[Mapbender-commits] r9869 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Feb 19 07:12:19 PST 2018
Author: armin11
Date: 2018-02-19 07:12:19 -0800 (Mon, 19 Feb 2018)
New Revision: 9869
   trunk/mapbender/http/classes/class_syncCkan.php
   trunk/mapbender/http/php/mod_showOpenDataOrganizations.php
Fix for exporting opendata information to ckan instances
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php	2018-02-16 11:57:11 UTC (rev 9868)
+++ trunk/mapbender/http/classes/class_syncCkan.php	2018-02-19 15:12:19 UTC (rev 9869)
@@ -751,13 +751,20 @@
                         //only use metadata for which real licenses are defined !!!!!! - what should be done with the other metadata?- DO a left join!!!
 			//TODO: test what wents wrong, if fkey_mb_group_id is set in mapbender
                         if ($organization['is_primary_group']) {
-                            $sql = "SELECT *, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_user_id = $1 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0) AND export2csw IS true";
-                            $v = array($this->mapbenderUserId);
-                            $t = array('i');
+			    $sql = "SELECT metadata_id as ressource_id, 'metadata' as ressource_type, uuid::varchar, title, lastchanged, fkey_termsofuse_id, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_user_id = $1 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0) AND export2csw IS true AND md_termsofuse.fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1) ";
+			    $sql .= " UNION SELECT layer_metadata.ressource_id, layer_metadata.ressource_type, layer_metadata.uuid::varchar, layer_metadata.title, to_timestamp(layer_metadata.lastchanged), wms_termsofuse.fkey_termsofuse_id, '{\"coupledResources\":{\"layerIds\":[' || layer_metadata.ressource_id || '],\"featuretypeIds\":[]}}' as f_get_coupled_resources FROM ";
+			    $sql .= "(SELECT layer_id as ressource_id, 'layer' as ressource_type, layer.uuid::varchar, layer_title as title, wms.wms_timestamp as lastchanged, layer.fkey_wms_id FROM layer INNER JOIN wms on layer.fkey_wms_id = wms.wms_id WHERE wms_owner = $2 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0)";
+			    $sql .= " AND layer.export2csw IS true AND layer.layer_searchable = 1 AND layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
+			    //$e = new mb_exception("class_syncCkan.php: sql: ".$sql);
+                            $v = array($this->mapbenderUserId, $this->mapbenderUserId);
+                            $t = array('i','i');
                         } else {
-                            $sql = "SELECT *, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_group_id = $1 AND export2csw IS true";
-                            $v = array($organization['id']);
-                            $t = array('i');
+			   $sql = "SELECT metadata_id as ressource_id, 'metadata' as ressource_type, uuid::varchar, title, lastchanged, fkey_termsofuse_id, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_group_id = $1 AND export2csw IS true AND md_termsofuse.fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1)";
+			    $sql .= " UNION SELECT layer_metadata.ressource_id, layer_metadata.ressource_type, layer_metadata.uuid::varchar, layer_metadata.title, to_timestamp(layer_metadata.lastchanged), wms_termsofuse.fkey_termsofuse_id, '{\"coupledResources\":{\"layerIds\":[' || layer_metadata.ressource_id || '],\"featuretypeIds\":[]}}' ";
+			    $sql = "as f_get_coupled_resources FROM (SELECT layer_id as ressource_id, 'layer' as ressource_type, layer.uuid::varchar, layer_title as title, wms.wms_timestamp as lastchanged, layer.fkey_wms_id FROM layer INNER JOIN wms on layer.fkey_wms_id = wms.wms_id WHERE fkey_mb_group_id = $2 AND layer.export2csw IS true AND layer.layer_searchable = 1 AND";
+			    $sql = " layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
+                            $v = array($organization['id'], $organization['id']);
+                            $t = array('i', 'i');
                         $res = db_prep_query($sql, $v, $t);
                         $countMetadataArray = 0;
@@ -766,12 +773,13 @@
                         //echo "List of datasets in geoportal instance:"."<br>";
                         while($row = db_fetch_array($res)){
                             $metadataArray[$countMetadataArray]["hasResource"] = false;
-                            $metadataArray[$countMetadataArray]["id"] = $row["metadata_id"];
+                            $metadataArray[$countMetadataArray]["id"] = $row["ressource_id"];
                             $metadataArray[$countMetadataArray]["uuid"] = $row["uuid"];
                             $metadataArray[$countMetadataArray]["title"] = $row["title"];
                             $metadataArray[$countMetadataArray]["changedate"] = $row["lastchanged"];
                             $metadataArray[$countMetadataArray]["license_id"] = $row["fkey_termsofuse_id"];
                             $metadataArray[$countMetadataArray]["resources"] = $row["f_get_coupled_resources"];
+			    $metadataArray[$countMetadataArray]["resource_type"] = $row["ressource_type"];
                             foreach (json_decode($metadataArray[$countMetadataArray]["resources"])->coupledResources->layerIds as $layerId) {
                                 $layerArray[] = $layerId;
                                 $metadataArray[$countMetadataArray]["hasResource"] = true;
@@ -799,6 +807,7 @@
                                         if ($listAllMetadataInJson == true) {
                                             $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->id = $geoportalMetadata['uuid'];
                                             $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->date_time = $geoportalMetadata['changedate'];
+					    $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->resource_type = $geoportalMetadata['resource_type'];
                                             $syncListResult->geoportal_organization[$numberGeoportalOrga]->datasource_metadata[$numberGeoportalMetadata]->resources = json_decode($geoportalMetadata['resources']);
                                         $geoportalUuids[] = $geoportalMetadata['uuid'];
@@ -945,7 +954,7 @@
 			//first try to read from datasource
 		        switch ($dataSourceType) {
 		            case "mapbender":
-			        $resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap);
+			        $resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap, $datasetMetadata->resource_type);
 			        break;
 		            case "portalucsw":
 			        $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->name, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
@@ -956,7 +965,7 @@
 				$resultCkanRepresentation = $this->getCkanRepresentationFromCkan($syncList->ckan_api_url, $syncList->ckan_api_version, $datasetMetadata->id, $syncList->central_filter, $syncList->ckan_orga_ident);
 				//$resultCkanRepresentation = false;
-			        //$resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap);
+			        //$resultCkanRepresentation = $this->getCkanRepresentation($datasetMetadata->id, $layerArrayMetadata, $featuretypeArrayMetadata, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap, $datasetMetadata->resource_type);
 			        break;
 			//if reading was successful
@@ -980,7 +989,7 @@
 			//first read from external source
 		            case "mapbender":
 			        break;
 		            case "portalucsw":
 			        $resultCkanRepresentation = $this->getCkanRepresentationFromCsw($syncList->id, $datasetMetadata->id, $syncList->ckan_orga_ident, $syncList->title, $syncList->email, $this->topicDataThemeCategoryMap, $syncList->ckan_filter);
@@ -990,7 +999,7 @@
 				//$e = new mb_exception("classes/class_syncCkan.php: try to pull json object from remote ckan - id: ".$datasetMetadata->id);
 			        break;
 			//if read from source was successful
@@ -1146,7 +1155,7 @@
     //function to get ckan representation from mapbender metadata
-    private function getCkanRepresentation($uuid, $layerArray, $featuretypeArray, $orgaId, $orgaTitle, $orgaEmail, $topicCkanCategoryMap) {
+    private function getCkanRepresentation($uuid, $layerArray, $featuretypeArray, $orgaId, $orgaTitle, $orgaEmail, $topicCkanCategoryMap, $resourceType = 'metadata') {
         if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
 	    $mapbenderUrl = MAPBENDER_PATH;
 	} else {
@@ -1157,7 +1166,18 @@
 	//all or only those which have standardized licenses?
 	//$sql = "SELECT *, f_get_coupled_resources(metadata_id) from mb_metadata LEFT JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE mb_metadata.uuid = $1";
 	//$sql = "SELECT * , st_asgeojson(the_geom) as geojson from mb_metadata JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id JOIN termsofuse ON md_termsofuse.fkey_termsofuse_id = termsofuse.termsofuse_id WHERE mb_metadata.uuid = $1 AND export2csw IS true";
-	$sql = "SELECT * , st_asgeojson(the_geom) as geojson, f_get_responsible_organization_for_ressource(metadata_id, 'metadata') as resp_party_id from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id LEFT OUTER JOIN termsofuse ON md_termsofuse.fkey_termsofuse_id = termsofuse.termsofuse_id WHERE mb_metadata.uuid = $1 AND export2csw IS true";#7aeacc93-6b0d-da7f-1f86-80eea9e188b2
+	switch ($resourceType) {
+		case "layer":
+			$sql = <<<SQL
+SELECT layer.layer_id as metadata_id, layer.layer_title as title, layer.layer_abstract as abstract ,  f_get_responsible_organization_for_ressource(layer.fkey_wms_id, 'wms') as resp_party_id, termsofuse.* FROM layer LEFT OUTER JOIN wms_termsofuse ON layer.fkey_wms_id = wms_termsofuse.fkey_wms_id LEFT OUTER JOIN termsofuse ON wms_termsofuse.fkey_termsofuse_id = termsofuse.termsofuse_id WHERE layer.uuid = $1 AND layer.export2csw IS true AND layer.layer_searchable = 1
+SQL;
+			break;
+		case "metadata":
+			$sql = "SELECT * , st_asgeojson(the_geom) as geojson, f_get_responsible_organization_for_ressource(metadata_id, 'metadata') as resp_party_id from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id LEFT OUTER JOIN termsofuse ON md_termsofuse.fkey_termsofuse_id = termsofuse.termsofuse_id WHERE mb_metadata.uuid = $1 AND export2csw IS true";
+			break;
 	$v = array($uuid);
 	$t = array('s');
@@ -1164,7 +1184,7 @@
 	if ($res) {
 	    $row = db_fetch_assoc($res);
 	} else {
-	    $e = new mb_exception("classes/class_syncCkan.php: No metadata found for uuid: ".$uuid);
+	    $e = new mb_exception("classes/class_syncCkan.php: No metadata/layer found for uuid: ".$uuid);
 	    return false;
 	//get responsible organisation information
@@ -1220,7 +1240,9 @@
 		$ckanPackage->license_id = 'notspecified';
 		$ckanPackage->license_title = "Keine definierte Lizenz";
-	$ckanPackage->spatial = $row['geojson'];
+	if ($resourceType == 'metadata') {
+		$ckanPackage->spatial = $row['geojson'];
         //$ckanPackage->url = "";
 	//special categories
 	//$ckanPackage->govdata_categories = [];
@@ -1228,10 +1250,11 @@
 $ckanPackage->registerobject_type = "Par_7_1_9";
 //$e = new mb_exception("update_frequency from db: ".$row['update_frequency']." - frequency for dcat: ".$this->frequencyMap[$row['update_frequency']]);
-if (array_key_exists($row['update_frequency'],$this->frequencyMap)) {
-	$ckanPackage->frequency = $this->frequencyMap[$row['update_frequency']];
+		if (array_key_exists($row['update_frequency'],$this->frequencyMap)) {
+			$ckanPackage->frequency = $this->frequencyMap[$row['update_frequency']];
 	$ckanPackage->type = "geodata";
 	//build resources:
 	$resourcesArray = array();
@@ -1243,7 +1266,16 @@
 	$resourcesArray[$indexResourceArray]->name = "Originäre Metadaten";// für ".$row['layer_title'];
 	$resourcesArray[$indexResourceArray]->id = $metadataUuid."_iso19139";
 	$resourcesArray[$indexResourceArray]->description = $ckanPackage->title." - Anzeige der originären Metadaten";
-	$resourcesArray[$indexResourceArray]->url = $mapbenderUrl."/php/mod_exportIso19139.php?url=http%3A%2F%2Fwww.geoportal.rlp.de%2Fmapbender%2Fphp%2Fmod_dataISOMetadata.php%3FoutputFormat%3Diso19139%26id%3D".$metadataUuid;
+		case "layer":
+			$resourcesArray[$indexResourceArray]->url = $mapbenderUrl."/php/mod_showMetadata.php?resource=layer&layout=tabs&redirectToMetadataUrl=1&id=".$metadataId;
+			break;
+		case "metadata":
+			$resourcesArray[$indexResourceArray]->url = $mapbenderUrl."/php/mod_exportIso19139.php?url=http%3A%2F%2Fwww.geoportal.rlp.de%2Fmapbender%2Fphp%2Fmod_dataISOMetadata.php%3FoutputFormat%3Diso19139%26id%3D".$metadataUuid;
+			break;
 	$resourcesArray[$indexResourceArray]->format = "HTML";
 	$indexResourceArray++;
 	//views to generate
Modified: trunk/mapbender/http/php/mod_showOpenDataOrganizations.php
--- trunk/mapbender/http/php/mod_showOpenDataOrganizations.php	2018-02-16 11:57:11 UTC (rev 9868)
+++ trunk/mapbender/http/php/mod_showOpenDataOrganizations.php	2018-02-19 15:12:19 UTC (rev 9869)
@@ -1,8 +1,23 @@
 <?php
 require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+$showOnlyDatasetMetadata = "false";
 //params: opendata licenses, only metadata, ....
+if (isset($_REQUEST["showOnlyDatasetMetadata"]) & $_REQUEST["showOnlyDatasetMetadata"] != "") {
+	$testMatch = $_REQUEST["showOnlyDatasetMetadata"];
+ 	if (!($testMatch == 'true' or $testMatch == 'false')){
+		echo 'Parameter <b>showOnlyDatasetMetadata</b> is not valid (true,false (default to false)).<br/>';
+		die();
+	switch ($testMatch) {
+		case "true":
+			$showOnlyDatasetMetadata = "true";
+		break;
+		case "false":
+			$showOnlyDatasetMetadata = "false";
+		break;
+	$testMatch = NULL;
 $sql = <<<SQL
 select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id,mb_group_name from (
@@ -18,6 +33,27 @@
 SQL;
+$sql2 = <<<SQL
+select opendata.*, mb_group.uuid, mb_group_id, mb_group_title, mb_group_description, mb_group_homepage, mb_group_logo_path, mb_group_address, mb_group_postcode, mb_group_city, mb_group_email, timestamp from mb_group, (select (sum(count_wms_layer)+sum(count_metadata)) as number_of_opendata_ressources, group_id,mb_group_name from (
+select count_wms_layer, metadata_group.count_metadata, group_id,mb_group_name from mb_group, (select count(metadata_id) as count_metadata, 0 as count_wms_layer , f_get_responsible_organization_for_ressource(metadata_id, 'metadata') as group_id from mb_metadata where searchable is true and export2csw is true and metadata_id in (select fkey_metadata_id from md_termsofuse where fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1)) group by group_id) as metadata_group where mb_group.mb_group_id = metadata_group.group_id
+) as opendata_ressources group by group_id, mb_group_name) as opendata
+where opendata.group_id = mb_group.mb_group_id
+SQL;
+switch ($showOnlyDatasetMetadata) {
+	case "true":
+		$result = db_query($sql2);
+		break;
+	case "false":
+		$result = db_query($sql);
+		break;
 $returnObject = array();
More information about the Mapbender_commits mailing list
