[Mapbender-commits] r9492 - trunk/mapbender/owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 27 00:29:34 PDT 2016
Author: armin11
Date: 2016-05-27 00:29:34 -0700 (Fri, 27 May 2016)
New Revision: 9492
Removed:
   trunk/mapbender/owsproxy/http/index.php_old
fix wrong commit
Deleted: trunk/mapbender/owsproxy/http/index.php_old
--- trunk/mapbender/owsproxy/http/index.php_old	2016-05-27 07:26:54 UTC (rev 9491)
+++ trunk/mapbender/owsproxy/http/index.php_old	2016-05-27 07:29:34 UTC (rev 9492)
@@ -1,831 +0,0 @@
-<?php
-# $Id: index.php 8750 2013-12-11 06:53:13Z armin11 $
-# http://www.mapbender.org/index.php/Owsproxy
-# Module maintainer Uli
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__) . "/../../http/classes/class_administration.php");
-require_once(dirname(__FILE__) . "/../../http/classes/class_connector.php");
-require_once(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
-/***** conf *****/
-$imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
-$width = 400;
-$height = 400;
-/***** conf *****/
-if (ini_get('session.save_handler') == "memcache") {
-	$memcache_obj = new Memcache;
-	$memcache_obj->connect('localhost', 11211);
-	$e = new mb_notice("sessions stored to memcached");
-$postdata = $HTTP_RAW_POST_DATA;
-$owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
-$query = new QueryHandler();
-// an array with keys and values toLowerCase -> caseinsensitiv
-$reqParams = $query->getRequestParams();
-$e = new mb_notice("incoming request: ".OWSPROXY."/".$_REQUEST['sid']."/".$_REQUEST['wms'].$query->getRequest());
-$e = new mb_notice("owsproxy requested from: ".$_SERVER["REMOTE_ADDR"]);
-if (defined("OWSPROXY_SESSION_GRABBING_WHITELIST")) {
-	$whiteListArray = explode(",", OWSPROXY_SESSION_GRABBING_WHITELIST);
-	if (in_array($_SERVER["REMOTE_ADDR"], $whiteListArray)) {
-		$grabbingAllowed = true;
-		$e = new mb_notice("Grabbing allowed for IP: ".$_SERVER["REMOTE_ADDR"]);
-	} else {
-		$grabbingAllowed = false;
-		$e = new mb_notice("Grabbing not allowed for IP: ".$_SERVER["REMOTE_ADDR"]."!");
-} else {
-$e = new mb_notice("Initial session_id: ".session_id());
-//The session can be set by a given cookie value or was newly created by core/globalSettings.php
-//either empty (without mb_user_id value) - when the corresponding session file was lost or timed out
-//or filled, when there was an actual mapbender session before
-//check if mb_user_id is given and is an string with an integer:
-if(!$_SESSION['mb_user_id'] && !is_int($_SESSION['mb_user_id'])){
-	$e = new mb_notice("Newly initialized session - no logged in mapbender user for this session!");
-//Possibility to grap an existing session:
-if (defined("OWSPROXY_ALLOW_SESSION_GRABBING") && OWSPROXY_ALLOW_SESSION_GRABBING == true) {
-	if ($grabbingAllowed) {
-		//first check is to find out if a session with the current sid exists! If so use this one, if not use the current one which was generated from globalSettings.php
-		switch (ini_get('session.save_handler')) {
-			//$e = new mb_notice("filesystem session found");
-			case "files":
-				$e = new mb_notice("search for session in filesystem");
-				if (file_exists(ini_get('session.save_path')."/sess_".$_REQUEST["sid"]) && session_id() !== $_REQUEST["sid"]) {
-					//there is a current session for the requested url
-					$e = new mb_notice("A current session exists for this url and will be used!");
-					$oldsessionId = session_id();
-					$tmpSessionFile = ini_get('session.save_path')."/sess_".session_id();
-					//do the following only, if a user is in this session - maybe it is a session which was generated from an external application and therefor it is empty!
-					session_id($_REQUEST["sid"]);
-					$e = new mb_notice("Grabbed session with id: ".session_id());
-					//kill dynamical session
-					//@unlink($tmpSessionFile);
-					$e = new mb_notice("Following user was found and will be used for authorization: ".Mapbender::session()->get('mb_user_id'));
-					$foundUserId = Mapbender::session()->get('mb_user_id');
-					if (!isset($foundUserId) || $foundUserId =='') {
-						$e = new mb_notice("No user found in the existing session - switch to the initial old one!");
-						session_id($oldsessionId);
-						//unset($tmpSessionFile);
-					} else {
-						//delete session as it will not be needed any longer
-						$e = new mb_notice("User found in grabbed session. Following temporary session will be deleted: ".$tmpSessionFile);
-						@unlink($tmpSessionFile);
-						unset($tmpSessionFile);
-				} else {
-				$e = new mb_notice("session exists but maybe no user in this session?");
-			break;
-			case "memcache":
-				//check if a session exists for the SID param and if this session
-				$currentSession = $memcache_obj->get($_REQUEST["sid"]);
-				if ($currentSession !== false && session_id() !== $_REQUEST["sid"]) {
-					$e = new mb_exception("A current session exists for this url and will be used!");
-					//$oldsessionId = session_id();
-					//get actual session as key from memcached - new if not there
-					$tmpSessionFile = session_id();
-					//$tmpSessionFile = ini_get('session.save_path')."/sess_".session_id();
-					$e = new mb_exception("Grabbed session with id: ".session_id());
-					$e = new mb_exception("Following user was found and will be used for authorization: ".Mapbender::session()->get('mb_user_id'));
-						$e = new mb_exception("No user found in the existing session - switch to the initial one!");
-						session_id($tmpSessionFile);
-					} else {
-						//delete old initial session  as it will not be needed any longer
-						$e = new mb_exception("Following temporary session will be deleted: ".$tmpSessionFile);
-						//delete session from memcached
-						$memcache_obj->delete($tmpSessionFile);
-			break;
-//check for user
-//check if current session has the same id as the session which is requested in the owsproxy url
-//exchange them, if they differ and redirect to an new one with the current session
-if (session_id() !== $_REQUEST["sid"]) {
-	//get all request params which are original
-	//build reuquest
-	$redirectUrl = OWSPROXY."/".session_id()."/".$_REQUEST['wms'].$query->getRequest();
-	$e = new mb_exception("IDs differ - redirect to new owsproxy url: ".$redirectUrl);
-	header("Location: ".$redirectUrl);
-	die();
-} else {
-	$e = new mb_exception("Current session_id() identical to requested SID!");
-//this is the request which may have been redirected
-//check for given user session with user_id which can be tested again the authorization
-(integer)$foundUserId = Mapbender::session()->get('mb_user_id');
-$e = new mb_exception("Found user id: ".$foundUserId ." of type: ".gettype($foundUserId));
-if(is_int($foundUserId) &&  $foundUserId > 0){
-	//Define the session to be temporary. This file can be deleted after the request was successful. It will be generated every time again.
-	$e = new mb_exception("userId is_int and > 0");
-		case "files":
-		break;
-		case "memcache":
-		break;
-	$e = new mb_notice("user_id not found in session!");
-	//if configured in mapbender.conf, create guest session so that also proxied service can be watched in external applications when they are available to the anonymous user
-	//only possible for webapplications - in case of desktop applications the user have to use his credentials and http_auth module
-	if (defined("OWSPROXY_ALLOW_PUBLIC_USER") && OWSPROXY_ALLOW_PUBLIC_USER && defined("PUBLIC_USER") && PUBLIC_USER != "") {
-		//setSession();
-  		Mapbender::session()->set("mb_user_id",PUBLIC_USER);
-		Mapbender::session()->set("external_proxy_user",true);
-		Mapbender::session()->set("mb_user_ip",$_SERVER['REMOTE_ADDR']);
-		$e = new mb_notice("Permission allowed for public user with id: ".PUBLIC_USER);
-	} else {
-		$e = new mb_notice("Permission denied - public user not allowed to access ressource!");
-		//kill actual session file
-			case "files":
-				$e = new mb_exception("delete temporary session file: ".$tmpSessionFile);
-				throwE(array("Permission denied"," - no current session found and ","public user not allowed to access ressource!"));
-				die();
-			break;
-			case "memcache":
-				$e = new mb_exception("delete temporary session ".session_id());
-				die();
-			break;
-} else {
-	$e = new mb_notice("mb_user_id found in session: ".$_SESSION['mb_user_id']);
-	$e = new mb_notice("tmpSessionFile: exists: ".isset($tmpSessionFile));
-//start the session to be able to write urls to it - for
-session_start();//maybe it was started by globalSettings.php
-$n = new administration;
-//Extra security - IP check
-if (defined("OWSPROXY_BIND_IP") && OWSPROXY_BIND_IP == true) {
-	if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
-		throwE(array("Session not identified.","Permission denied.","Please authenticate."));
-		die();
-$e = new mb_notice("user id for authorization test: ".$_SESSION['mb_user_id']);
-$wmsId = $n->getWmsIdFromOwsproxyString($query->getOwsproxyServiceId());
-//get authentication infos if they are available in wms table! if not $auth = false
-$auth = $n->getAuthInfoOfWMS($wmsId);
-if ($auth['auth_type']==''){
-	unset($auth);
-/*************  workflow ************/
-$n = new administration();
-switch (strtolower($reqParams['request'])) {
-	case 'getcapabilities':
-		$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
-		$query->setOnlineResource($arrayOnlineresources['wms_getcapabilities']);
-		$request = $query->getRequest();
-		if(isset($auth)){
-			getCapabilities($request,$auth);
-		else {
-			getCapabilities($request);
-		break;
-	case 'getfeatureinfo':
-		$query->setOnlineResource($arrayOnlineresources['wms_getfeatureinfo']);
-		if(isset($auth)){
-			getFeatureInfo($request,$auth);
-		else {
-			getFeatureInfo($request);
-		break;
-	case 'getmap':
-		$arrayOnlineresources = checkWmsPermission($owsproxyService);
-		$query->setOnlineResource($arrayOnlineresources['wms_getmap']);
-		$layers = checkLayerPermission($arrayOnlineresources['wms_id'],$reqParams['layers']);
-		if($layers===""){
-			throwE("Permission denied");
-			die();
-		$query->setParam("layers",urldecode($layers));//the decoding of layernames dont make problems - but not really good names will be requested also ;-)
-		//Following is only needed for high quality print and is vendor specific for mapservers mapfiles!
-		if (defined("OWSPROXY_SUPPORT_HQ_PRINTING") && OWSPROXY_SUPPORT_HQ_PRINTING) {
-			//if url has integrated mapfile - exchange it
-			//$e = new mb_notice("owsproxy/http/index.php: OWSPROXY_SUPPORT_HQ_PRINTING is set");
-			if ($reqParams['mapbenderhighqualityprint'] === "true") {
-				//exchange mapfiles with high quality ones
-				$request = preg_replace("/\.map/","_4.map",$query->getRequest());
-			} else {
-		} else {
-		//log proxy requests
-		if($n->getWmsLogTag($arrayOnlineresources['wms_id'])==1) {
-			#do log to db
-			#TODO read out size of bbox and calculate price
-		        #get price out of db
-			$price=intval($n->getWmsPrice($arrayOnlineresources['wms_id']));
-			$n->logWmsProxyRequest($arrayOnlineresources['wms_id'],$_SESSION['mb_user_id'],$request,$price);
-		//$e = new mb_exception("owsproxy/http/index.php: ".$request);
-		if(isset($auth)){
-			getImage($request,$auth);
-		else {
-			getImage($request);
-		break;
-	case 'map':
-		if($layers===""){
-			die();
-		if(isset($auth)){
-			getImage($url,$auth);
-		else {
-			getImage($url);
-		break;
-	case 'getlegendgraphic':
-		$url = getLegendUrl($query->getOwsproxyServiceId());
-		if (isset ($reqParams['sld']) && $reqParams['sld'] != "") {
-			$url = $url . getConjunctionCharacter($url) . "SLD=".$reqParams['sld'];
-		if(isset($auth)){
-		else {
-			getImage($url);
-		break;
-	case 'external':
-		getExternalRequest($query->getOwsproxyServiceId());
-		break;
-	case 'getfeature':
-		$arrayFeatures = array($reqParams['typename']);
-		$arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures);
-		$query->setOnlineResource($arrayOnlineresources['wfs_getfeature']);
-		$request = stripslashes($request);
-		getFeature($request);
-		break;
-	// case wfs transaction (because of raw POST the request param is empty)
-	case '':
-		$arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
-		$query->setOnlineResource($arrayOnlineresources['wfs_transaction']);
-		doTransaction($request, $HTTP_RAW_POST_DATA);
-		break;
-	default:
-//why delete session here - only if it was temporary?
-switch (ini_get('session.save_handler')) {
-	case "files":
-		if (isset($tmpSessionFile) && file_exists($tmpSessionFile)) {
-			$e = new mb_notice("Following temporary session will be deleted: ".$tmpSessionFile);
-	break;
-	case "memcache":
-		if (isset($tmpSessionFile) && $memcache_obj->get($tmpSessionFile) != false) {
-	break;
-function throwE($e){
-	global $reqParams, $imageformats;
-	if(in_array($reqParams['format'],$imageformats)){
-		throwImage($e);
-	else{
-		throwText($e);
-function throwImage($e){
-	global $width,$height;
-	$image = imagecreate($width,$height);
-	$transparent = ImageColorAllocate($image,155,155,155);
-	ImageFilledRectangle($image,0,0,$width,$height,$transparent);
-	imagecolortransparent($image, $transparent);
-	$text_color = ImageColorAllocate ($image, 233, 14, 91);
-	if (count($e) > 1){
-		for($i=0; $i<count($e); $i++){
-			$imageString = $e[$i];
-			ImageString ($image, 3, 5, $i*20, $imageString, $text_color);
-	} else {
-		if (is_array($e)) {
-			$imageString = $e[0];
-		} else {
-			$imageString = $e;
-		if ($imageString == "") {
-			$imageString = "An unknown error occured!";
-	responseImage($image);
-function throwText($e){
-	echo join(" ", $e);
-function responseImage($im){
-	global $reqParams;
-	$format = $reqParams['format'];
-	$format="image/gif";
-	if($format == 'image/png'){header("Content-Type: image/png");}
-	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
-	if($format == 'image/gif'){header("Content-Type: image/gif");}
-	if($format == 'image/png'){imagepng($im);}
-	if($format == 'image/jpeg' || $format == 'image/jpg'){imagejpeg($im);}
-	if($format == 'image/gif'){imagegif($im);}
-function completeURL($url){
-	$mykeys = array_keys($reqParams);
-	for($i=0; $i<count($mykeys);$i++){
-		if($i > 0){ $url .= "&"; }
-		$url .= $mykeys[$i]."=".urlencode($reqParams[$mykeys[$i]]);
-	return $url;
- * fetch and returns an image to client
- * @param string the original url of the image to send
-function getImage($or){
-	header("Content-Type: ".$reqParams['format']);
-	#log the image_requests to database
-	#log the following to table mb_proxy_log
-	#timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
-	if (func_num_args() == 2) { //new for HTTP Authentication
-		$auth = func_get_arg(1);
-		echo getDocumentContent($or,$auth);
-	else
-		echo getDocumentContent($or);
- * fetchs and returns the content of the FeatureInfo Response
- * @param string the url of the FeatureInfoRequest
- * @return string the content of the FeatureInfo document
-function getFeatureInfo($url){
-	//$e = new mb_notice("owsproxy: Try to fetch FeatureInfoRequest: ".$url);
-	header("Content-Type: ".$reqParams['info_format']);
-		$content = getDocumentContent($url,$auth);
-	else {
-		$content = getDocumentContent($url);
-	$content = matchUrls($content);
-	echo $content;
- * fetchs and returns the content of WFS GetFeature response
- * @param string the url of the GetFeature request
- * @return echo the content of the GetFeature document
-function getFeature($url){
-	echo $content;
- * simulates a post request to host
- * @param string host to send the request to
- * @param string port of host to send the request to
- * @param string method to send data (should be "POST")
- * @param string path on host
- * @param string data to send to host
- * @return string hosts response
-function sendToHost($host,$port,$method,$path,$data){
-	$buf = '';
-    if (empty($method)) $method = 'POST';
-    $method = mb_strtoupper($method);
-    $fp = fsockopen($host, $port);
-    fputs($fp, "$method $path HTTP/1.1\r\n");
-    fputs($fp, "Host: $host\r\n");
-    fputs($fp,"Content-type: application/xml\r\n");
-    fputs($fp, "Content-length: " . strlen($data) . "\r\n");
-    fputs($fp, "Connection: close\r\n\r\n");
-    if ($method == 'POST') fputs($fp, $data);
-    while (!feof($fp)) $buf .= fgets($fp,4096);
-    fclose($fp);
-    return $buf;
- * get wfs featurenames that are touched by a tansaction request defined in XML $data
- * @param string XML that contains the tansaction request
- * @return array array of touched feature names
-function getWfsFeaturesFromTransaction($data){
-	new mb_exception("owsproxy.getWfsFeaturesFromTransaction.data: ".$data);
-	if(!$data || $data == ""){
-		return false;
-	$features = array();
-	$values = NULL;
-	$tags = NULL;
-	$parser = xml_parser_create();
-	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-	xml_parse_into_struct($parser,$data,$values,$tags);
-	$code = xml_get_error_code ($parser);
-	if ($code) {
-		$line = xml_get_current_line_number($parser);
-		$col = xml_get_current_column_number($parser);
-		$mb_exception = new mb_exception("OWSPROXY invalid Tansaction XML: ".xml_error_string($code) .  " in line " . $line. " at character ". $col);
-		die();
-	xml_parser_free($parser);
-	$insert = false;
-	$insertlevel = 0;
-	foreach ($values as $element) {
-		//features touched by insert
-		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "open"){
-			$insert = true;
-			$insertlevel = $element[level];
-		if($insert && $element[level] == $insertlevel + 1 && $element[type] == "open"){
-			array_push($features, $element[tag]);
-		if(strtoupper($element[tag]) == "WFS:INSERT" && $element[type] == "close"){
-			$insert = false;
-		//updated features
-		if(strtoupper($element[tag]) == "WFS:UPDATE" && $element[type] == "open"){
-			array_push($features, $element[attributes]["typeName"]);
-		//deleted features
-		if(strtoupper($element[tag]) == "WFS:DELETE" && $element[type] == "open"){
-	return $features;
- * sends the data of WFS Transaction and echos the response
- *  @param string url to send the WFS Transaction to
- *  @param string WFS Transaction data
-function doTransaction($url, $data){
-	$arURL = parse_url($url);
-	$host = $arURL["host"];
-	$port = $arURL["port"];
-	if($port == '') $port = 80;
-	$path = $arURL["path"];
-	$method = "POST";
-	$result = sendToHost($host,$port,$method,html_entity_decode($path),$data);
-	//delete header from result
-	$result = mb_eregi_replace("^[^<]*", "", $result);
-	$result = mb_eregi_replace("[^>]*$", "", $result);
-	echo $result;
-function matchUrls($content){
-	if(!isset($_SESSION["owsproxyUrls"])){
-		$_SESSION["owsproxyUrls"] = array();
-		$_SESSION["owsproxyUrls"]["id"] = array();
-		$_SESSION["owsproxyUrls"]["url"] = array();
-	$pattern = "/[\"|\'](https*:\/\/[^\"|^\']*)[\"|\']/";
-	preg_match_all($pattern,$content,$matches);
-	for($i=0; $i<count($matches[1]); $i++){
-		$req = $matches[1][$i];
-		$notice = new mb_exception("owsproxy found URL ".$i.": ".$req);
-		#$notice = new mb_exception("owsproxy id:".$req);
-		$id = registerURL($req);
-		$extReq = setExternalRequest($id);
-		$notice = new mb_exception("MD5 URL ".$id." - external link: ".$extReq);
-		$content = str_replace($req,$extReq,$content);
-	return $content;
-function setExternalRequest($id){
-	global $reqParams,$query;
-//	$extReq = "http://".$_SESSION['HTTP_HOST'] ."/owsproxy/". $reqParams['sid'] ."/".$id."?request=external";
-	$extReq = OWSPROXY ."/". $reqParams['sid'] ."/".$id."?request=external";
-	return $extReq;
-function getExternalRequest($id){
-	for($i=0; $i<count($_SESSION["owsproxyUrls"]["url"]); $i++){
-		if($id == $_SESSION["owsproxyUrls"]["id"][$i]){
-			$cUrl = $_SESSION["owsproxyUrls"]["url"][$i];
-			$query_string = removeOWSGetParams($_SERVER["QUERY_STRING"]);
-			if($query_string != ''){
-				$cUrl .= getConjunctionCharacter($cUrl).$query_string;
-			$metainfo = get_headers($cUrl,1);
-			// just for the stupid InternetExplorer
-			header('Pragma: private');
-			header('Cache-control: private, must-revalidate');
-			header("Content-Type: ".$metainfo['Content-Type']);
-			$content = getDocumentContent($cUrl);
-			#$content = matchUrls($content);
-			echo $content;
-function removeOWSGetParams($query_string){
-	$r = preg_replace("/.*request=external&/","",$query_string);
-	#return $r;
-	return "";
-function getConjunctionCharacter($url){
-	if(strpos($url,"?")){
-		if(strpos($url,"?") == strlen($url)){
-			$cchar = "";
-		}else if(strpos($url,"&") == strlen($url)){
-			$cchar = "";
-		}else{
-			$cchar = "&";
-	if(strpos($url,"?") === false){
-		$cchar = "?";
-	return $cchar;
-function registerUrl($url){
-	if(!in_array($url,$_SESSION["owsproxyUrls"]["url"])){
-		$id = md5($url);
-		array_push($_SESSION["owsproxyUrls"]["url"],$url);
-		array_push($_SESSION["owsproxyUrls"]["id"], $id);
-	else{
-			if($url == $_SESSION["owsproxyUrls"]["url"][$i]){
-				$id = $_SESSION["owsproxyUrls"]["id"][$i];
-	return $id;
-function getCapabilities($url){
-	global $arrayOnlineresources;
-	global $sid,$wms;
-	$t = array(htmlentities($arrayOnlineresources["wms_getcapabilities"]),htmlentities($arrayOnlineresources["wms_getmap"]),htmlentities($arrayOnlineresources["wms_getfeatureinfo"]));
-	$new = OWSPROXY ."/". $sid ."/".$wms."?";
-	$r = str_replace($t,$new,$arrayOnlineresources["wms_getcapabilities_doc"]);
-	header("Content-Type: application/xml");
-	echo $r;
- * gets the original url of the requested legend graphic
- * @param string owsproxy md5
- * @return string url to legend graphic
-function getLegendUrl($wms){
-	//get wms id
-	$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
-	$v = array($wms);
-	$t = array("s");
-	$res = db_prep_query($sql, $v, $t);
-	if($row = db_fetch_array($res)) {
-		$wmsid = $row["wms_id"];
-		$getLegendUrl = $row["wms_getlegendurl"];
-	} else {
-		throwE(array("No wms data available."));
-		die();
-	//get the url
-	$sql = "SELECT layer_style.legendurl ";
-	$sql .= "FROM layer_style JOIN layer ";
-	$sql .= "ON layer_style.fkey_layer_id = layer.layer_id ";
-	$sql .= "WHERE layer.layer_name = $2 AND layer.fkey_wms_id = $1 ";
-	$sql .= "AND layer_style.name = $3 AND layer_style.legendurlformat = $4";
-	$v = array($wmsid, $reqParams['layer'], $reqParams['style'], $reqParams['format']);
-	$t = array("i", "s", "s", "s");
-		if (strpos($row["legendurl"],'http') !== 0) {
-			$e = new mb_exception("combine legendurls!");
-			return $getLegendUrl.$row["legendurl"];
-		return $row["legendurl"];
-	} else {
-		throwE(array("No legend available."));
-		die();
- * validated access permission on requested wms
- * @param string OWSPROXY md5
- * @return array array with detailed information about requested wms
-function checkWmsPermission($wms){
-	global $con, $n;
-	$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
-	$mywms = $n->getWmsByOwnGuis($myguis);
-	$v = array($wms);
-	$t = array("s");
-	$service = array();
-	if($row = db_fetch_array($res)){
-		$service["wms_id"] = $row["wms_id"];
-		$service["wms_getcapabilities"] = $row["wms_getcapabilities"];
-		$service["wms_getmap"] = $row["wms_getmap"];
-		$service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
-		$service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
-	if(!$row || count($mywms) == 0){
-		die();
-	if(!in_array($service["wms_id"], $mywms)){
-		throwE(array("Permission denied."," -> ".$service["wms_id"], implode(",", $mywms)));
-		die();
-	return $service;
- * validates the access permission by getting the appropriate wfs_conf
- * to each feature requested and check the wfs_conf permission
- * @param array array of requested featuretype names
- * @return array array with detailed information on reqested wfs
-function checkWfsPermission($wfsOws, $features){
-	global $con, $n;
-	$myconfs = $n->getWfsConfByPermission($_SESSION["mb_user_id"]);
-	//check if we know the features requested
-	if(count($features) == 0){
-		throwE(array("No wfs_feature data available."));
-		die();
-	//get wfs
-	$sql = "SELECT * FROM wfs WHERE wfs_owsproxy = $1";
-	$v = array($wfsOws);
-	$t = array("s");
-		$service["wfs_id"] = $row["wfs_id"];
-		$service["wfs_getcapabilities"] = $row["wfs_getcapabilities"];
-		$service["wfs_getfeature"] = $row["wfs_getfeature"];
-		$service["wfs_describefeaturetype"] = $row["wfs_describefeaturetype"];
-		$service["wfs_transaction"] = $row["wfs_transaction"];
-		$service["wfs_getcapabilities_doc"] = $row["wfs_getcapabilities_doc"];
-	else{
-		throwE(array("No wfs data available."));
-		die();
-	foreach($features as $feature){
-		//get appropriate wfs_conf
-		$sql = "SELECT wfs_conf.wfs_conf_id FROM wfs_conf ";
-		$sql.= "JOIN wfs_featuretype ";
-		$sql.= "ON wfs_featuretype.featuretype_id = wfs_conf.fkey_featuretype_id ";
-		$sql.= "WHERE wfs_featuretype.featuretype_name = $2 ";
-		$sql.= "AND wfs_featuretype.fkey_wfs_id = $1";
-		$v = array($service["wfs_id"], $feature);
-		$t = array("i","s");
-		if(!($row = db_fetch_array($res))){
-			$notice = new mb_exception("Permissioncheck failed no wfs conf for wfs ".$service["wfs_id"]." with feturetype ".$feature);
-			throwE(array("No wfs_conf data for featuretype ".$feature));
-			die();
-		$conf_id = $row["wfs_conf_id"];
-		//check permission
-		if(!in_array($conf_id, $myconfs)){
-			$notice = new mb_exception("Permissioncheck failed:".$conf_id." not in ".implode(",", $myconfs));
-			throwE(array("Permission denied."," -> ".$conf_id, implode(",", $myconfs)));
-			die();
-	return $service;
-function checkLayerPermission($wms_id,$l){
-	global $n, $owsproxyService;
-//	$notice = new mb_exception("owsproxy: checkLayerpermission: wms: ".$wms_id.", layer: ".$l);
-	$myl = split(",",$l);
-	$r = array();
-	foreach($myl as $mysl){
-		if($n->getLayerPermission($wms_id, $mysl, $_SESSION["mb_user_id"]) === true){
-			array_push($r, $mysl);
-	$ret = implode(",",$r);
-	return $ret;
-function getDocumentContent($url){
-		$d = new connector($url, $auth);
-	else {
-		$d = new connector($url);
-	return $d->file;
More information about the Mapbender_commits mailing list
