[Mapbender-commits] r9939 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 06:05:30 PDT 2018
Author: armin11
Date: 2018-08-09 06:05:30 -0700 (Thu, 09 Aug 2018)
New Revision: 9939
Removed:
   trunk/mapbender/http/classes/class_metadata.php
   trunk/mapbender/http/classes/class_metadata_new.php~
Delete old unneeded files
Deleted: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php	2018-08-09 12:56:03 UTC (rev 9938)
+++ trunk/mapbender/http/classes/class_metadata.php	2018-08-09 13:05:30 UTC (rev 9939)
@@ -1,1471 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/class_administration.php");
- * class to handle keywords for services
-class class_metadata{
-	private $user_id;
-	private $departments = array();
-	private $categories = array();
-	private $searchtext;
-	private $timestamp_beg;
-	private $timestamp_end;
-	private $limit;
-	private $search_bbox = array();
-	private $search_epsg;
-	private $obj_members = array();
-	private $availabilityTime;
-	private $doc;
-	 * Constructor of the class_metadata-class
-	 * @$user_id 		integer 	users ID
-	 * @$departments 	array 		departments
-	 * @$categories 	array 		categories
-	 * @$searchtext 	string 		searchtext (with blanks => more searchwords)
-	 * @$timestamp_beg 	integer		Timebegin of the Search in TIMESTAMP-Format
-	 * @$timestamp_end 	integer		Timeend of the Search in TIMESTAMP-Format
-	 * @$limit			integer		Limit of the whole Result of the Metadata Search
-	 * @$search_bbox	array		BoundingBox
-	 * @$search_epsg	string		EPSG like: "EPSG:4326"
-	 function logit($text){
-	 	if($h = fopen("/data/mapbender/http/tmp/gregor.txt","a")){
-					$content = $text .chr(13).chr(10);
-					if(!fwrite($h,$content)){
-						#exit;
-					fclose($h);
-	function __construct($user_id, $departments, $categories, $searchtext, $timestamp_beg, $timestamp_end, $limit, $search_bbox, $search_epsg){
-		$this->user_id = $user_id;
-		$this->departments = $departments;
-		$this->categories = $categories;
-		$this->searchtext = $searchtext;
-		$this->timestamp_beg = $timestamp_beg;
-		$this->timestamp_end = $timestamp_end;
-		$this->limit = $limit;
-		$this->search_bbox = $search_bbox;
-		$this->search_epsg = $search_epsg;
-		$this->availabilityTime = 60*60*24*90;	// sec*min*hour*days
-//		$e = new mb_notice("Search extended => user_id: ".$this->user_id."");
-//		$e = new mb_notice("Search extended => searchtext: ".$this->searchtext."");
-//		$e = new mb_notice("Search extended => timestamp_beg: ".$this->timestamp_beg."");
-//		$e = new mb_notice("Search extended => timestamp_end: ".$this->timestamp_end."");
-//		$e = new mb_notice("Search extended => limit: ".$this->limit."");
-//		$e = new mb_notice("Search extended => search_epsg: ".$this->search_epsg."");
-//		$e = new mb_notice("Search extended => count departments: ".count($this->departments)."");
-//		$e = new mb_notice("Search extended => count categories: ".count($this->categories)."");
-//		$e = new mb_notice("Search extended => count search_bbox: ".count($this->search_bbox)."");
-//		echo "Search extended => user_id: ".$this->user_id."<br>";
-//		echo "Search extended => searchtext: ".$this->searchtext."<br>";
-//		echo "Search extended => timestamp_beg: ".$this->timestamp_beg."<br>";
-//		echo "Search extended => timestamp_end: ".$this->timestamp_end."<br>";
-//		echo "Search extended => limit: ".$this->limit."<br>";
-//		echo "Search extended => search_epsg: ".$this->search_epsg."<br>";
-//		echo "Search extended => count search_bbox: ".count($this->search_bbox)."<br>";
-//		echo "Search extended => count departments: ".count($this->departments)."<br>";
-//		echo "Search extended => count categories: ".count($this->categories)."<br>";
-//		echo "Search extended => count departments: ".$this->departments[0]."<br>";
-//		echo "Search extended => count categories: ".$this->categories[0]."<br>";
-//		echo "Search extended => count search_bbox: ".$this->search_bbox[0]."<br>";
-		$this->logit("searchtext: ".$this->searchtext);
-		$this->logit("count categories: ".count($this->categories));
-		$this->logit("count departments: ".count($this->departments));
-		$this->logit("count search_bbox: ".count($this->search_bbox));
-		$cat_id="";
-		for ($index = 0; $index < sizeof($this->categories); $index++) {
-			$array_element = $this->categories[$index];
-			$cat_id .= $array_element.", ";
-		$this->isOverLimit;
-		$this->anz_wms=0;
-		$this->anz_wfs=0;
-		$cat = array();
-		$this->cat = $cat;
-		$this->user_authorization();
-		$this->set_categories();
-		$this->doc = new DOMDocument('1.0');
-		$this->generate_xml_output();
-	 * user authorization
-	function user_authorization(){
-		$n = new administration();
-		$this->n = $n;
-		$myguis = $this->n->getGuisByPermission($this->user_id,true);
-		$mywms = $this->n->getWmsByOwnGuis($myguis);
-		$myWFSconfs = $this->n->getWfsConfByPermission($this->user_id);
-		$this->myWFSConfs = $myWFSconfs;
-		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
-			$array_element = $this->myWFSConfs[$index];
-//			 echo $index."wfs_conf_id: ".$array_element."<br>";
-		$mylayer = array();
-		$this->mylayer = $mylayer;
-		if($mywms == false){
-			$mywms = array();
-	/* set categories as array */
-		function set_categories(){
-			$sql = "SELECT * FROM md_topic_category ";
-			$sql .= "ORDER BY md_topic_category_id";
-			$res = db_query($sql);
-			$this->cat[0] = array();
-			$this->cat[0]['md_topic_category_code_de'] = '';
-			$this->cat[0]['member'] = array();
-			$cnt = 1;
-			while($row = db_fetch_array($res)){
-				$this->cat[$cnt] = array();
-				$this->cat[$cnt]['md_topic_category_code_de'] = $row['md_topic_category_code_de'];
-				$this->cat[$cnt]['member'] = array();
-				$cnt++;
-//				echo " => ".$row['md_topic_category_code_de'];
-//				echo " => ".$row['md_topic_category_id']."<br>";
-			$cat_de="";
-			for ($index = 0; $index < sizeof($this->cat); $index++) {
-				$array_element = $this->cat[$index];
-				$cat_de .= "'".$this->cat[$index]['md_topic_category_code_de']."', ";
-//			$this->logit("set cat => count categories in [][]: ".count($this->cat));
-//			$this->logit("set cat => categories: ".$cat_de);
-	 * replace german letters (for example � => ae)
-	function replaceChars($text){
-	$search = array( "�",  "�",  "�",  "�",  "�",  "�",  "�");
-	$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
-	if(CHARSET=="UTF-8")
-		$text = utf8_decode($text);
-	$ret = str_replace($search, $repwith, $text);
-		$ret = utf8_encode($ret);
-	return $ret;
-	function replaceString($string , $replaceString, $newString){
-		$newstr = str_replace($string, $replaceString, $newString);
-		return $newstr;
-	function generate_xml_output(){
-		$this->writeXmlhead();
-		$this->writeXmlWMSPart();
-		$this->writeXmlWFSPart();
-		$this->writeXmlEnd();
-	function writeXmlhead(){
-		$this->doc->encoding = CHARSET;
-		$result = $this->doc->createElement("result");
-		$this->doc->appendChild($result);
-		//Trefferanzahl
-		$overLimit = $this->doc->createElement('overLimit');
-		$result->appendChild($overLimit);
-		$tr_text = $this->doc->createTextNode($this->isOverLimit);
-		$overLimit->appendChild($tr_text);
-		$rd = $this->doc->createElement("redirect");
-		$result->appendChild($rd);
-		$trd = $this->doc->createTextNode("muss noch...");
-		$rd->appendChild($trd);
-	function writeXmlEnd(){
-		$overLimitText = $this->doc->createTextNode($this->isOverLimit);
-		$overLimits = $this->doc->getElementsByTagName("overLimit");
-		foreach ($overLimits as $overLimit) {
-			$overLimit->appendChild($overLimitText);
-		$ready = $this->doc->createElement('ready');
-		$tready = $this->doc->createTextNode("true");
-		$ready->appendChild($tready);
-		$results = $this->doc->getElementsByTagName("result");
-				foreach ($results as $result) {
-				$result->appendChild($ready);
-		echo $this->doc->saveXML();	// Ausgabe
-		$e = new mb_notice("Wrote the XML-File");
-	 * generats categories with members in the xml-File
-	function writeXmlWMSPart(){
-		$asstr = array();
-		if ($this->searchtext!="false"){
-			$asstr = explode(" ",$this->searchtext);
-		$isTextSearch = "false";
-		for ($index = 0; $index < count($asstr); $index++) {
-			$array_element = $asstr[$index];
-			$e = new mb_notice("Search-Text: ".$index.".  ".$array_element."");
-		$v = array();
-		$t = array();
-		$sql = "SELECT DISTINCT * from service_metadata where ";
-		for($i=0; $i<count($asstr); $i++){
-			$isTextSearch = "true";
-			if($i>0){$sql .= " AND ";}
-			$sql .= "searchtext LIKE $".($i+1);
-			$va = "%".trim(strtoupper($this->replaceChars($asstr[$i])))."%";
-			array_push($v,$va);
-			array_push($t,"s");
-		$whereBedArray = array();
-		//layer_searchable condition
-		array_push($whereBedArray, "(layer_searchable = 1)");
-		//date condition
-		if ($this->timestamp_beg!="false" && $this->timestamp_end!="false"){
-			$time ="(wms_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
-			array_push($whereBedArray, $time);
-		} else if ($this->timestamp_beg!="false" && $this->timestamp_end=="false"){
-			$time ="(wms_timestamp > ".$this->timestamp_beg.")";
-		} else if ($this->timestamp_beg=="false" && $this->timestamp_end!="false"){
-			$time ="(wms_timestamp < ".$this->timestamp_end.")";
-		//department condition
-		if(count($this->departments)>0){
-			$txt = $this->getDepartmentBed("wms_owner", "mb_user_department", $this->departments, "OR");
-			$dep = " (". $txt . ") ";
-			array_push($whereBedArray, $dep);
-//		//Testausgabe
-//		for ($index = 0; $index < sizeof($this->whereBedArray); $index++) {
-//			$array_element = $this->whereBedArray[$index];
-//			echo $index." el: ".$array_element."<br>";
-		//Creating the Where Clausel, based on a Array
-		if(count($whereBedArray)>0){
-			$txt_whereBed="";
-			for ($index = 0; $index < sizeof($whereBedArray); $index++) {
-			$array_element = $whereBedArray[$index];
-				if($isTextSearch=="true") {
-					$txt_whereBed .=" AND ".$array_element;
-				} else {
-					if($index>0){
-					} else {
-						$txt_whereBed .=" ".$array_element;
-			$sql .= $txt_whereBed;
-		//order by
-		$sql .= " ORDER BY load_count DESC";
-		//Beschr�nkung
-		$lim = $this->limit;
-		$overLimit = $lim+1;
-		$sql .= " LIMIT ".$overLimit;
-		for ($index = 0; $index < sizeof($asstr); $index++) {
-			$this->logit($index.".Suchwort : ".$array_element);
-		$this->logit("SQL_WMS: ".$sql);
-		$e = new mb_notice("Search extended => SQL-Request of view service_metadata: ".$sql."");
-		$res = db_prep_query($sql, $v, $t);
-		//	spatial search
-//		for ($index = 0; $index < sizeof($this->cat); $index++) {
-//		$array_element = $this->cat[$index];
-//		$this->logit("0. vor Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
-		if(count($this->search_bbox)>0){
-		$anz = 0;
-			$resultColumns = array();
-			$resultColumns = $this->generateNewReaArray($res);
-			$e = new mb_notice("count service_metadata: ".count($resultColumns)."");
-			for ($index = 0; $index < count($resultColumns); $index++) {
-				$row = $resultColumns[$index];
-				if ($this->n->getLayerPermission($row['wms_id'], $row['layer_name'], $this->user_id)) {
-					array_push($this->mylayer,$row['layer_id']);
-				//accessconstraints -> email subadmin
-//				$sql_ac = "SELECT mb_user_email FROM mb_user WHERE mb_user_id = $1";
-//				$v = array($row["wms_owner"]);
-//				$t = array('i');
-//				$res_ac = db_prep_query($sql_ac, $v, $t);
-//				if($row_ac = db_fetch_array($res_ac)){
-//					$row["accessconstraints"] = $row_ac["mb_user_email"];
-				$ns = $this->make_members($row);
-				$anz++;
-			$e = new mb_notice("count service_metadata(spatial-search): ".$anz."");
-			$this->logit("ANZ_WMS mit bbox: ".$anz);
-		} else {
-		$anz = 0;
-//				if ($row_ac = db_fetch_array($res_ac)){
-				$anz++;
-		$e = new mb_notice("count service_metadata(no spatial-search): ".$anz."");
-		$this->logit("ANZ_WMS ohne bbox: ".$anz);
-//		$this->logit("1.nach Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
-		if ($this->limit < $anz ){
-			$this->isOverLimit="true";
-		} else {
-			$this->isOverLimit="false";
-		$ns = $this->make_xml();
-	 *  fills an array[][] with members based on categories
-	function make_members($r){
-//		$sql = "SELECT fkey_md_topic_category_id FROM layer_md_topic_category WHERE fkey_layer_id = $1";
-		$sql = "SELECT fkey_md_topic_category_id, md_topic_category_code_de, fkey_layer_id " .
-		"FROM layer_md_topic_category, md_topic_category " .
-		"WHERE layer_md_topic_category.fkey_md_topic_category_id = md_topic_category.md_topic_category_id " .
-		"AND fkey_layer_id = $1";
-		$sql .= " ORDER BY fkey_md_topic_category_id";
-		$v = array($r['layer_id']);
-		$t = array('i');
-		$c = 0;
-		//layer with category
-			if (count($this->categories)>0){
-				if (in_array($row['fkey_md_topic_category_id'], $this->categories) ){
-					$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
-			} else {
-//			$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
-//			$catID = $row['fkey_md_topic_category_id'];
-//			array_push($this->cat[$catID]['member'],$r);
-			$c++;
-		// no category for this layer
-		if($c == 0){
-			array_push($this->cat[0]['member'],$r);
-		return true;
-	 * generats the xml-document
-	function make_xml(){
-//		echo "Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member'])."<br>";
-	$i=0;
-	if (count($this->categories) == 0){		// Wenn eine Kategorieauswahl werde WMSe/Layer die keiner Kategorie zugeordnet sind nicht angezeigt
-		$i=0;
-	} else {
-		$i=1;
-	for($i; $i<count($this->cat); $i++){
-		if(count($this->cat[$i]['member'])>0){
-			$c = $this->doc->createElement("category");
-			$result->appendChild($c);
-			$c->setAttribute('name',$this->cat[$i]['md_topic_category_code_de']);
-			$c->setAttribute('count',count($this->cat[$i]['member']));
-			$this->logit("IM XML-Aufbau: category: ".$this->cat[$i]['md_topic_category_code_de'].", Anzahl: ".count($this->cat[$i]['member']));
-			for($ii=0; $ii<count($this->cat[$i]['member']); $ii++){
-// 					Schachtelung Start
-					$m = $this->doc->createElement('member');
-					$m->setAttribute('wms_id',$this->cat[$i]['member'][$ii]['wms_id']);			// Attribut muss gesetzt werden um es wieder zu finden
-					$m->setAttribute('layer_pos',$this->cat[$i]['member'][$ii]['layer_pos']);	// Attribut muss gesetzt werden um es wieder zu finden
-//					$m->setAttribute('layer_parent',$this->cat[$i]['member'][$ii]['layer_parent']);
-					if ($ii != 0){
-						$members = $c->getElementsByTagName('member');
-						$sub = "false";
-						$mem = null;
-						foreach ($members as $member) {
-							$tmp_wms_id = $member -> getAttribute('wms_id');
-							$tmp_layer_pos = $member -> getAttribute('layer_pos');
-						     * Wiederfinden des Members �ber die Attribute
-							if ($this->cat[$i]['member'][$ii]['wms_id'] == $tmp_wms_id){
-								if ($this->cat[$i]['member'][$ii]['layer_parent'] == $tmp_layer_pos){
-									$sub = "true";
-									$member->appendChild($m);	// dem member $member wird ein weiteres member $m hinzugef�gt
-									break;
-								} else {
-									$sub = "false";
-						if ($sub == "true"){
-										     // member konnte schon in der foreach-schleife eingefuegt werden
-						} else {
-						$c->appendChild($m); // member kategorie 1	(anderer WMS)
-					} else {
-						$c->appendChild($m);	 // member kategorie 1 (erstes member)
-// 				Schachtelung Ende
-				// LayerName
-				$state = $this->doc->createElement('layername');
-				$m->appendChild($state);
-				$name = "";
-				$layname = $this->cat[$i]['member'][$ii]['layer_name'];
-				if ($layname == "NULL" || $layname == "") {
-					$name = "";
-				} else {
-					$name = $layname;
-				$lay_name_text = $this->doc->createTextNode($name);
-				$state->appendChild($lay_name_text);
-				//Abfragbarkeit
-				$queryable = $this->doc->createElement('queryable');
-				$m->appendChild($queryable);
-				if ($this->cat[$i]['member'][$ii]['layer_queryable']==1){
-					$lay_queryable = "true";
-				} else {
-					$lay_queryable = "false";
-				$abf_text = $this->doc->createTextNode($lay_queryable);
-				$queryable->appendChild($abf_text);
-				// Epsg
-				$epsg = $this->doc->createElement('epsg');
-				$m->appendChild($epsg);
-				$equalEPSG = $this->checkEPSG($this->cat[$i]['member'][$ii]['wms_id']);
-				$epsg_text = $this->doc->createTextNode($equalEPSG);
-				$epsg->appendChild($epsg_text);
-				// L�nderkennung
-				$state = $this->doc->createElement('federalstate');
-				$spatialSource = "";
-				$stateorprovince = $this->cat[$i]['member'][$ii]['stateorprovince'];
-				if ($stateorprovince == "NULL" || $stateorprovince == "") {
-					$spatialSource = $this->cat[$i]['member'][$ii]['country'];
-				} else {
-					$spatialSource = $this->cat[$i]['member'][$ii]['stateorprovince'];
-				$countr_code_text = $this->doc->createTextNode($spatialSource);
-				$state->appendChild($countr_code_text);
-				// Satus des letzten Monitorings
-				$last_monitoring = $this->doc->createElement('last_monitoring');
-				$m->appendChild($last_monitoring);
-				$lastMonitoring = $this->getLastMonitoringDate($this->cat[$i]['member'][$ii]['wms_id']);
-				$last_monitoring_text = $this->doc->createTextNode($lastMonitoring);
-				$last_monitoring->appendChild($last_monitoring_text);
-				// Verf�gbarkeit - Prozentzahl
-				$availability = $this->doc->createElement('availability');
-				$m->appendChild($availability);
-				$availabilityPercent = $this->getWMSavailability($this->cat[$i]['member'][$ii]['wms_id'], $this->availabilityTime);
-				$availability_text = $this->doc->createTextNode($availabilityPercent);
-				$availability->appendChild($availability_text);
-				// Relevanz / Count
-				$relevance = $this->doc->createElement('relevance');
-				$m->appendChild($relevance);
-				$lay_count=0;
-				if($this->cat[$i]['member'][$ii]['load_count'] != null){
-				$lay_count=$this->cat[$i]['member'][$ii]['load_count'];
-				$relevance_text = $this->doc->createTextNode($lay_count);
-				$relevance->appendChild($relevance_text);
-				//type
-				$type = $this->doc->createElement('type');
-				$m->appendChild($type);
-				if($this->cat[$i]['member'][$ii]['layer_pos'] > 0){
-					$ttype = $this->doc->createTextNode("layer");
-				else{
-					$ttype = $this->doc->createTextNode("wms");
-				$type->appendChild($ttype);
-				//wms_id
-				$wms__id = $this->doc->createElement('wms_id');
-				$m->appendChild($wms__id);
-				$id_text = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['wms_id']);
-				$wms__id->appendChild($id_text);
-				//layer_id
-				$id = $this->doc->createElement('id');
-				$m->appendChild($id);
-				$tid = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_id']);
-				$id->appendChild($tid);
-				//title
-				$title = $this->doc->createElement('title');
-				$m->appendChild($title);
-				$ttitle = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_title']);
-				$title->appendChild($ttitle);
-				//abstract
-				$abst = $this->doc->createElement('abstract');
-				$m->appendChild($abst);
-				$tabst = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_abstract']);
-				$abst->appendChild($tabst);
-				// accesscontraints
-				$ac = $this->doc->createElement('accessconstraints');
-				$m->appendChild($ac);
-				$myac = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['accessconstraints']);
-				$ac->appendChild($myac);
-				//data
-				$date = $this->doc->createElement('date');
-				$m->appendChild($date);
-				$tdate = $this->doc->createTextNode(date("d.m.Y",$this->cat[$i]['member'][$ii]['wms_timestamp']));
-				$date->appendChild($tdate);
-				//department
-				$dm = $this->doc->createElement('department');
-				$m->appendChild($dm);
-				$tdm = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['mb_group_name']);
-				$dm->appendChild($tdm);
-				//permission // Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
-				$per = $this->doc->createElement('permission');
-				$m->appendChild($per);
-				$per_text = $this->getPermissionValue( $this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['layer_id']);
-				$pe =  $this->doc->createTextNode($per_text);
-				$per->appendChild($pe);
-				// termsofuse
-				$ter = $this->doc->createElement('termsofuse');
-				$m->appendChild($ter);
-				$myter_text = $this->getTermOfUse($this->cat[$i]['member'][$ii]['wms_id']);
-				$myter =  $this->doc->createTextNode($myter_text);
-				$ter->appendChild($myter);
-//				$this->logit("Ende member: ".$ii);
-//				echo "ende member: ".$ii."<br>";
-	function writeXmlWFSPart(){
-//		$asstr = split(" ",$this->searchtext);
-		$asstr = array();
-		$v = array();
-		$t = array();
-		$sql = "SELECT DISTINCT * from wfs_service_metadata where ";
-		$isTextSearch="false";
-		//textsearch
-			$isTextSearch="true";
-		//date condition
-			$time ="(wfs_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
-			$time ="(wfs_timestamp > ".$this->timestamp_beg.")";
-			$time ="(wfs_timestamp < ".$this->timestamp_end.")";
-				$txt = $this->getDepartmentBed("wfs_owner", "mb_user_department", $this->departments, "OR");
-		//featuretype_searchable condition
-			array_push($whereBedArray, "(featuretype_searchable = 1)");
-		// Creating the Where Clausel, based on a Array
-				$txt_whereBed="";
-					} else {
-						if($index>0){
-						} else {
-//				$txt_whereBed .=" AND ".$array_element;
-			//order by
-			$sql .= " ORDER BY featuretype_id ";
-//			echo "WFS-SQL:<br>".$sql."<br>";
-			$this->logit("WFS_SQL: ".$sql);
-				$c->setAttribute('name', "Geometriedienste");
-				$c->setAttribute('count', "0");
-			$i = 0;
-			$m->setAttribute('wfs_id', $row['wfs_id']);
-			$m->setAttribute('layer_pos', "");
-			//Abfragbarkeit
-			if ($row['featuretype_searchable'] == "1"){
-			} else {
-			$search_text = $this->doc->createTextNode($lay_queryable);
-			$queryable->appendChild($search_text);
-			// Epsg
-			$equalEPSG = $row['featuretype_srs'];
-			// L�nderkennung
-			$stateorprovince = $row['administrativearea'];
-				$spatialSource = $row['country'];
-			} else {
-				$spatialSource = $row['administrativearea'];
-			//type
-			$ttype = $this->doc->createTextNode("wfs");
-//			// FeaturetypeName
-//			$state = $this->doc->createElement('name');
-//			$m->appendChild($state);
-//			$name = "";
-//			$stateorprovince = $row['featuretype_name'];
-//			if ($stateorprovince == "NULL" || $stateorprovince == "") {
-////				$name = $row[''];
-//			} else {
-//				$name = $row['featuretype_name'];
-//			$countr_code_text = $this->doc->createTextNode($name);
-//			$state->appendChild($countr_code_text);
-			//id
-			$id = $this->doc->createElement('featuretype_id');
-			$tid = $this->doc->createTextNode($row['featuretype_id']);
-			//wfs_conf_id
-			$conf_id = $this->doc->createElement('wfs_conf_id');
-			$m->appendChild($conf_id);
-			$c_id = $this->doc->createTextNode($row['wfs_conf_id']);
-			$conf_id->appendChild($c_id);
-			//title
-			$ttitle = $this->doc->createTextNode($row['wfs_conf_abstract']);
-			//title
-			//abstract
-			$tabst = $this->doc->createTextNode($row['wfs_conf_description']);
-			// Geomtype
-			$geo = $this->doc->createElement('geomtype');
-			$m->appendChild($geo);
-			$geo_text = $this->getGeoType($row['wfs_id'], $row['featuretype_id']);
-			$ge =  $this->doc->createTextNode($geo_text);
-			$geo->appendChild($ge);
-//				$myac = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
-			$myac = $this->doc->createTextNode($row['accessconstraints']);
-			//data
-			$tdate = $this->doc->createTextNode(date("d.m.Y",$row['wfs_timestamp']));
-			//department
-			$tdm = $this->doc->createTextNode($row['mb_group_name']);
-			//permission  		 Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
-			$per_text = $this->getPermissionValueForWFS($row['wfs_id'], $row['wfs_conf_id']);
-//			// termsofuse
-//			$ter = $this->doc->createElement('termsofuse');
-//			$m->appendChild($ter);
-////			$myter = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
-//			$myter_text = "";
-//			$myter =  $this->doc->createTextNode($myter_text);
-//			$ter->appendChild($myter);
-			$i++;
-		$c->setAttribute('count', $i);
-		$this->anz_wfs = $i;
-	function getLastMonitoringDate($wms_id){
-	$sql = "SELECT max(upload_id) as last_time, status FROM mb_monitor WHERE fkey_wms_id=$1 GROUP BY (status)";
-	$v = array($wms_id);
-	$t = array('i');
-	$c = 0;
-	$status = "";
-		$status = $row['status'];
-		$c++;
-		return $status;
-	 * Returns the availability of a WMS/Layer during a period of time
-	 * in percent
-	function getWMSavailability ($wms_id, $time_period){
-		$timestamp = time();
-		$datum = date("d.m.Y - H:i", $timestamp);
-		$last_timestamp = $timestamp - $time_period;
-		$last_date = date("d.m.Y - H:i", $last_timestamp);
-//		Vorr�bergehend auskommentiert da keine aktuellen (auf Timestamp basierten) Daten vorliegen
-//		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1 AND upload_id > ".$last_timestamp;
-		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1";
-		$t = array('i');
-		$c = 0;
-		$positivStatus=0;
-			if ($row['status'] == "1" || $row['status'] == "0"){
-				$positivStatus++;
-			$c++;
-		$percent=0;
-		if ($c!=0){
-			$percent = ($positivStatus*100) / $c;
-		} else {
-			$percent = 0;
-		return number_format($percent,0, ",", ".") ;
-	function checkEPSG ($wms_id){
-	$sql = "SELECT wms.wms_id, wms_srs.wms_srs FROM wms, wms_srs where wms.wms_id=fkey_wms_id and wms.wms_id=$1";
-	$t = array('i');
-	$c = 0;
-	$isequal = "false";
-		$wms_epsg = $row['wms_srs.wms_srs'];
-		$c++;
-		if ($wms_epsg==$this->epsg){
-			$isequal="true";
-		return $isequal;
-	function isPermissioned() {
-	function getPermissionValue($wms_id, $lay_id){
-		$return_permission="";
-		// get permission
-		if (in_array($lay_id, $this->mylayer)){
-			$return_permission = "true";
-		} else {
-			$sql = "SELECT wms.wms_id, mb_user.mb_user_email as email FROM wms, mb_user where wms.wms_owner=mb_user.mb_user_id " .
-						"and wms.wms_id=$1";
-			$t = array('i');
-			// get email
-			$mail="";
-			$mail = $row['email'];
-			$return_permission = $mail;
-		return $return_permission;
-	function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
-	// get permission
-	if (in_array($wfs_conf_id, $this->myWFSConfs)){
-	} else {
-		$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id " .
-					"and wfs.wfs_id=$1";
-		$v = array($wfs_id);
-		$t = array('i');
-		// get email
-		$mail="";
-	function getTermOfUse($wms_id){
-		$return_tou_id="";
-		$sql = "SELECT wms.wms_id, wms_termsofuse.fkey_wms_id, wms_termsofuse.fkey_termsofuse_id, termsofuse.termsofuse_id as tid " .
-				"FROM wms, wms_termsofuse, termsofuse " .
-				"where wms.wms_id=wms_termsofuse.fkey_wms_id " .
-				"and wms_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id " .
-		$t = array('i');
-		// get termsofuse_id
-		$termsofuse_id="";
-		$termsofuse_id = $row['tid'];
-//		$return_tou_id = "mapbender/php/mod_termsofuse_service.php?id=".$termsofuse_id;
-		$return_tou_id = $termsofuse_id;
-		return $return_tou_id;
-	function generateNewReaArray($result){
-		global $con;
-//		echo "func generateNewReaArray<br>";
-//		$this->search_bbox;
-//		$this->search_epsg;
-		$delColumns = array();
-		$columnsResult = array();
-		$db_epsg="";
-		$db_minx="";
-		$db_miny="";
-		$db_maxx="";
-		$db_maxy="";
-		$isIntersecting = "";
-		$anz = 0;
-		while($row = db_fetch_array($result)){
-			$status="";
-//			echo $anz.". layer_id: ".$row['layer_id'];
-			//EPSG Vergleich
-			$sql_ac = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1";
-			$v = array($row["layer_id"]);
-			$t = array('i');
-			$res_ac = db_prep_query($sql_ac, $v, $t);
-			$tra_epsg="";
-			$tra_minx="";
-			$tra_miny="";
-			$tra_maxx="";
-			$tra_maxy="";
-			$i=0;
-			while($row_ac = db_fetch_array($res_ac)){
-				if ($row_ac["epsg"]=="EPSG:4326"){ // maybe for transformation needed
-					$db_epsg=$row_ac["epsg"];
-					$db_minx=$row_ac["minx"];
-					$db_miny=$row_ac["miny"];
-					$db_maxx=$row_ac["maxx"];
-					$db_maxy=$row_ac["maxy"];
-				if ($row_ac["epsg"]==$this->search_epsg){
-//				if ($row_ac["epsg"]=="EPSG:31467"){
-					$status="match";
-					break;
-				} else {
-				$i++;
-			if ($status=="match"){
-//					echo "match<br>";
-					$temp = $this->search_bbox;
-					$isIntersecting = $this->intersect($temp[0], $temp[1], $temp[2], $temp[3], $db_minx, $db_miny, $db_maxx, $db_maxy, $this->search_epsg);
-			} else if ($status != "match" && $i>0){
-//					echo "Transformation<br>";
-//					Transformation
-					$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as minx";
-					$resMinx = @pg_query($con,$sqlMinx);
-					$s_minx = pg_result($resMinx,0,"minx");
-					$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as miny";
-					$resMiny = @pg_query($con,$sqlMiny);
-					$s_miny = pg_result($resMiny,0,"miny");
-					$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxx";
-					$resMaxx = @pg_query($con,$sqlMaxx);
-					$s_maxx = pg_result($resMaxx,0,"maxx");
-					$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxy";
-					$resMaxy = @pg_query($con,$sqlMaxy);
-					$s_maxy = pg_result($resMaxy,0,"maxy");
-					$isIntersecting = $this->intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, "EPSG:4326");
-			} else {
-//					"no intersection possible()<br>";
-					$isIntersecting="f";
-			if ($isIntersecting=="t"){
-//				Datensatz loeschen
-				array_push($columnsResult, $row);
-			$anz++;
-		return $columnsResult;
-	function intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, $epsg){
-		global $con;
-		 * @security_patch sqli done
-                $s_minx = floatval($s_minx);
-                $s_miny = floatval($s_miny);
-                $s_maxx = floatval($s_maxx);
-                $s_maxy = floatval($s_maxy);
-                $db_minx = floatval($db_minx);
-                $db_miny = floatval($db_miny);
-                $db_maxx = floatval($db_maxx);
-                $db_maxy = floatval($db_maxy);
-                $epsg = pg_escape_string($epsg);
-                $result="";
-		$sqlint = "SELECT intersects(envelope(geometryFROMtext('LINESTRING(".$s_minx." ".$s_miny.", ".$s_maxx." ".$s_maxy.")',".str_replace("EPSG:","",$epsg).")) " .
-								   ",envelope(geometryFROMtext('LINESTRING(".$db_minx." ".$db_miny.", ".$db_maxx." ".$db_maxy.")',".str_replace("EPSG:","",$epsg).")))";
-		$resInt = @pg_query($con,$sqlint);
-		$result = pg_result($resInt,0,"intersects");
-		return $result;
-	 * Checks whether the keyword exist in the table keywords
-	 * @todo is UPPER() working with mysql
-	 * @param string the keyword
-	 * @return integer the ID of the keyword
-	function exists($keyword){
-		global $con;
-		$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
-		$v = array($keyword);
-		$t = array('s');
-		$res = db_prep_query($sql,$v,$t);
-		if($row = db_fetch_array($res)){
-			return $row['keyword_id'];
-		else{
-			return false;
-	function getSQLBedfromArray($culumnName, $columnValues, $additionalChar){
-		$a = array();
-		$a = $columnValues;
-		$a_char = $additionalChar;
-		$colName=$culumnName;
-		$resultSql="";
-		for ($index = 0; $index < sizeof($a); $index++) {
-			$array_element = $a[$index];
-			if ($index<1){
-				$resultSql .= $colName."='".$a[$index]."'";
-			}else{
-				$resultSql .= " ".$a_char." " .$colName."='".$a[$index]."'";
-		return $resultSql;
-	function getDepartmentBed ($columnFkey, $culumnName, $columnValues, $additionalChar){
-		$a = array();
-		$resultSql = $columnFkey." in (SELECT mb_user_id FROM mb_user WHERE ";
-		for ($index = 0; $index < count($a); $index++) {
-			if ($index<1){
-			}else{
-		$resultSql .=")";
-	function getGeoType($wfs_id, $featureType_id){
-		$return_geoType="";
-		$sql = "SELECT element_type FROM wfs_element, wfs_featuretype " .
-				"where wfs_featuretype.featuretype_id=wfs_element.fkey_featuretype_id " .
-				"and element_name='the_geom'" .
-				"and wfs_featuretype.fkey_wfs_id = $1" .
-				"and wfs_element.fkey_featuretype_id=$2";
-		$v = array($wfs_id, $featureType_id);
-		$t = array('i', 'i');
-		// get element_type
-		$return_geoType = $row['element_type'];;
-		return $return_geoType;
Deleted: trunk/mapbender/http/classes/class_metadata_new.php~
--- trunk/mapbender/http/classes/class_metadata_new.php~	2018-08-09 12:56:03 UTC (rev 9938)
+++ trunk/mapbender/http/classes/class_metadata_new.php~	2018-08-09 13:05:30 UTC (rev 9939)
@@ -1,1644 +0,0 @@
-<?php
-#Script to call this class: http://www.geoportal.rlp.de/mapbender/php/mod_callMetadata.php
-#Class for getting results out of the mapbender service registry
-#Resulttypes: WMS, WMS-Layer, (WFS), WFS-Featurtyps, WFS-Conf, WMC, GeoRSS-Feeds, ...
-#Possible filters: registrating organizations, time, bbox (fully inside, intersects, fully outside), ISO Topic Categories, INSPIRE themes, INSPIRE: keywords, classification of data/service ... - maybe relevant for the german broker not for one instance, quality and actuality (maybe spatial and temporal), bbox, deegree of conformity with ir, access and use constraints, responsible parties - maybe one is enough? We must have a look at the INSPIRE Metadata IR
-#Metadata we need to fullfil the demands of INSPIRE:
-#1. INSPIRE conformity classification for WMS/WFS/WCS
-#2. Temporal Extents at WMS/WMS-Layer/WFS/WFS-Featuretype levels - for datasets if demanded - til now there is no demand defined in the guidance-paper for metadata ir
-#3. Classified access and use contraints - which classes? - Check IR Data Sharing and IR Metadata
-#4.
-#Every ressource which should be send to INSPIRE can be filtered - but is not neccessary for a standardized approach
-#Another problem is the ranking of the different ressources. The ranking should be homogeneus.
-#Till now we rank the using of WMS Layers when Caps are requested and when s.o. load one layer into the geoportal.
-#The same things have to be done for the wfs-conf, wmc and georssfeeds
-#The searching for metadata should be parallel done. We need different classes for doing the search. They should be requested by one central class (class_metadata.php).
-#Classes for filtering after the results have been send to the portal:
-#1. ISO Topic Categories
-#2. INSPIRE Themes
-#3. Access and use classification
-#4. departments which provides the ressources - we need the new concept for the administration of this departments - store the addresses in the group table and give the relation - originating group in table mb_user_mb_group
-#Cause we have a authorization layer, we need the id of the requesting user which is defined in the session. If no session is set, it should be the anonymous user of the portal.
-#We need a parameter for internationalization - it should be send with the search request! Some of the Classes can be provided with different languages.
-#WMC and GeoRSS-Feeds have no or a to complex authorization info - maybe we need to test if wmc consists of info which is fully or only partually available to the anonymous user.
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_json.php");
-//definition for the things which are common to all kind of metadata ressources
-class searchMetadata {
-	var $userId;
-	var $searchId;
-	var $searchText;
-	var $registratingDepartments;
-	var $isoCategories;
-	var $inspireThemes;
-	var $customCategories;
-	var $timeBegin;
-	var $timeEnd;
-	var $regTimeBegin;
-	var $regTimeEnd;
-	var $maxResults;
-	var $searchBbox;
-	var $searchTypeBbox;
-	var $accessRestrictions;
-	var $languageCode;
-	var $searchStartTime;
-	var $searchView;
-	var $searchURL;
-	var $searchEPSG;
-	var $searchResources;
-	var $searchPages;
-	var $outputFormat;
-	var $resultTarget;
-	var $tempFolder;
-	var $orderBy;
-	var $hostName;
-	function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy){
-		$this->userId = (integer)$userId;
-		$this->searchId = $searchId;
-		$this->searchText = $searchText;
-		$this->registratingDepartments = $registratingDepartments; //array with ids of the registrating groups in the mb database
-		$this->registratingDepartmentsArray = explode(",",$this->registratingDepartments);
-		$this->isoCategories = $isoCategories;
-		$this->inspireThemes = $inspireThemes;
-		$this->customCategories = $customCategories;
-		$this->timeBegin = $timeBegin;
-		$this->timeEnd = $timeEnd;
-		$this->regTimeBegin = $regTimeBegin;
-		$this->regTimeEnd = $regTimeEnd;
-		$this->maxResults = (integer)$maxResults;
-		$this->searchBbox = $searchBbox;
-		$this->searchTypeBbox = $searchTypeBbox;
-		$this->accessRestrictions = $accessRestrictions;
-		$this->languageCode = $languageCode;
-		$this->searchEPSG = $searchEPSG;
-		$this->searchResources = $searchResources;
-		$this->searchPages = $searchPages;
-		$this->outputFormat = $outputFormat;
-		$this->resultTarget = $resultTarget;
-		$this->searchURL = $searchURL;
-		$this->hostName = $hostName;
-		$this->orderBy = $orderBy;
-		//definitions for generating tagClouds
-		$this->maxObjects = 15;
-		$this->maxFontSize = 30;
-		$this->maxWeight = 0;
-		$this->scale = 'linear';
-		$this->minFontSize = 10;
-		$this->tempFolder = TMPDIR; //TODO define another path - maybe the one which is given in mapbender.conf
-		if ($this->outputFormat == 'json'){
-			$this->json = new Mapbender_JSON;
-		$this->accessableLayers = NULL;
-		//set a time to find time consumers
-		$this->searchStartTime = $this->microtime_float();
-		//Defining of the different database categories
-		$this->resourceClassifications = array();
-		$this->resourceClassifications[0]['title'] = "ISO 19115"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[0]['tablename'] = 'md_topic_category';
-		$this->resourceClassifications[0]['requestName'] = 'isoCategories';
-		$this->resourceClassifications[0]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[0]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[0]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[0]['relation_wms'] = 'layer_md_topic_category';
-		$this->resourceClassifications[0]['relation_wfs'] = 'featuretype_md_topic_category';
-		$this->resourceClassifications[0]['relation_wmc'] = 'wmc_md_topic_category';
-//TODO: define this in mapbender
-		$this->resourceClassifications[1]['title'] = "INSPIRE"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-		$this->resourceClassifications[1]['tablename'] = 'inspire_category';
-		$this->resourceClassifications[1]['requestName'] = 'inspireThemes';
-		$this->resourceClassifications[1]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[1]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[1]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[1]['relation_wms'] = 'layer_inspire_category';
-		$this->resourceClassifications[1]['relation_wfs'] = 'featuretype_inspire_category';
-		$this->resourceClassifications[1]['relation_wmc'] = 'wmc_inspire_category';
-		switch($this->languageCode){
-			case "de":
-				$this->resourceClassifications[2]['title'] = "Sonstige"; //TODO: define the translations somewhere? - This is done in call_metadata.php before. Maybe we can get them from there? - It will be shown in the rightside categories table
-			break;
-			case "en":
-				$this->resourceClassifications[2]['title'] = "Custom";
-			break;
-			case "fr":
-				$this->resourceClassifications[2]['title'] = "Personnaliser";
-			break;
-			default:
-			break;
-		$this->resourceClassifications[2]['tablename'] = 'custom_category';
-		$this->resourceClassifications[2]['requestName'] = 'customCategories';
-		$this->resourceClassifications[2]['id_wms'] = 'layer_id';
-		$this->resourceClassifications[2]['id_wfs'] = 'featuretype_id';
-		$this->resourceClassifications[2]['id_wmc'] = 'wmc_serial_id';
-		$this->resourceClassifications[2]['relation_wms'] = 'layer_custom_category';
-		$this->resourceClassifications[2]['relation_wfs'] = 'featuretype_custom_category';
-		$this->resourceClassifications[2]['relation_wmc'] = 'wmc_custom_category';
-		//Defining of the different result categories
-		$this->resourceCategories = array();
-		$this->resourceCategories[0]['name'] = 'WMS';
-		$this->resourceCategories[1]['name'] = 'WFS';
-		$this->resourceCategories[2]['name'] = 'WMC';
-		$this->resourceCategories[3]['name'] = 'DAD';
-        		case 'de':
-                	$this->resourceCategories[0]['name2show'] = 'Darstellungsdienste';
-			$this->resourceCategories[1]['name2show'] = 'Such- und Download- und Erfassungsmodule';
-			$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
-			$this->resourceCategories[3]['name2show'] = 'KML/Newsfeeds';
-			$this->keywordTitle = 'Schlagwortliste';
-       			break;
-        		case 'en':
-               		$this->resourceCategories[0]['name2show'] = 'Viewingservices';
-			$this->resourceCategories[1]['name2show'] = 'Search- and Downloadservices';
-			$this->resourceCategories[2]['name2show'] = 'Combined Maps';
-			$this->keywordTitle = 'Keywordlist';
-        		break;
-        		case 'fr':
-          	     	$this->resourceCategories[0]['name2show'] = 'Services de visualisation';
-			$this->resourceCategories[1]['name2show'] = 'Services de recherche et de téléchargement';
-			$this->resourceCategories[2]['name2show'] = 'Cartes composées';
-       			break;
-     			default:
-		//not needed til now - maybe usefull for georss output
-		if ($this->outputFormat == "xml") {
-			//Initialize XML documents
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wms") {
-				$this->wmsDoc = new DOMDocument('1.0');
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wfs") {
-				$this->wfsDoc = new DOMDocument('1.0');
-				$this->generateWFSMetadata($this->wfsDoc);
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "wmc") {
-				$this->wmcDoc = new DOMDocument('1.0');
-				$this->generateWMCMetadata($this->wmcDoc);
-			if (isset($this->searchResources) & strtolower($this->searchResources) === "georss") {
-				$this->georssDoc = new DOMDocument('1.0');
-		if ($this->outputFormat === "json") {
-			$this->e = new mb_notice("orderBy old: ".$this->orderBy);
-				$this->databaseIdColumnName = 'featuretype_id';
-				$this->databaseTableName = 'wfs_featuretype';
-				//$this->keywordRelation = 'wfs_featuretype_keyword';
-				$this->searchView = 'search_wfs_view';
-				$this->whereStrCatExtension = " AND custom_category.custom_category_hidden = 0";
-				switch ($this->orderBy) {
-					case "rank":
-						$this->orderBy = " ORDER BY wfs_id,featuretype_id,wfs_conf_id ";
-						break;
-					case "id":
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY featuretype_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wfs_timestamp DESC ";
-						break;
-					default:
-				$this->resourceClasses = NULL;
-				$this->databaseIdColumnName = 'layer_id';
-				$this->databaseTableName = 'layer';
-				//$this->keywordRelation = 'layer_keyword';
-				$this->searchView = 'wms_search_table';
-				//$this->searchView = 'wms_search_view';
-					case "rank":
-						$this->orderBy = " ORDER BY load_count DESC";
-						break;
-					case "id":
-						$this->orderBy = " ORDER BY wms_id,layer_pos ASC";
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY layer_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wms_timestamp DESC ";
-						break;
-					default:
-				$this->resourceClasses = array(0,1,2);
-				$this->generateWMSMetadata($this->wmsDoc);
-				$this->searchView = 'search_wmc_view';
-				$this->databaseIdColumnName = 'wmc_serial_id';
-				$this->databaseTableName = 'wmc';
-				//the following is needed to give a special filter to the custom cat table!
-					case "rank":
-						$this->orderBy = " ORDER BY load_count DESC ";
-						break;
-					case "id":
-						$this->orderBy = " ORDER BY wmc_id";
-						break;
-					case "title":
-						$this->orderBy = " ORDER BY wmc_title ";
-						break;
-					case "date":
-						$this->orderBy = " ORDER BY wmc_timestamp DESC ";
-						break;
-					default:
-				$this->resourceClasses = array(0,1,2); #TODO adopt to count classifications
-				#$this->resourceClasses = array();
-	$this->e = new mb_notice("orderBy new: ".$this->orderBy);
-	private function microtime_float() {
-    		list($usec, $sec) = explode(" ", microtime());
-    		return ((float)$usec + (float)$sec);
-	private function generateXMLHead($xmlDoc) {
-		$xmlDoc->encoding = CHARSET;
-		$result = $xmlDoc->createElement("result");
-		$xmlDoc->appendChild($result);
-		//Result Count
-		$overLimit = $xmlDoc->createElement("overLimit");
-		//$tr_text = $xmlDoc->createTextNode($this->isOverLimit);
-		$tr_text = $xmlDoc->createTextNode("really?");
-		$rd = $xmlDoc->createElement("redirect");
-		$trd = $xmlDoc->createTextNode("not yet ready...");
-	private function generateXMLFoot($xmlDoc){
-		$results = $xmlDoc->getElementsByTagName("result");
-	private function flipDiagonally($arr) {
-    		$out = array();
-    		foreach ($arr as $key => $subarr) {
-      			foreach ($subarr as $subkey => $subvalue) {
-        			$out[$subkey][$key] = $subvalue;
-   		return $out;
-	private function generateWFSMetadataJSON($res, $n) {
-		//initialize object
-		$this->wfsJSON = new stdClass;
-		$this->wfsJSON->wfs = (object) array(
-				'md' => (object) array(
-					'nresults' => $n,
-					'p' => $this->searchPages,
-					'rpp' => $this->maxResults
-				'srv' => array()
-		//read out records
-		$serverCount = 0;
-		$wfsMatrix = db_fetch_all($res);
-		//sort result for accessing the right services
-		$wfsMatrix = $this->flipDiagonally($wfsMatrix);
-		//TODO check if order by db or order by php is faster!
-		#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
-		#print_r($wfsMatrix);
-		//read out first server entry - maybe this a little bit timeconsuming TODO
-		$j = 0; //count identical wfs_id => double featuretype
-		$l = 0; //index featuretype and or modul per wfs
-		$m = 0; //index modul per featuretype
-		for($i=0; $i<count($wfsMatrix);$i++){
-				$this->wfsJSON->wfs->srv[$i-$j]->id = $wfsMatrix[$i]['wfs_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->title = $wfsMatrix[$i]['wfs_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->abstract = $wfsMatrix[$i]['wfs_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->date = date("d.m.Y",$wfsMatrix[$i]['wfs_timestamp']);
-				$this->wfsJSON->wfs->srv[$i-$j]->respOrg = $wfsMatrix[$i]['mb_group_name'];
-				$this->wfsJSON->wfs->srv[$i-$j]->logoUrl = $wfsMatrix[$i]['mb_group_logo_path'];
-				$this->wfsJSON->wfs->srv[$i-$j]->mdLink = "http://".$this->hostName."/mapbender/geoportal/showWFSMetadata.php?id=".$wfsMatrix[$i]['wfs_id'];
-				$stateOrProvince = $wfsMatrix[$i]['administrativearea'];
-				if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
-					$spatialSource = $wfsMatrix[$i]['country'];
-				} else {
-					$spatialSource = $wfsMatrix[$i]['administrativearea'];
-				$this->wfsJSON->wfs->srv[$i-$j]->iso3166 = $spatialSource;
-				//check if a disclaimer has to be shown and give the relevant symbol
-				//$this->wfsJSON->wfs->srv[$i-$j]->tou = $wfsMatrix[$i]['termsofuse'];
-				list($hasConstraints, $symbolLink) = $this->hasConstraints("wfs", $wfsMatrix[$i]['wfs_id']);
-				$this->wfsJSON->wfs->srv[$i-$j]->hasConstraints = $hasConstraints;
-				$this->wfsJSON->wfs->srv[$i-$j]->symbolLink = $symbolLink;
-				//TODO check the field accessconstraints - which should be presented?
-				$this->wfsJSON->wfs->srv[$i-$j]->status = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->avail = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->logged = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->price = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->nwaccess = NULL; //$wfsMatrix[$i][''];
-				$this->wfsJSON->wfs->srv[$i-$j]->bbox = array(-180.0,-90.0,180.0,90.0); //$wfsMatrix[$i][''];
-				//if featuretype hasn't been created - do it
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype = array();
-				//fill in featuretype infos
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->id = (integer)$wfsMatrix[$i]['featuretype_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->title = $wfsMatrix[$i]['featuretype_title'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->abstract = $wfsMatrix[$i]['featuretype_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->mdLink = "http://".$this->hostName."/mapbender/geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->bbox = array(-180.0,-90.0,180.0,90.0);//TODO: $wfsMatrix[$i]['bbox'];
-				//give info for inspire categories - not relevant for other services or instances of mapbender TODO: comment it if the mapbender installation is not used to generate inspire output
-				if (isset($wfsMatrix[$i]['md_inspire_cats']) & ($wfsMatrix[$i]['md_inspire_cats'] != '')){
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->inspire = 1;
-				else {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->inspire = 0;
-				//fill in categories
-				#if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat)) {
-				#	$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat = array();
-				#if (isset($wfsMatrix[$i]['iso_categories'])) {
-				//if (isset($wfsMatrix[$i]['inspire_category'])) {
-					//TODO write the categories as JSON into Database!
-					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->type = 'INSPIRE Kategorie';
- 					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->value = 'Umwelt';
-					#$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->cat[0]->symbol = 'umwelt.png';
-				#if (isset($wfsMatrix[$i]['custom_categories'])) {
-				//if modul hasn't been created - do it
-				if (!isset($this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul)) {
-					$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul = array();
-				//fill in modul infos
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->id = $wfsMatrix[$i]['wfs_conf_id'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->title = $wfsMatrix[$i]['wfs_conf_description'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->abstract = $wfsMatrix[$i]['wfs_conf_abstract'];
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->type = $wfsMatrix[$i]['modultype'];
-				$equalEPSG = $wfsMatrix[$i]['featuretype_srs'];
-                       		$isEqual = true;
-				//control if EPSG is supported by Client
-		        	if ($equalEPSG == $this->searchEPSG){
-					$isEqual = false;
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->srsProblem = $isEqual;
-				//generate Link to show metadata
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?resource=featuretype&id=".$wfsMatrix[$i]['featuretype_id'];
-				$perText = $this->getPermissionValueForWFS($wfsMatrix[$i]['wfs_id'], $wfsMatrix[$i]['wfs_conf_id']);
-				$this->wfsJSON->wfs->srv[$i-$j]->ftype[$l-$m]->modul[$m]->permission = $perText;
-				if ($wfsMatrix[$i]['wfs_id'] == $wfsMatrix[$i+1]['wfs_id']){
-					$j++; //next record is the same service
-					$l++;
-				else
-					$l = 0;
-				if ($wfsMatrix[$i]['featuretype_id'] == $wfsMatrix[$i+1]['featuretype_id']){
-					$m++;
-				else
-					$m = 0;
-	private function generateWMCMetadataJSON($res, $n) {
-		$this->wmcJSON = new stdClass;
-		$this->wmcJSON->wmc = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$wmcMatrix = db_fetch_all($res);
-		$wmcMatrix = $this->flipDiagonally($wmcMatrix);
-		for($i=0; $i<count($wmcMatrix);$i++){
-			$this->wmcJSON->wmc->srv[$i]->id = $wmcMatrix[$i]['wmc_id'];
-			$this->wmcJSON->wmc->srv[$i]->title = $wmcMatrix[$i]['wmc_title'];
-			$this->wmcJSON->wmc->srv[$i]->abstract = $wmcMatrix[$i]['abstract'];
-			$this->wmcJSON->wmc->srv[$i]->date = date("d.m.Y",$wmcMatrix[$i]['wmc_timestamp']);
-			$this->wmcJSON->wmc->srv[$i]->respOrg = $wmcMatrix[$i]['mb_group_name'];
-			$this->wmcJSON->wmc->srv[$i]->logoUrl = $wmcMatrix[$i]['mb_group_logo_path'];
-			$this->wmcJSON->wmc->srv[$i]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=wmc&layout=tabs&id=".$wmcMatrix[$i]['wmc_id'];
-			$this->wmcJSON->wmc->srv[$i]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=wmc&id=".$wmcMatrix[$i]['wmc_id'];
-			$stateOrProvince = $wmcMatrix[$i]['mb_group_stateorprovince'];
-				$spatialSource = $wmcMatrix[$i]['mb_group_country'];
-			} else {
-				$spatialSource = $wmcMatrix[$i]['mb_group_stateorprovince'];
-			$this->wmcJSON->wmc->srv[$i-$j]->iso3166 = $spatialSource;
-			$this->wmcJSON->wmc->srv[$i-$j]->bbox = array($wmcMatrix[$i]['bbox']); //TODO: read out bbox from wmc $wmcMatrix[$i][''];
-			#$equalEPSG = $wmcMatrix[$i]['srs'];
-                       	#$isEqual = true;
-		        #if ($equalEPSG == $this->searchEPSG){
-			#	$isEqual = false;
-	private function generateWMSMetadataJSON($res, $n) {
-		$this->wmsJSON = new stdClass;
-		$this->wmsJSON->wms = (object) array(
-					'nresults' => $n,
-				'srv' => array()
-		$serverCount = 0;
-		$wmsMatrix = db_fetch_all($res);
-		$layerIdArray = array();
-		//read out array with unique wms_ids in wmsMatrix
-		$wmsIdArray = array();
-		//initialize root layer id;
-		$rootLayerId = -1;
-		$j = 0;
-		//get array with all available layer_id for this user:
- 		$admin = new administration();
-		$this->accessableLayers = $admin->getLayersByPermission($this->userId);
-		#echo "<br>user_id: ".$this->userId."<br><br>";
-		#var_dump($this->accessableLayers);
-		#echo "<br>";
-		#$countWmsMatrix = count($wmsMatrix);
-		#echo $countWmsMatrix;
-		if ($n != 0) {
-		for($i=0; $i<count($wmsMatrix);$i++){
-			$layerID = $wmsMatrix[$i]['layer_id'];
-			#echo "<br>LayerID: ".$layerID."<br>";
-			#$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-			if (!in_array($layerID, $layerIdArray) or !in_array($rootLayerId, $layerIdArray)) {
-				$wmsID = $wmsMatrix[$i]['wms_id']; //get first wms id - in the next loop - dont get second, but some else!
-				//Select all layers of with this wms_id into new array per WMS - the grouping should be done by wms!
-				$subLayers = $this->filter_by_value($wmsMatrix, 'wms_id', $wmsID);
-				#echo "<br>wms_id: ".$wmsID."<br>";
-				#echo "<br>Number of sublayers: <br>";
-				#print(count($subLayers));
-				//Sort array by load_count - problem: maybe there are some groups between where count is to low (they have no load count because you cannot load them by name)? - Therefor we need some ideas - or pull them out of the database and show them greyed out. Another way will be to define a new group (or wms with the same id) for those layers which are more than one integer away from their parents
-				$subLayersFlip = $this->flipDiagonally($subLayers);
-				#var_dump($subLayers['layer_pos']);
-				#$subLayers = $this->flipDiagonally($subLayers);
-				//go backwards through the layerTree to get the layer with the highest position without gaps in between
-				#var_dump($subLayers['layer_id']);
-				#echo "<br>";
-				$index = array_search($layerID, $subLayersFlip['layer_id']);
-				#echo "<br>found layer_id= ".$layerID." at index: ".$index." in sublayerstable layer_pos=".$subLayers[$index]['layer_pos']." <br>";
-				#echo "<br>sublayers: ";
-				#var_dump($subLayersFlip);
-				#echo "<br>";
-				$rootIndex = $this->getLayerParent($subLayersFlip, $index);
-				$rootLayerPos = $subLayers[$rootIndex]['layer_pos'];
-				$rootLayerId = $subLayers[$rootIndex]['layer_id'];
-				#echo "<br>root layer for this layer: <br>";
-				#echo "<br>id= "..""
-				#echo "<br>";
-				#echo "<br>LayerId:<br>";
-				#echo "<br>".$layerID."<br>";
-				#echo "<br>rootLayerPos:<br>";
-				#echo "<br>".$rootLayerPos."<br>";
-				#echo "<br>rootLayerId:<br>";
-				#echo "<br>".$rootLayerId."<br>";
-				//push root layer id in array
-				array_push($layerIdArray, $rootLayerId);
-				#echo "<br>root Layer ID: ".$rootLayerId."<br>";
-				#array_multisort($subLayers['layer_pos'], SORT_ASC);
-				#print_r($subLayers);
-				#print_r("<br>rootIndex: ".$rootIndex."<br>");
-				//Create object for wms service level
-				$this->wmsJSON->wms->srv[$j]->id = (integer)$subLayers[$rootIndex]['wms_id'];
-				$this->wmsJSON->wms->srv[$j]->title = $subLayers[$rootIndex]['wms_title'];
-				$this->wmsJSON->wms->srv[$j]->abstract = $subLayers[$rootIndex]['wms_abstract'];
-				$this->wmsJSON->wms->srv[$j]->date = date("d.m.Y",$subLayers[$rootIndex]['wms_timestamp']);
-				#$this->wmsJSON->wms->srv[$j]->respOrg = "test";
-				$this->wmsJSON->wms->srv[$j]->loadCount = (integer)$subLayers[$rootIndex]['load_count'];
-				#$this->wmsJSON->wms->srv[$j]->mdLink = "http://".$_SERVER['HTTP_HOST']."/mapbender/geoportal/mod_layerMetadata.php?id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				$stateOrProvince = $subLayers[$rootIndex]['stateorprovince'];
-				#echo $stateOrProvince."<br>";
-					$spatialSource = $subLayers[$rootIndex]['country'];
-				} else {
-					$spatialSource = $subLayers[$rootIndex]['stateorprovince'];
-				$this->wmsJSON->wms->srv[$j]->iso3166 = $spatialSource;
-				$this->wmsJSON->wms->srv[$j]->respOrg = $subLayers[$rootIndex]['mb_group_name'];
-				$this->wmsJSON->wms->srv[$j]->logoUrl = $subLayers[$rootIndex]['mb_group_logo_path'];
-				#$this->wmsJSON->wms->srv[$j]->tou = $subLayers[$rootIndex]['termsofuse'];
-				list($hasConstraints, $symbolLink) = $this->hasConstraints("wms", $subLayers[$rootIndex]['wms_id']);
-				$this->wmsJSON->wms->srv[$j]->hasConstraints = $hasConstraints;
-				$this->wmsJSON->wms->srv[$j]->symbolLink = $symbolLink;
-				$this->wmsJSON->wms->srv[$j]->status = $subLayers[$rootIndex]['status']; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->avail = $subLayers[$rootIndex]['availability']; //$wmsMatrix[$i][''];
-				//get info about defined price
-				if ($subLayers[$rootIndex]['wms_pricevolume'] == '' OR $subLayers[$rootIndex]['wms_pricevolume'] == 0){
-					$this->wmsJSON->wms->srv[$j]->price = NULL;
-				else {
-					$this->wmsJSON->wms->srv[$j]->price = $subLayers[$rootIndex]['wms_pricevolume'];
-				//get info about logging of resource
-				if ($subLayers[$rootIndex]['wms_proxylog'] == NULL OR $subLayers[$rootIndex]['wms_proxylog'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->logged = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->logged = true;
-				//get info about network_accessability
-				if ($subLayers[$rootIndex]['wms_network_access'] == NULL OR $subLayers[$rootIndex]['wms_network_access'] == 0){
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = false;
-				else {
-					 $this->wmsJSON->wms->srv[$j]->nwaccess = true;
-				#$this->wmsJSON->wms->srv[$j]->logged = NULL; //$wmsMatrix[$i][''];
-				#$this->wmsJSON->wms->srv[$j]->price = NULL; //$wmsMatrix[$i][''];
-				#$this->wmsJSON->wms->srv[$j]->nwaccess = NULL; //$wmsMatrix[$i][''];
-				$this->wmsJSON->wms->srv[$j]->bbox = $subLayers[$rootIndex]['bbox']; //$wmsMatrix[$i][''];
-				//Call recursively the child elements, give and pull $layerIdArray to push the done elements in the array to avoid double results
-				//generate the layer-entry for the so called root layer - maybe this is only a group layer if there is a gap in the layer hierachy
-				$this->wmsJSON->wms->srv[$j]->layer = array();
-				$this->wmsJSON->wms->srv[$j]->layer[0]->id = (integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->title = $subLayers[$rootIndex]['layer_title'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->abstract = $subLayers[$rootIndex]['layer_abstract'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=layer&layout=tabs&id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=layer&id=".(integer)$subLayers[$rootIndex]['layer_id'];
-				if ($subLayers[$rootIndex]['layer_name'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->loadable = 1;
-				if ($subLayers[$rootIndex]['layer_pos'] == '0'){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = true;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->isRoot = false;
-				if ($subLayers[$rootIndex]['md_inspire_cats'] == ''){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 0;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->inspire = 1;
-				//get info about queryable or not
-				if ($subLayers[$rootIndex]['layer_queryable'] == 1){
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 1;
-				else {
-					$this->wmsJSON->wms->srv[$j]->layer[0]->queryable = 0;
-				#if ($subLayers[$rootIndex]['layer_name'] == ''){
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 0;
-				#else {
-				#	$this->wmsJSON->wms->srv[$i-$j]->layer[0]->loadable = 1;
-				$this->wmsJSON->wms->srv[$j]->layer[0]->loadCount = $subLayers[$rootIndex]['load_count'];
-				#$servObject->layer[$countsublayer]->mdLink = $_SERVER['HOST']."/mapbender/geoportal/showWFeatureTypeMetadata.php?id=".$wfsMatrix[$i]['featuretype_id'];
-				#$servObject->layer[$countsublayer]->geomtype = $wfsMatrix[$i]['element_type'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->bbox = $subLayers[$rootIndex]['bbox'];
-				$this->wmsJSON->wms->srv[$j]->layer[0]->permission = $this->getPermissionValueForLayer($subLayers[$rootIndex]['layer_id'], $subLayers[$rootIndex]['wms_id']); //TODO: Make this much more faster
-				//when the entry for the first server has been written, the server entry is fixed and the next one will be a new server or a part of the old one.
-				 //increment server (highest object id)
-				$layerIdArray = $this->writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, $this->wmsJSON->wms->srv[$j]->layer[0]);
-				$j++;
-				//generate php object - if root layer was found - > layer_parent='' give hint to visualize folder symbol.
-	private function generateWMSMetadata($xmlDoc) {
-		$starttime = $this->microtime_float();
-		list($sql, $v, $t, $n) = $this->generateSearchSQL();
-		//call database search in limits
-			//generate json
-			$this->generateWMSMetadataJSON($res,$n);
-			$usedTime = $this->microtime_float() - $starttime;
-			//put in the time to generate the data
-			$this->wmsJSON->wms->md->genTime = $usedTime;
-			$this->wmsJSON = $this->json->encode($this->wmsJSON);
-			if ($this->resultTarget == 'file') {
-				if($wmsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wmsFileHandle,$this->wmsJSON);
-					fclose($wmsFileHandle);
-			if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
-				echo $this->wmsJSON;
-		$usedTime2 = $this->microtime_float() - $starttime;
-		//echo "<br>used time: ".$usedTime."<br>";
-		$e = new mb_notice("Time to generate WMS-Metadata: ".$usedTime2);
-		$e = new mb_notice("Wrote the MD_WMS-File");
-	private function generateWFSMetadata($xmlDoc) {
-			//generate json
-			$this->generateWFSMetadataJSON($res, $n);
-			$this->wfsJSON->wfs->md->genTime = $usedTime;
-			$this->wfsJSON = $this->json->encode($this->wfsJSON);
-				if($wfsFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wfsFileHandle,$this->wfsJSON);
-					fclose($wfsFileHandle);
-			if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
-				echo $this->wfsJSON;
-		$e = new mb_notice("Time to generate WFS-Metadata: ".$usedTime);
-		$e = new mb_notice("Wrote the MD_WFS-File");
-	private function generateWMCMetadata($xmlDoc) {
-			//generate json
-			$this->generateWMCMetadataJSON($res,$n);
-			$this->wmcJSON->wmc->md->genTime = $usedTime;
-			$this->wmcJSON = $this->json->encode($this->wmcJSON);
-				if($wmcFileHandle = fopen($this->tempFolder."/".$this->searchId."_".$this->searchResources."_".$this->searchPages.".json","w")){
-					fwrite($wmcFileHandle,$this->wmcJSON);
-					fclose($wmcFileHandle);
-				echo $this->wmcJSON;
-		$e = new mb_notice("Time to generate WMC-Metadata: ".$usedTime2);
-		$e = new mb_notice("Wrote the MD_WMC-File");
-	private function replaceChars_all($text){
-		$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
-		$repWith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
-		$replaced = str_replace($search, $repWith, $text);
-		return $replaced;
-	private function generateSearchSQL() {
-		//elements needed to exist in mb wfs,wms,wmc view or table:
-		//1. textfield - all texts - searchText
-		//2. responsible organisations - given id
-		//3. bbox - is not explicit given in the wfs metadata? Since WFS 1.1.0 a latlonbbox is present
-		//4. isoTopicCategory - is not been saved til now
-		//5. ...
-		//parse searchText into different array elements to allow an AND search
-		$searchStringArray = $this->generateSearchStringArray();
-		$v = array();
-		$t = array();
-		$sql = "SELECT * from ".$this->searchView." where ";
-		#$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
-		$whereStr = "";
-		$whereCondArray = array();
-		$e = new mb_notice("Number of used searchstrings: ".count($searchStringArray));
-		//textsearch
-		if ($this->searchText != NULL) {
-			for($i=0; $i < count($searchStringArray); $i++){
-				if($i>0) {
-					$whereStr .= " AND ";
-				$whereStr .= "searchtext LIKE $".($i+1);
-				//output for debugging
-				$e = new mb_notice("Part of string".$i.": ".$searchStringArray[$i]);
-				$e = new mb_notice("converted: ".$this->replaceChars_all($searchStringArray[$i]));
-				$va = "%".trim(strtoupper($this->replaceChars_all($searchStringArray[$i])))."%";
-				$e = new mb_notice($this->searchResources." Searchtext in SQL: ".$va);
-		// This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
-		//check for postgis version
-		//sql for get version string
-		//get version number
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->searchBbox != NULL) {
-			//decide which type of search should be done
-			//check for postgis version cause postgis versions < 1.4 have problems when doing disjoint and inside
-			$sqlPostgisVersion = "SELECT postgis_version();";
-			$vPostgisVersion = array();
-			$tPostgisVersion = array();
-			$resPostgisVersion = db_prep_query($sqlPostgisVersion, $vPostgisVersion, $tPostgisVersion);
-			// get version string
-			while($row = db_fetch_array($resPostgisVersion)){
-				$postgisVersion = $row['postgis_version'];
-				$postgisVersionArray = explode(" ",$postgisVersion);
-				$postgisVersionSmall = explode(".",$postgisVersionArray[0]);
-				$postgisSubNumber = $postgisVersionSmall[1];
-				$e = new mb_notice("class_metadata.php: postgis sub number = ".$postgisSubNumber);
-			$e = new mb_notice("class_metadata.php: spatial operator: ".$this->searchTypeBbox);
-			if ((integer)$postgisSubNumber >= 3){
-				#$spatialFilter = "(the_geom ";
-				if ($this->searchTypeBbox == 'outside') {
-					$spatialFilter = ' disjoint(';
-				} elseif ($this->searchTypeBbox == 'inside') {
-					$spatialFilter = ' within(';
-				} else {
-					$spatialFilter = ' intersects(';
-				//define spatial filter
-				if(count(explode(',',$this->searchBbox)) == 4){   //if searchBbox has 4 entries
-					$spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
-					//definition of the spatial filter
-					$spatialFilter .= 'the_geom,GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
-					$spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
-					$spatialFilter .= $spatialFilterCoords[0];//minx
-					$spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
-					$spatialFilter .= $spatialFilterCoords[2];//maxx
-					$spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
-					$spatialFilter .= ")";
-					array_push($whereCondArray, $spatialFilter);
-			} else {
-				$spatialFilter = ' the_geom && ';
-					$spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
-					#$spatialFilter .= ",the_geom)";
-		//search filter for md_topic_categories
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->isoCategories != NULL) {
-			$isoArray = explode(',',$this->isoCategories);
-			$topicCond = "(";
-			for($i=0; $i < count($isoArray); $i++){
-				if ($i == 0) {
-					$topicCond .= "(md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-				} else {
-					$topicCond .= "AND (md_topic_cats LIKE '%{".$isoArray[$i]."}%') ";
-			$topicCond .= ")";
-			array_push($whereCondArray, $topicCond);
-		//search filter for inspire_categories
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->inspireThemes != NULL) {
-			$inspireArray = explode(',',$this->inspireThemes);
-			$inspireCond = "(";
-			for($i=0; $i < count($inspireArray); $i++){
-				if ($i == 0) {
-					$inspireCond .= "(md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
-				} else {
-					$inspireCond .= "AND (md_inspire_cats LIKE '%{".$inspireArray[$i]."}%') ";
-			$inspireCond .= ")";
-			array_push($whereCondArray, $inspireCond);
-		//search filter for custom_categories
-		if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->customCategories != NULL) {
-			$customArray = explode(',',$this->customCategories);
-			$customCond = "(";
-			for($i=0; $i < count($customArray); $i++){
-				if ($i == 0) {
-					$customCond .= "(md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
-				} else {
-					$customCond .= "AND (md_custom_cats LIKE '%{".$customArray[$i]."}%') ";
-			$customCond .= ")";
-			array_push($whereCondArray, $customCond);
-		//date condition
-		//if begin and end are set
-		//echo "<br> regTimeBegin: ".$this-> regTimeBegin." regTimeEnd: ".$this-> regTimeEnd."<br>";
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) BETWEEN '".$this->regTimeBegin."' AND '".$this->regTimeEnd."')";
-			array_push($whereCondArray, $time);
-			//only begin is set
-		if ($this->regTimeBegin != NULL && $this->regTimeEnd == NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) > '".$this->regTimeBegin."')";
-		if ($this->regTimeBegin == NULL && $this->regTimeEnd != NULL){
-			$time ="(TO_TIMESTAMP(".$this->searchResources."_timestamp) < '".$this->regTimeEnd."')";
-		//department condition
-		//TODO: generate filter for new sql check if at least some department is requested
-		//generate array
-		//$this->registratingDepartments = explode(',',$this->registratingDepartments);
-		#if(count($this->registratingDepartments) > 0 & $this->registratingDepartments){
-		if($this->registratingDepartments != NULL){
-			$dep = " department IN (".$this->registratingDepartments.") ";
-			array_push($whereCondArray, $dep);
-		// Creating the WHERE clause, based on a array
-		if(count($whereCondArray) > 0){
-			$txt_whereCond = "";
-			for ($index = 0; $index < sizeof($whereCondArray); $index++) {
-				$array_element = $whereCondArray[$index];
-				if($isTextSearch == "true") {
-					$txt_whereCond .= " AND ".$array_element;
-				} else {
-					if($index>0){
-					} else {
-						$txt_whereCond .= " ".$array_element;
-			$whereStr .= $txt_whereCond;
-		//Add WHERE condition to search
-		$sql .= $whereStr;
-		//TODO ORDER BY in SQL - not necessary for counting things:
-		$sql .= $this->orderBy;
-		//Calculate Paging for OFFSET and LIMIT values:
-		$offset = ((integer)$this->maxResults) * ((integer)$this->searchPages -1);
-		$limit = (integer)$this->maxResults;
-		//defining range for paging
-		$sql .= " LIMIT ".$limit." OFFSET ".$offset."";
-		//Print out search SQL term
-		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata: ".$sql."");
-		//parameter: searchId -> can be used global, searchResources -> is only one type per instance!!-> global,which categories -> can be defined global! $whereStr
-		$n = $this->writeCategories($whereStr, $v, $t);
-		//write counts to filesystem to avoid to many database connections
-		//only write them, if searchId is given - problem: searches with same searchId's maybe get wrong information
-		return array($sql, $v, $t, $n);
-/** Function to write a json file which includes the categories of the search result for each searchResource - wms/wfs/wmc/georss, new: it should also count the keyword distribution of the searchResource ans save it as a special json file!
-	private function writeCategories($whereStr, $v, $t) {
-		//generate count sql
-		//generate count of all entries
-		$sqlN = "SELECT count(".$this->searchResources."_id) from ".$this->searchView." where ";
-		$sqlN .= $whereStr;
-		//Get total number of results
-		$count = db_prep_query($sqlN, $v, $t);
-		$n = db_fetch_all($count);
-		#echo "<br>N: ".var_dump($n)."<br>";
-		$n = $n[0]['count'];
-		$e = new mb_notice("class_metadata.php: Search => SQL-Request of ".$this->searchResources." service metadata N: ".$sqlN." Number of found objects: ".$n);
-		if ($this->searchId != 'dummysearch') { //searchId is not the default id! - it has been explicitly defined
-			//check if cat file already exists:
-			//filename to search for:
-			$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_cat.json";
-			$keyFilename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_keywords.json";
-			if (!file_exists($filename)  or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
-				//open category file for results
-				$this->catJSON = new stdClass;
-				$this->catJSON->searchMD = (object) array(
-					'searchId' => $this->searchId,
-					'n' => $n
-				//new: also generate a json object for the keyword distribution
-				$this->keyJSON = new stdClass;
-				$this->keyJSON->tagCloud = (object) array(
-					'maxFontSize' => $this->maxFontSize,
-					'maxObjects' => $this->maxObjects,
-					'title' => $this->keywordTitle,
-					'tags' => array()
-				$this->inc = ($this->maxFontSize-$this->minFontSize)/$this->maxObjects;//maybe 10 or 5 or ...
-				//generate the list of category counts
-				$sqlCat = array();
-				//generate the sql for the keyword count
-				$sqlKeyword = "select keyword.keyword, COUNT(*) ";
-				$sqlKeyword .= "FROM (select ";
-				$sqlKeyword .= $this->databaseIdColumnName;
-				$sqlKeyword .= " FROM ".$this->searchView." WHERE ".$whereStr.") as a";
-				$sqlKeyword .= " INNER JOIN ".$this->databaseTableName."_keyword ON (";
-				$sqlKeyword .= $this->databaseTableName."_keyword.fkey_".$this->databaseIdColumnName." = a.";
-				$sqlKeyword .= $this->databaseIdColumnName.") ";
-				$sqlKeyword .= "INNER JOIN keyword ON (keyword.keyword_id=".$this->databaseTableName."_keyword.fkey_keyword_id) WHERE (keyword.keyword NOTNULL AND keyword.keyword <> '')";
-				$sqlKeyword .= "GROUP BY keyword.keyword  ORDER BY COUNT DESC LIMIT  ".$this->maxObjects;
-				//do sql select for keyword cloud
-				$resKeyword = db_prep_query($sqlKeyword, $v, $t);
-				$keywordCounts = db_fetch_all($resKeyword);
-				if (count($keywordCounts) > 0) {
-					$this->maxWeight = $keywordCounts[0]['count'];
-					for ($j = 0; $j < count($keywordCounts); $j++) {
-						if ($this->scale == 'linear'){
-							//order in a linear scale desc
-							$keywordCounts[$j]['count'] = $this->maxFontSize-($j*$this->inc);
-						} else {
-							//set weight prop to count
-							 $keywordCounts[$j]['count'] = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
-	/*if ($scale == 'linear'){
-		$tags[$i]['weight'] = $maxFontSize-($i*$inc);
-	} else {
-		$tags[$i]['weight'] = $tags[$i]['weight']*$maxFontSize/$maxWeight;
-					shuffle($keywordCounts);
-						$this->keyJSON->tagCloud->tags[$j]->title = $keywordCounts[$j]['keyword'];
-						$this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count'];
-						$paramValue = $this->getValueForParam('searchText', $this->searchURL);
-						//delete resources part from query and set some new one
-						$searchUrlKeywords = $this->delTotalFromQuery('searchResources',$this->searchURL);
-						//append the resource parameter:
-						$searchUrlKeywords .= '&searchResources='.$this->searchResources;
-						$e = new mb_notice("class_metadata_new: value ".$paramValue." for searchText param found");
-						$paramValue = urldecode($paramValue);
-						if ($paramValue == false || $paramValue == '*') {
-							$this->keyJSON->tagCloud->tags[$j]->url = $searchUrlKeywords."&searchText=".$keywordCounts[$j]['keyword'];
-						} else {
-							$this->keyJSON->tagCloud->tags[$j]->url = $this->addToQuery('searchText',$searchUrlKeywords,$keywordCounts[$j]['keyword'],$paramValue);
-				//encode json!
-				$this->keyJSON = $this->json->encode($this->keyJSON);
-				//write clouds to file
-				if($keyFileHandle = fopen($keyFilename, "w")){
-					fwrite($keyFileHandle,$this->keyJSON);
-					fclose($keyFileHandle);
-					$e = new mb_notice("class_metadata: new ".$this->searchResources."_keyword_file created!");
-				} else {
-					$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_keyword_file!");
-				if ($this->resultTarget == 'debug') {
-					echo "<br>DEBUG: show keywords: <br>".$this->keyJSON."<br><br>";
-/** "$resourceId." from ".$wms_view." where ".$whereClause.") as a";
-				$sqlKeyword .= "(select keyword, count(*) from keyword INNER JOIN  layer_keyword  ON (layer_keyword.fkey_keyword_id = keyword.keyword_id) GROUP BY keyword.keyword) ";
-				$sqlKeyword .= " GROUP BY keyword.keyword)) as a WHERE a.keyword <> '' GROUP BY a.keyword ORDER BY sum DESC LIMIT $1";
-				//check if categories are defined for the resource
-				if ($this->resourceClasses != NULL) {
-					$this->catJSON->searchMD->category = array();
-					for ($i = 0; $i < count($this->resourceClasses); $i++) {
-						//TODO: not to set the classification?
-						$this->catJSON->searchMD->category[$i]->title = $this->resourceClassifications[$i]['title'];
-						$sqlCat[$i] = "SELECT ".$this->resourceClassifications[$i]['tablename'];
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['tablename']."_id, ";
-						$sqlCat[$i] .= " ".$this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_";
-						$sqlCat[$i] .= $this->languageCode.", COUNT(*) FROM ".$this->searchView;
-						//first join for connection table
-						$sqlCat[$i] .= " INNER JOIN ".$this->resourceClassifications[$i]['relation_'.$this->searchResources];
-						$sqlCat[$i] .= " ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['relation_'.$this->searchResources].".fkey_";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['id_'.$this->searchResources]."=".$this->searchView;
-						$sqlCat[$i] .= ".".$this->resourceClassifications[$i]['id_'.$this->searchResources];
-						$sqlCat[$i] .= ") INNER JOIN ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']." ON (";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename'].".";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id=";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id)";
-						//the following is needed to filter the custom cats for those which should not be seen in the classification
-						if ($this->resourceClassifications[$i]['title'] != $this->resourceClassifications[2]['title']){
-							$sqlCat[$i] .= " WHERE ".$whereStr." GROUP BY ";
-						} else {
-							$sqlCat[$i] .= " WHERE ".$whereStr.$this->whereStrCatExtension." GROUP BY ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id,";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode." ORDER BY ";
-						$sqlCat[$i] .= $this->resourceClassifications[$i]['tablename']."_id";
-						$sqlCategory = $sqlCat[$i];
-						//call sql for count of category
-						$res = db_prep_query($sqlCategory, $v, $t);
-						$e = new mb_notice("class_metadata: countCatsql: ".$sqlCategory);
-						$categoryCounts = db_fetch_all($res);
-						//if none found: $categoryCounts=false
-						#echo "<br>count sub categories :".$categoryCounts."<br>";
-						if ($categoryCounts) {
-						//write results in json object
-						if (count($categoryCounts) > 0) {
-							#echo "<br>count main categories".count($categoryCounts)."<br>";
-							#echo "<br>vardump main categories".var_dump($categoryCounts)."<br>";
-							$this->catJSON->searchMD->category[$i]->subcat = array();
-							for ($j = 0; $j < count($categoryCounts); $j++) {
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->id = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->title = $categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_code_".$this->languageCode];
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->count = $categoryCounts[$j]['count'];
-								//delete requestParam for this category and for id - cause a new search is started from searchURL
-								$filteredSearchString = $this->delTotalFromQuery('searchId',$this->searchURL);
-								//uncomment the following line if a or category search is intended
-								//$filteredSearchString = $this->delTotalFromQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString);
-								//TODO: maybe adopt this to do a and search and not a or like it is done now
-								//check if category search was requested and rewrite the search url
-								//get the value of the param as string or false if not set!
-								$paramValue = $this->getValueForParam($this->resourceClassifications[$i]['requestName'], $filteredSearchString);
-								if ($paramValue == false) {
-									//add new category to search
-								//set filter for this categoryid
-								$filteredSearchString .= "&".$this->resourceClassifications[$i]['requestName']."=".$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"];
-								} else {
-									//rewrite the searchUrl
-									$filteredSearchString = $this->addToQuery($this->resourceClassifications[$i]['requestName'],$filteredSearchString,$categoryCounts[$j][$this->resourceClassifications[$i]['tablename']."_id"],$paramValue);
-								$this->catJSON->searchMD->category[$i]->subcat[$j]->filterLink = $filteredSearchString;
-						} else {
-							#$this->catJSON->searchMD->category[$i]->subcat = array();
-						$e = new mb_notice("class_metadata: countsql: ".$sqlCat[$i]);
-				$this->catJSON = $this->json->encode($this->catJSON);
-				//write categories files only when file is requested and the searchid was not used before!
-					if($catFileHandle = fopen($filename, "w")){
-						fwrite($catFileHandle,$this->catJSON);
-						fclose($catFileHandle);
-						$e = new mb_notice("class_metadata: new ".$this->searchResources."_class_file created!");
-					} else {
-						$e = new mb_notice("class_metadata: cannot create ".$this->searchResources."_cat_file!");
-					echo "<br>DEBUG: show categories: <br>".$this->catJSON."<br><br>";
-			} else {
-				$e = new mb_notice("class_metadata: ".$this->searchResources."_class_file: ".$filename." already exists - no new one is generated!");
-		} else {
-				echo "<br>DEBUG: Standard ID dummysearch was invoked - classifications won't be counted!<br>";
-			$e = new mb_notice("class_metadata: standard dummysearch was invoked - classifications won't be counted!");
-		return $n;
-	private function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
-		//TODO: Set Email of owner into view for ressource - so it don't have to be searched?
-		$return_permission = "";
-		//get permission
-		$myWFSconfs = $admin->getWfsConfByPermission($this->userId);
-		$this->myWFSConfs = $myWFSconfs;
-		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
-			$array_element = $this->myWFSConfs[$index];
-		} else {
-			$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id "."and wfs.wfs_id=$1";
-			$t = array('i');
-			$res = db_prep_query($sql, $v, $t);
-			// get email
-			$mail = "";
-			while($row = db_fetch_array($res)){
-	private function getPermissionValueForLayer($layerId,$wmsId){
-		#$admin = new administration();
-		#$permission = $admin->getLayerPermission($wms_id, $layer_name, $this->userId);
-		#echo "<br>wms_id: ".$wms_id."<br>";
-		#echo "<br>layer_name: ".$layer_name."<br>";
-		#echo "<br>user_id: ".$this->userId."<br>";
-		#echo "<br>Permission: ".$permission."<br>";
-               # var_dump($this->accessableLayers);
-		if (in_array($layerId, $this->accessableLayers)){
-		} else {
-			$sql = "SELECT mb_user.mb_user_email as email FROM wms, mb_user WHERE wms.wms_owner=mb_user.mb_user_id";
-			$sql .= " AND wms.wms_id=$1";
-			$v = array($wmsId);
-			$t = array('i');
-			// get email
-			$mail="";
-	private function generateSearchStringArray() {
-		//'wfs test array' -> ('wfs' 'test' 'array')
-		$asstr = array();
-		if ($this->searchText != "false"){
-			$asstr = explode(",",$this->searchText);
-			//delete left and right whitespaces
-			for ($i=0; $i<count($asstr);$i++) {
-				$asstr[$i]=ltrim($asstr[$i]);
-				$asstr[$i]=rtrim($asstr[$i]);
-		} else {
-			$asstr[0]='%';
-		//check for single wildcard search
-		$e = new mb_notice('class_metadata_new: searchText: '.$this->searchText);
-		if ((count($asstr) == 1) && (($asstr[0]=='*') || ($asstr[0]==='false'))) {
-			$asstr[0]='%';
-		$e = new mb_notice('class_metadata_new: asstr[0]: '.$asstr[0]);
-		return $asstr;
-	//out of php doc - test if it is faster than normal array_search
-	private function fast_in_array($elem, $array) {
-   		$top = sizeof($array) -1;
-   		$bot = 0;
-		while($top >= $bot) {
-			$p = floor(($top + $bot) / 2);
-			if ($array[$p] < $elem) $bot = $p + 1;
-			elseif ($array[$p] > $elem) $top = $p - 1;
-			else return TRUE;
-    	return FALSE;
-	* filtering an array
-	private function filter_by_value ($array, $index, $value){
-        	if(is_array($array) && count($array)>0) {
-            		foreach(array_keys($array) as $key){
-                		$temp[$key] = $array[$key][$index];
-                		if ($temp[$key] == $value){
-                    			$newarray[$key] = $array[$key];
-      	return $newarray;
-	//function to get the parent of the given layer by crawling the layertree upwards
-	private function getLayerParent ($layerArray, $index){
-		//only layers of one service should be in $layerArray
-		#$parentExists = false;
-		#var_dump($layerArray);
-		$layerIDKey = $layerArray['layer_id'][$index];
-		#echo ("layerIDKey= ".$layerIDKey."<br>");
-		$layerParentPos = $layerArray['layer_parent'][$index];//get first parent object position
-		#echo ("layerParentPos= ".$layerParentPos."<br>");
-		#echo("<br>number of sublayers ".count(flipDiagonally($layerArray))."<br>");
-		#echo("<br>size of layerArray['layer_pos']: ".count($layerArray['layer_pos'])."<br>");
-		#var_dump($layerArray['layer_pos']);
-		#echo "<br>flipped layerArray: <br> ";
-		#var_dump(flipDiagonally($layerArray));
-		#echo "<br>";
-		if ($layerParentPos == '') {
-			//root layer directly found
-			return $index;
-		//Initialize index of layer parent - first it references the layer itself
-		$layerParentIndex = $index;
-		//loop to search higher parent objects - maybe this can be faster if the loop is not used over all sublayer elements! Do a while loop instead!
-		$highestParentLayerNotFound = true;
-		while ($highestParentLayerNotFound) {
-			#echo("<br>i= ".$i."<br>");
-			#echo("<br>layerParentPosNew= ".$layerParentPos."<br>");
-			$layerParentIndexNew = array_search((string)$layerParentPos, $layerArray['layer_pos']);
-			#echo("<br>layerParentIndexNew= ".$layerParentIndexNew."<br>");
-			if ($layerParentIndexNew != false) {
-				//some parent has been found
-				$layerParentIndex = $layerParentIndexNew;
-				$layerParentPos = $layerArray['layer_parent'][$layerParentIndex];
-					$highestParentLayerNotFound = false;
-					return $layerParentIndex; //a real root layer was found!
-				#$layerParentIndex = array_search($layerParentPos, $layerArray['layer_pos']);
-			} else {
-				$highestParentLayerNotFound = false; //no higher layer could be found
-	//function to write the child elements to the resulting wms object -> object is given by reference
-	private function writeWMSChilds($layerIdArray, $rootLayerPos, $subLayers, &$servObject) {
-		#echo "test";
-		#echo "<br>subLayers:<br>";
-		#var_dump($subLayers);
-		#echo "<br>";
-		$childLayers = $this->filter_by_value($subLayers, 'layer_parent', $rootLayerPos); //the root layer position in the sublayer array was located before. In this step, all layers will be pulled out of sublayer, where root layer position is parent object
-		#echo "<br<childLayers:<br>";
-		#var_dump($childLayers);
-		#echo "<br>";
-		#echo "test";
-		#print_r($childLayers);
-		$countsublayer = 0;
-		//if child exists create a new layer array for these
-		if (count($childLayers) != 0) {
-			$servObject->layer = array();
-		foreach ($childLayers as $child){
-			#echo "<br>countsublayer: ".$countsublayer."<br>";
-			#echo "<br>Child id: ".$child['layer_id']."<br>";
-			#echo "<br>Child pos: ".$child['layer_pos']."<br>";
-			$servObject->layer[$countsublayer]->id = $child['layer_id'];
-			$servObject->layer[$countsublayer]->title = $child['layer_title'];
-			$servObject->layer[$countsublayer]->abstract = $child['layer_abstract'];
-			$servObject->layer[$countsublayer]->previewURL = "http://".$this->hostName."/mapbender/geoportal/mod_showPreview.php?resource=layer&id=".$child['layer_id'];
-			$servObject->layer[$countsublayer]->mdLink = "http://".$this->hostName."/mapbender/php/mod_showMetadata.php?languageCode=".$this->languageCode."&resource=layer&layout=tabs&id=".$child['layer_id'];
-			if ($child['layer_name'] == ''){
-				$servObject->layer[$countsublayer]->loadable = 0;
-			} else {
-				$servObject->layer[$countsublayer]->loadable = 1;
-			if ($child['md_inspire_cats'] == ''){
-				$servObject->layer[$countsublayer]->inspire = 0;
-			else {
-				$servObject->layer[$countsublayer]->inspire = 1;
-			if ($child['layer_queryable'] == 1){
-				$servObject->layer[$countsublayer]->queryable = 1;
-			else {
-				$servObject->layer[$countsublayer]->queryable = 0;
-			$servObject->layer[$countsublayer]->loadCount = $child['load_count'];
-			$servObject->layer[$countsublayer]->bbox = $child['bbox'];
-			$servObject->layer[$countsublayer]->permission = $this->getPermissionValueForLayer($child['layer_id'],$child['wms_id']); //TODO: make this much faster!!!! - is done by collecting all accessable resources once. Maybe this has to be adopted if the count of the resources become higher
-			//call this function itself - search sublayers in the layer object.
-			$layerIdArray = $this->writeWMSChilds($layerIdArray, $child['layer_pos'], $subLayers, $servObject->layer[$countsublayer]);//TODO create a timeout condition !
-			array_push($layerIdArray, $child['layer_id']); //child have been identified and recursively written
-			#var_dump($layerIdArray);#
-			#echo "<br>";
-			$countsublayer ++;
-		return $layerIdArray;
-	private function hasConstraints($type,$id) {
-		if ($type == "wms") {
-			$sql = "SELECT wms.accessconstraints, wms.fees, wms.wms_network_access , wms.wms_pricevolume, wms.wms_proxylog, termsofuse.name,";
-			$sql .= " termsofuse.termsofuse_id, termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from wms LEFT OUTER JOIN";
-			$sql .= "  wms_termsofuse ON  (wms.wms_id = wms_termsofuse.fkey_wms_id) LEFT OUTER JOIN termsofuse ON";
-			$sql .= " (wms_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where wms.wms_id = $1";
-		if ($type == "wfs") {
-			$sql = "SELECT accessconstraints, fees, wfs_network_access , termsofuse.name,";
-			$sql .= " termsofuse.termsofuse_id ,termsofuse.symbollink, termsofuse.description,termsofuse.descriptionlink from wfs LEFT OUTER JOIN";
-			$sql .= "  wfs_termsofuse ON  (wfs.wfs_id = wfs_termsofuse.fkey_wfs_id) LEFT OUTER JOIN termsofuse ON";
-			$sql .= " (wfs_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id) where wfs.wfs_id = $1";
-		$v = array();
-		$t = array();
-		array_push($t, "i");
-		array_push($v, $id);
-		$res = db_prep_query($sql,$v,$t);
-		$row = db_fetch_array($res);
-		if ((isset($row[$type.'_proxylog']) & $row[$type.'_proxylog'] != 0) or strtoupper($row['accessconstraints']) != "NONE" or strtoupper($row['fees']) != "NONE" or isset($row['termsofuse_id']) ) {
-		//service has some constraints defined!
-		//give symbol and true
-		//termsofuse symbol or exclamation mark
-			if (isset($row['termsofuse_id']) & $row['symbollink'] != "") {
- 				$symbolLink = $row['symbollink'];
-			} else {
-				$symbolLink = "http://".$this->hostName."/portal/fileadmin/design/icn_warn.png";
-			$hasConstraints = true;
-			#$disclaimerLink = $_SERVER['HTTP_HOST']."/mapbender/php/mod_getServiceDisclaimer.php?type=".$type."&id=".$id;
-			#$symbolMouseOver = "Nutzungsbedingungen"; //TODO internationalize it
-		} else {
-		//give symbol and false
-		//green symbol
-			$symbolLink = "http://".$this->hostName."/portal/fileadmin/design/icn_ok.png";
-       			#$disclaimerLink = "";
-			$hasConstraints = false;
-			#$symbolMouseOver = "Frei zugänglich"; //TODO internationalize it
-		//generate json output:
-		#$json = new Mapbender_JSON;
-		#$returnJSON = new stdClass;
-		#$returnJSON->serviceConstraints = (object) array(
-				#'hasConstraints' => $hasConstraints,
-				#'disclaimerLink' => $disclaimerLink,
-				#'symbolLink' => $symbolLink,
-				#'symbolMouseOver' => $symbolMouseOver
-		#$returnJSON = $json->encode($returnJSON);
-		#echo $returnJSON;
-		return array($hasConstraints, $symbolLink);
-	//function to delete one of the comma separated values from a HTTP-GET request
-	private function delFromQuery($paramName,$queryString,$string,$queryArray,$queryList) {
-		//check if if count searchArray = 1
-		if (count($queryArray) == 1){
-			//remove request parameter from url by regexpr or replace
-			$str2search = $paramName."=".$queryList;
-			$str2exchange = "";
-			$queryStringNew = str_replace($str2search, $str2exchange, $queryString);
-			$queryStringNew = str_replace("&&", "&", $queryStringNew);
-		} else {
-		//there are more than one filter - reduce the filter
-			$objectList = "";
-			for($i=0; $i < count($queryArray); $i++){
-				if ($queryArray[$i] != $string){
-					$objectList .= $queryArray[$i].",";
-			//remove last comma
-			$objectList = rtrim($objectList, ",");
-			$str2exchange = $paramName."=".$objectList;
-	return $queryStringNew;
-	private function getValueForParam($paramName,$queryString) {
-		#another approach:
-		parse_str($queryString, $allQueries);
-		if (isset($allQueries[$paramName]) & $allQueries[$paramName] != '') {
-			return $allQueries[$paramName];
-		} else {
-			return false;
-#		old version
-/*		#TODO: check if last and first ampersand was set before
-		$queryString = "&".$queryString."&";
-		#$pattern = '/\b'.$paramName.'=([a-z0-9-]+)\&?/';
-		$pattern = '/\b&'.$paramName.'\=[^&]+&?/';
-		#$pattern = '/^&'.$paramName.'=[a-zA-ZöäüÖÄÜß,]*&$/';
-		$e = new mb_notice("class_metadata_new.php: look for pattern: ".$pattern."  in ".$queryString);
- 		if (!preg_match($pattern, $queryString, $matches)){
-			return false;
-		} else {
-			//some param found
-			//delete $paramName= and the last ampersand!
-			if (count($matches) == 1) {
-				$requestString = $matches[0];
-				$requestString = ltrim($requestString,"&".$paramName."=");
-				$requestString = rtrim($requestString,'&');
-				return $requestString;
-			} else {
-				$e = new mb_notice("class_metadata_new.php: There are parameter ambiguities!");
-				#echo "Parameter Ambiguities found!";
-				die();
-// function to add a new variable or complete parameter to a GET parameter query url
-	private function addToQuery($paramName,$queryString,$string,$queryList) {
-		//test if string was part of query before, if so, don't extent the query
-		//TODO: the strings come from json and so they are urlencoded! maybe we have to decode them to find the commata
-		$queryListComma = urldecode($queryList);
-		$queryListC = ",".$queryListComma.",";
-		$pattern = ','.$string.',';
- 		if (!preg_match($pattern, $queryListC)){
-			//append the new element
-			$queryListNew = $queryListC.$string;
-			//echo "query string new: ".$queryListNew."<br>";
-			//delete the commatas
-			$queryListNew = ltrim($queryListNew,',');
-			//generate the new query string
-			$queryStringNew = str_replace($paramName.'='.$queryList,$paramName.'='.$queryListNew,$queryString);
-			//dump old and new querystring for debugging
-			//$this->logit("class_metadata_new: queryString_old:".$queryString);
-			//$this->logit("class_metadata_new: queryString_new:".$queryStringNew);
-		} else {
-			//$this->logit("class_metadata_new: queryString unchanged:".$queryString);
-			//return the old one!
-			return $queryString;
-//for debugging purposes only
-	private function logit($text){
-	 	if($h = fopen("/tmp/class_metadata_new.log","a")){
-					$content = $text .chr(13).chr(10);
-					if(!fwrite($h,$content)){
-						#exit;
-					fclose($h);
-// function to delete one GET parameter totally from a query url
-	private function delTotalFromQuery($paramName,$queryString) {
-		$queryString = "&".$queryString;
-		#echo "<br>queryString: ".$queryString."<br>";
-		$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',"",$queryString);
-		$queryStringNew = ltrim($queryStringNew,'&');
-		$queryStringNew = rtrim($queryStringNew,'&');
More information about the Mapbender_commits mailing list
