[Mapbender-commits] r9870 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Feb 19 07:37:02 PST 2018
Author: armin11
Date: 2018-02-19 07:37:02 -0800 (Mon, 19 Feb 2018)
New Revision: 9870
   trunk/mapbender/http/classes/class_syncCkan.php
Fix
Modified: trunk/mapbender/http/classes/class_syncCkan.php
--- trunk/mapbender/http/classes/class_syncCkan.php	2018-02-19 15:12:19 UTC (rev 9869)
+++ trunk/mapbender/http/classes/class_syncCkan.php	2018-02-19 15:37:02 UTC (rev 9870)
@@ -754,7 +754,7 @@
 			    $sql = "SELECT metadata_id as ressource_id, 'metadata' as ressource_type, uuid::varchar, title, lastchanged, fkey_termsofuse_id, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_user_id = $1 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0) AND export2csw IS true AND md_termsofuse.fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1) ";
 			    $sql .= " UNION SELECT layer_metadata.ressource_id, layer_metadata.ressource_type, layer_metadata.uuid::varchar, layer_metadata.title, to_timestamp(layer_metadata.lastchanged), wms_termsofuse.fkey_termsofuse_id, '{\"coupledResources\":{\"layerIds\":[' || layer_metadata.ressource_id || '],\"featuretypeIds\":[]}}' as f_get_coupled_resources FROM ";
 			    $sql .= "(SELECT layer_id as ressource_id, 'layer' as ressource_type, layer.uuid::varchar, layer_title as title, wms.wms_timestamp as lastchanged, layer.fkey_wms_id FROM layer INNER JOIN wms on layer.fkey_wms_id = wms.wms_id WHERE wms_owner = $2 AND (fkey_mb_group_id is null OR fkey_mb_group_id = 0)";
-			    $sql .= " AND layer.export2csw IS true AND layer.layer_searchable = 1 AND layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
+			    $sql .= " AND layer.export2csw IS true AND layer.layer_searchable = 1 AND layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata WHERE fkey_layer_id IS NOT NULL)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
 			    //$e = new mb_exception("class_syncCkan.php: sql: ".$sql);
                             $v = array($this->mapbenderUserId, $this->mapbenderUserId);
                             $t = array('i','i');
@@ -762,7 +762,7 @@
 			   $sql = "SELECT metadata_id as ressource_id, 'metadata' as ressource_type, uuid::varchar, title, lastchanged, fkey_termsofuse_id, f_get_coupled_resources(metadata_id) from mb_metadata LEFT OUTER JOIN md_termsofuse ON mb_metadata.metadata_id = md_termsofuse.fkey_metadata_id WHERE fkey_mb_group_id = $1 AND export2csw IS true AND md_termsofuse.fkey_termsofuse_id in (select termsofuse_id from termsofuse where isopen = 1)";
 			    $sql .= " UNION SELECT layer_metadata.ressource_id, layer_metadata.ressource_type, layer_metadata.uuid::varchar, layer_metadata.title, to_timestamp(layer_metadata.lastchanged), wms_termsofuse.fkey_termsofuse_id, '{\"coupledResources\":{\"layerIds\":[' || layer_metadata.ressource_id || '],\"featuretypeIds\":[]}}' ";
 			    $sql = "as f_get_coupled_resources FROM (SELECT layer_id as ressource_id, 'layer' as ressource_type, layer.uuid::varchar, layer_title as title, wms.wms_timestamp as lastchanged, layer.fkey_wms_id FROM layer INNER JOIN wms on layer.fkey_wms_id = wms.wms_id WHERE fkey_mb_group_id = $2 AND layer.export2csw IS true AND layer.layer_searchable = 1 AND";
-			    $sql = " layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
+			    $sql = " layer_id NOT IN (SELECT DISTINCT fkey_layer_id FROM ows_relation_metadata WHERE fkey_layer_id IS NOT NULL)) AS layer_metadata INNER JOIN wms_termsofuse ON layer_metadata.fkey_wms_id = wms_termsofuse.fkey_wms_id AND fkey_termsofuse_id IS NOT NULL AND wms_termsofuse.fkey_termsofuse_id IN (SELECT termsofuse_id FROM termsofuse WHERE isopen = 1)";
                             $v = array($organization['id'], $organization['id']);
                             $t = array('i', 'i');
More information about the Mapbender_commits mailing list
