[Mapbender-commits] r9938 - in trunk/mapbender: core http/extensions http/geoportal http/html http/javascripts http_auth/http lib owsproxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 05:56:03 PDT 2018
Author: armin11
Date: 2018-08-09 05:56:03 -0700 (Thu, 09 Aug 2018)
New Revision: 9938
   trunk/mapbender/core/globalSettings.php
   trunk/mapbender/http/extensions/DifferenceEngine.php
   trunk/mapbender/http/extensions/JSON.php
   trunk/mapbender/http/geoportal/class_gml2_DOG.php
   trunk/mapbender/http/geoportal/class_gml3.php
   trunk/mapbender/http/geoportal/gaz_geom.php
   trunk/mapbender/http/geoportal/gaz_geom_mobile.php
   trunk/mapbender/http/html/mod_blank.html
   trunk/mapbender/http/javascripts/initWmcObj.php
   trunk/mapbender/http_auth/http/index.php
   trunk/mapbender/lib/exception.js
   trunk/mapbender/owsproxy/http/index.php
Last fixes for php7 compatibility thanx to http://www.benndorf.de financed by the federal german state Hesse
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/core/globalSettings.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -48,5 +48,9 @@
 require_once dirname(__FILE__) . "/../http/classes/class_locale.php";
 $localeObj = new Mb_locale(Mapbender::session()->get("mb_lang"));
+// globally used includes (due to PHP Version changes)
+require_once dirname(__FILE__) . "/../http/php/wrappers/includes.php";
Modified: trunk/mapbender/http/extensions/DifferenceEngine.php
--- trunk/mapbender/http/extensions/DifferenceEngine.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/extensions/DifferenceEngine.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -30,13 +30,21 @@
 class _DiffOp_Copy extends _DiffOp {
   var $type = 'copy';
-  function _DiffOp_Copy ($orig, $closing = false) {
+  function __construct ($orig, $closing = false) {
     if (!is_array($closing))
       $closing = $orig;
     $this->orig = $orig;
     $this->closing = $closing;
+* Old constructor to keep PHP downward compatibility
+  function _DiffOp_Copy ($orig, $closing = false) {
+    self::__construct($orig, $closing);
   function reverse() {
     return new _DiffOp_Copy($this->closing, $this->orig);
@@ -45,11 +53,16 @@
 class _DiffOp_Delete extends _DiffOp {
   var $type = 'delete';
-  function _DiffOp_Delete ($lines) {
+  function __construct ($lines) {
     $this->orig = $lines;
     $this->closing = false;
+  function _DiffOp_Delete ($lines) {
+    self::__construct($lines);
     return new _DiffOp_Add($this->orig);
@@ -58,10 +71,14 @@
 class _DiffOp_Add extends _DiffOp {
   var $type = 'add';
-  function _DiffOp_Add ($lines) {
     $this->closing = $lines;
     $this->orig = false;
+  function _DiffOp_Add ($lines) {
     return new _DiffOp_Delete($this->closing);
@@ -71,11 +88,16 @@
 class _DiffOp_Change extends _DiffOp {
   var $type = 'change';
-  function _DiffOp_Change ($orig, $closing) {
+  function __construct ($orig, $closing) {
+  function _DiffOp_Change ($orig, $closing) {
     return new _DiffOp_Change($this->closing, $this->orig);
@@ -501,12 +523,17 @@
    *      (Typically these are lines from a file.)
    * @param $to_lines array An array of strings.
-  function Diff($from_lines, $to_lines) {
+  function __construct($from_lines, $to_lines) {
     $eng = new _DiffEngine;
     $this->edits = $eng->diff($from_lines, $to_lines);
     //$this->_check($from_lines, $to_lines);
+  function Diff($from_lines, $to_lines) {
+    self::__construct($from_lines, $to_lines);
    * Compute reversed Diff.
@@ -627,52 +654,61 @@
 class MappedDiff
 extends Diff
-   * Constructor.
-   * Computes diff between sequences of strings.
-   * This can be used to compute things like
-   * case-insensitve diffs, or diffs which ignore
-   * changes in white-space.
-   * @param $from_lines array An array of strings.
-   *  (Typically these are lines from a file.)
-   * @param $to_lines array An array of strings.
-   * @param $mapped_from_lines array This array should
-   *  have the same size number of elements as $from_lines.
-   *  The elements in $mapped_from_lines and
-   *  $mapped_to_lines are what is actually compared
-   *  when computing the diff.
-   * @param $mapped_to_lines array This array should
-   *  have the same number of elements as $to_lines.
-  function MappedDiff($from_lines, $to_lines,
-            $mapped_from_lines, $mapped_to_lines) {
+    * Constructor.
+    * Computes diff between sequences of strings.
+    * This can be used to compute things like
+    * case-insensitve diffs, or diffs which ignore
+    * changes in white-space.
+    * @param $from_lines array An array of strings.
+    *  (Typically these are lines from a file.)
+    * @param $to_lines array An array of strings.
+    * @param $mapped_from_lines array This array should
+    *  have the same size number of elements as $from_lines.
+    *  The elements in $mapped_from_lines and
+    *  $mapped_to_lines are what is actually compared
+    *  when computing the diff.
+    * @param $mapped_to_lines array This array should
+    *  have the same number of elements as $to_lines.
+    function __construct($from_lines, $to_lines,
+        $mapped_from_lines, $mapped_to_lines) {
-    assert(sizeof($from_lines) == sizeof($mapped_from_lines));
-    assert(sizeof($to_lines) == sizeof($mapped_to_lines));
+        assert(sizeof($from_lines) == sizeof($mapped_from_lines));
+        assert(sizeof($to_lines) == sizeof($mapped_to_lines));
-    $this->Diff($mapped_from_lines, $mapped_to_lines);
+        $this->Diff($mapped_from_lines, $mapped_to_lines);
-    $xi = $yi = 0;
-    for ($i = 0; $i < sizeof($this->edits); $i++) {
-      $orig = &$this->edits[$i]->orig;
-      if (is_array($orig)) {
-        $orig = array_slice($from_lines, $xi, sizeof($orig));
-        $xi += sizeof($orig);
+        $xi = $yi = 0;
+        for ($i = 0; $i < sizeof($this->edits); $i++) {
+            $orig = &$this->edits[$i]->orig;
+            if (is_array($orig)) {
+                $orig = array_slice($from_lines, $xi, sizeof($orig));
+                $xi += sizeof($orig);
-      $closing = &$this->edits[$i]->closing;
-      if (is_array($closing)) {
-        $closing = array_slice($to_lines, $yi, sizeof($closing));
-        $yi += sizeof($closing);
+            $closing = &$this->edits[$i]->closing;
+            if (is_array($closing)) {
+                $closing = array_slice($to_lines, $yi, sizeof($closing));
+                $yi += sizeof($closing);
+    * Old constructor to keep PHP downward compatibility
+    function MappedDiff($from_lines, $to_lines, $mapped_from_lines,
+          $mapped_to_lines) {
+        self::__construct($from_lines, $to_lines, $mapped_from_lines,
+            $mapped_to_lines);
@@ -837,12 +873,16 @@
 define('NBSP', "\xC2\xA0");     // utf-8 non-breaking space.
 class _HWLDF_WordAccumulator {
-  function _HWLDF_WordAccumulator () {
+  function __construct () {
     $this->_lines = array();
     $this->_line = '';
     $this->_group = '';
     $this->_tag = '';
+  function _HWLDF_WordAccumulator () {
+    self::__construct();
   function _flushGroup ($new_tag) {
     if ($this->_group !== '') {
@@ -888,15 +928,19 @@
 class WordLevelDiff extends MappedDiff
-  function WordLevelDiff ($orig_lines, $closing_lines) {
+  function __construct ($orig_lines, $closing_lines) {
     list ($orig_words, $orig_stripped) = $this->_split($orig_lines);
     list ($closing_words, $closing_stripped) = $this->_split($closing_lines);
     $this->MappedDiff($orig_words, $closing_words,
               $orig_stripped, $closing_stripped);
+  function WordLevelDiff ($orig_lines, $closing_lines) {
+    self::__construct($orig_lines, $closing_lines);
   function _split($lines) {
     // FIXME: fix POSIX char class.
 #    if (!preg_match_all('/ ( [^\S\n]+ | [[:alnum:]]+ | . ) (?: (?!< \n) [^\S\n])? /xs',
@@ -940,11 +984,16 @@
 class UnifiedDiffFormatter extends DiffFormatter
-    function UnifiedDiffFormatter($context_lines = 4) {
+    function __construct($context_lines = 4) {
         $this->leading_context_lines = $context_lines;
         $this->trailing_context_lines = $context_lines;
+    function UnifiedDiffFormatter($context_lines = 4) {
+        self::__construct($context_lines);
     function _block_header($xbeg, $xlen, $ybeg, $ylen) {
         if ($xlen != 1)
             $xbeg .= "," . $xlen;
@@ -971,11 +1020,16 @@
 class TableDiffFormatter extends DiffFormatter
-  function TableDiffFormatter() {
+  function __construct() {
     $this->leading_context_lines = 2;
     $this->trailing_context_lines = 2;
+  function TableDiffFormatter() {
   function _pre($text){
     $text = htmlspecialchars($text);
     $text = str_replace('  ','  ',$text);
Modified: trunk/mapbender/http/extensions/JSON.php
--- trunk/mapbender/http/extensions/JSON.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/extensions/JSON.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -130,10 +130,18 @@
     *                                   bubble up with an error, so all return values
     *                                   from encode() should be checked with isError()
-    function Services_JSON($use = 0)
+    function __construct($use = 0)
         $this->use = $use;
+    function Services_JSON($use = 0)
+        self::__construct($use);
     * convert a string from one UTF-16 char to one UTF-8 char
@@ -780,10 +788,16 @@
     class Services_JSON_Error extends PEAR_Error
+        function __construct($message = 'unknown error', $code = null,
+                             $mode = null, $options = null, $userinfo = null)
+            parent::PEAR_Error($message, $code, $mode, $options, $userinfo);
         function Services_JSON_Error($message = 'unknown error', $code = null,
-            parent::PEAR_Error($message, $code, $mode, $options, $userinfo);
+            self::__construct($message, $code, $mode, $options, $userinfo);
@@ -794,11 +808,17 @@
-        function Services_JSON_Error($message = 'unknown error', $code = null,
-                                     $mode = null, $options = null, $userinfo = null)
+        function Services_JSON_Error($message = 'unknown error', $code = null,
Modified: trunk/mapbender/http/geoportal/class_gml2_DOG.php
--- trunk/mapbender/http/geoportal/class_gml2_DOG.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/geoportal/class_gml2_DOG.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -38,9 +38,18 @@
 	var $geomFeaturetypeElement = null;
-	function gml2(){
+	function __construct(){
 		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
+        function gml2(){
 	function getGml($req){
 		$x = new connector($req);
 		return $x->file;
@@ -496,7 +505,7 @@
 	function sepNameSpace($s){
-		list($ns,$FeaturePropertyName) = split(":",$s);
+		list($ns,$FeaturePropertyName) = mbw_split(":",$s);
 		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
 		return $nodeName;
Modified: trunk/mapbender/http/geoportal/class_gml3.php
--- trunk/mapbender/http/geoportal/class_gml3.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/geoportal/class_gml3.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -39,9 +39,17 @@
-	function gml3(){
+        function gml3(){
 		return $x->file;
@@ -480,7 +488,7 @@
 		return $nodeName;
Modified: trunk/mapbender/http/geoportal/gaz_geom.php
--- trunk/mapbender/http/geoportal/gaz_geom.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/geoportal/gaz_geom.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -79,7 +79,7 @@
 /****** Workflow *********************************/
-$astr = split(",",replaceChars($sstr));
+$astr = mbw_split(",",replaceChars($sstr));
 if(count($astr) == 1){
 	$astr[0] = trim($astr[0]);
 	$plz = getPlz($astr[0]);
Modified: trunk/mapbender/http/geoportal/gaz_geom_mobile.php
--- trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/geoportal/gaz_geom_mobile.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -144,7 +144,7 @@
 $test = str_replace("ß", "ss", $sstr);
 $e = new mb_notice("replaced test string: ".$test);
 $e = new mb_notice("replaced string: ".$astr[0]." ".$astr[1]." ".$astr[2]);
 //if only one string without any comma is given
Modified: trunk/mapbender/http/html/mod_blank.html
--- trunk/mapbender/http/html/mod_blank.html	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/html/mod_blank.html	2018-08-09 12:56:03 UTC (rev 9938)
@@ -1,6 +1,6 @@
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <!-- version 2.0.0 -->
-<html>
+<html lang="en">
 <head>
 <title>Blank</title>
 </head>
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -212,7 +212,7 @@
 	// WMS param given as comma separated list
 	else {
-		$inputWmsArray = split(",",$getParams['WMS']);
+		$inputWmsArray = mbw_split(",",$getParams['WMS']);
 	$wmsArray = array();
 	$singleAssocArray = array();
Modified: trunk/mapbender/http_auth/http/index.php
--- trunk/mapbender/http_auth/http/index.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/http_auth/http/index.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -524,13 +524,25 @@
         break;
     case '':
-        $arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
+        if (version_compare(PHP_VERSION, '7.0.0', '<')) {
+            $arrayFeatures = getWfsFeaturesFromTransaction($HTTP_RAW_POST_DATA);
+        else {
+            $rawpostdata = file_get_contents("php://input");
+            $arrayFeatures = getWfsFeaturesFromTransaction($rawpostdata);
         $arrayOnlineresources = checkWfsPermission($owsproxyString, $arrayFeatures, $userId);
         $query->setOnlineResource($arrayOnlineresources['wfs_transaction']);
         $request = $query->getRequest();
 	//TODO: following is not the standard way because ows has not to handle vsp!!!
 	$request = delTotalFromQuery("wfs_id",$request);
-        doTransaction($request, $HTTP_RAW_POST_DATA);
+            doTransaction($request, $HTTP_RAW_POST_DATA);
+        else {
+            doTransaction($request, $rawpostdata);
         break;
     default:
         echo 'Your are logged in as: <b>' . $requestHeaderArray['username'] . '</b> and requested the layer/featuretype with id=<b>' . $layerId . '</b> but your request is not a valid OWS request';
Modified: trunk/mapbender/lib/exception.js
--- trunk/mapbender/lib/exception.js	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/lib/exception.js	2018-08-09 12:56:03 UTC (rev 9938)
@@ -3,7 +3,7 @@
 	//An abstract class, logs JavaScript events like errors, warnings etc.
 	var Mb_log = function () {
 		var that = this;
 		var levelArray = global_log_levels.split(",");
 		var log_level = global_mb_log_level;
 		var log_js = global_mb_log_js;
@@ -23,6 +23,12 @@
 			return (isNotOff && isAppropriate);
 		this.throwException = function (message, level) {
+                        if (Mb_log.caller == null){
+                            message = ' NN - ' + message;
+                        else {
+                            message = Mb_log.caller + ' - ' + message;
 			if (isValidLevel(level)) {
 				if (log_js == "on") {
 					try {
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php	2018-08-09 12:43:50 UTC (rev 9937)
+++ trunk/mapbender/owsproxy/http/index.php	2018-08-09 12:56:03 UTC (rev 9938)
@@ -481,11 +481,23 @@
         break;
     // case wfs transaction (because of raw POST the request param is empty)
     case '':
+        else {
         $arrayOnlineresources = checkWfsPermission($query->getOwsproxyServiceId(), $arrayFeatures, $userId);
+        else {
         break;
     default:
 	throwText(array("Request parameter not known to mapbender security proxy!"));
More information about the Mapbender_commits mailing list
