[Mapbender-commits] r9885 - in trunk/mapbender/http/extensions/mobilemap2: . scripts/netgis
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 19 09:38:14 PDT 2018
Author: armin11
Date: 2018-03-19 09:38:14 -0700 (Mon, 19 Mar 2018)
New Revision: 9885
   trunk/mapbender/http/extensions/mobilemap2/index.html
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/events.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
New possibilities for mobilemap component from sebastian pauli
Modified: trunk/mapbender/http/extensions/mobilemap2/index.html
--- trunk/mapbender/http/extensions/mobilemap2/index.html	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/index.html	2018-03-19 16:38:14 UTC (rev 9885)
@@ -365,8 +365,9 @@
 					<span class="icon-left glyphicon glyphicon-check"></span>
 					<span data-content="title"></span>
 					<span class="pull-right">
-						<span class="btn-up glyphicon glyphicon-arrow-up"></span>
-						<span class="btn-down glyphicon glyphicon-arrow-down"></span>
+						<span class="btn-zoom glyphicon glyphicon-fullscreen" title="Zoom"></span>
+						<span class="btn-up glyphicon glyphicon-arrow-up" title="Rauf"></span>
+						<span class="btn-down glyphicon glyphicon-arrow-down" title="Runter"></span>
 					</span>
 				</a>
 			</div>
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/component.js	2018-03-19 16:38:14 UTC (rev 9885)
@@ -132,3 +132,16 @@
 netgis.component.KML.prototype.name = "kml";
+/** Extent */
+netgis.component.Extent = function( minx, miny, maxx, maxy )
+	this.minx = minx;
+	this.miny = miny;
+	this.maxx = maxx;
+	this.maxy = maxy;
+	return this;
+netgis.component.Extent.prototype.name = "extent";
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/events.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/events.js	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/events.js	2018-03-19 16:38:14 UTC (rev 9885)
@@ -129,6 +129,7 @@
 			LAYER_REMOVE:		"layer-remove",
 			LAYER_MOVE_UP:		"layer-move-up",
 			LAYER_MOVE_DOWN:	"layer-move-down",
+			LAYER_ZOOM:			"layer-zoom",
 			POSITION_TOGGLE:	"position-toggle",
 			POSITION_CENTER:	"position-center",
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2018-03-19 16:38:14 UTC (rev 9885)
@@ -16,6 +16,7 @@
 		// Private Variables
 		//var layerList;
+		var singleLayerRequest = null;
 		// Private Methods
 		var init = function()
@@ -43,7 +44,15 @@
 			else
 				netgis.events.call( netgis.events.LAYERS_LOADING, { loading: true } );
-				netgis.events.call( netgis.events.LAYERS_LOADING, { loading: false } );
+				// Request Layer
+				if ( params.layerid )
+					singleLayerRequest = parseInt( params.layerid );
+					requestLayers( [ params.layerid ] );
+				else
+					netgis.events.call( netgis.events.LAYERS_LOADING, { loading: false } );
@@ -137,6 +146,16 @@
 			if ( layerData.layerQueryable === 1 || layerData.queryable === 1 ) //NOTE: these two props should have the same name!
 				entity.set( new netgis.component.Queryable() );
+			if ( layerData.bbox )
+				var bbox = layerData.bbox.split( "," );
+				for ( var i = 0; i < bbox.length; i++ )
+					bbox[ i ] = parseFloat( bbox[ i ] );
+				entity.set( new netgis.component.Extent( bbox[ 0 ], bbox[ 1 ], bbox[ 2 ], bbox[ 3 ] ) );
 			return entity;
@@ -278,6 +297,22 @@
+			// Single Layer Request
+			if ( singleLayerRequest )
+				var results = netgis.entities.find( netgis.component.Layer, "id", singleLayerRequest );
+				if ( results.length > 0 )
+					var layer = results[ 0 ];
+					layer.toggle( netgis.component.Active );
+					netgis.events.call( netgis.events.LAYER_TOGGLE, { id: layer.id } );
+					netgis.events.call( netgis.events.LAYER_ZOOM, { id: layer.id } );
 		var onLayerToggle = function( params )
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/manager.js	2018-03-19 16:38:14 UTC (rev 9885)
@@ -136,6 +136,7 @@
 			layerListMap.find( ".btn-layer" ).click( onLayerClick );
 			layerListMap.find( ".btn-up" ).click( onLayerUpClick );
 			layerListMap.find( ".btn-down" ).click( onLayerDownClick );
+			layerListMap.find( ".btn-zoom" ).click( onLayerZoomClick );
 			updateMapLayerOrder();
@@ -459,6 +460,16 @@
 			//TODO: bug when moving background layer down
+		var onLayerZoomClick = function( event )
+			event.stopPropagation();
+			event.preventDefault();
+			var id = $( event.target ).closest( "[data-id]" ).data( "id" );
+			netgis.events.call( netgis.events.LAYER_ZOOM, { id: id } );
 		var onLayerMoveUp = function( event )
 			var item = layerListMap.find( "#" + event.id );
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-03-16 11:23:40 UTC (rev 9884)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-03-19 16:38:14 UTC (rev 9885)
@@ -313,6 +313,7 @@
 			netgis.events.on( netgis.events.LAYER_REMOVE, onLayerRemove );
 			netgis.events.on( netgis.events.LAYER_MOVE_UP, onLayerMoveUp );
 			netgis.events.on( netgis.events.LAYER_MOVE_DOWN, onLayerMoveDown );
+			netgis.events.on( netgis.events.LAYER_ZOOM, onLayerZoom );
 			netgis.events.on( netgis.events.POSITION_TOGGLE, onPositionToggle );
 			netgis.events.on( netgis.events.POSITION_CENTER, onPositionCenter );
@@ -876,7 +877,7 @@
 				content += "<div class='panel panel-primary'>";
 				content += "<div class='panel-heading clickable' data-toggle='collapse' data-target='#" + panelId + "'>";
-				content += "<h4 class='panel-title'>" + "KML Feature" + "</h4>";
+				content += "<h4 class='panel-title'>" + "Zeichnungsobjekt" + "</h4>";
 				content += "</div>";
 				content += "<div id='" + panelId + "' class='panel-collapse collapse'>";
@@ -1166,6 +1167,24 @@
+		var onLayerZoom = function( event )
+			var layer = netgis.entities.get( event.id );
+			var extent = layer.get( netgis.component.Extent );
+			if ( extent )
+				var min = ol.proj.fromLonLat( [ extent.minx, extent.miny ], netgis.config.MAP_PROJECTION );
+				var max = ol.proj.fromLonLat( [ extent.maxx, extent.maxy ], netgis.config.MAP_PROJECTION );
+				viewExtent( min[ 0 ], min[ 1 ], max[ 0 ], max[ 1 ] );
+			else
+				viewExtent( netgis.config.MAP_EXTENT[ 0 ], netgis.config.MAP_EXTENT[ 1 ], netgis.config.MAP_EXTENT[ 2 ], netgis.config.MAP_EXTENT[ 3 ] );
 		var onPositionToggle = function( params )
 			positionActive = params.active;
More information about the Mapbender_commits mailing list
