[Mapbender-commits] r9886 - trunk/mapbender/http/extensions/mobilemap2/scripts/netgis
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Mar 20 01:40:34 PDT 2018
Author: armin11
Date: 2018-03-20 01:40:33 -0700 (Tue, 20 Mar 2018)
New Revision: 9886
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
   trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
New possibilities for mobilemap2 - set default opacity for overlay layers, option to open featureinfo in new tab, featureinfo proxy to solve http/https problems. thanx to sebastian pauli ;-)
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2018-03-19 16:38:14 UTC (rev 9885)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/config.js	2018-03-20 08:40:33 UTC (rev 9886)
@@ -36,10 +36,13 @@
 	/** Map extent (min x, min y, max x, max y). */
 	MAP_EXTENT:				[ 293300, 5424000, 464300, 5654100 ],
+	/** Default map layer opacity (0.0 - 1.0). */
+	MAP_DEFAULT_OPACITY:	0.8,
 	/** Maximum number of map view history entries. */
 	MAX_HISTORY:			10,
-	/** Service URLs. */
+	/** Service URLs (avoid proxies by setting to null or empty string). */
 	URL_WMC_PROXY:			"./scripts/proxy.php",
 	URL_WMC_REQUEST:		"http://www.geoportal.rlp.de/mapbender/php/mod_exportWmc2Json.php",
@@ -50,5 +53,7 @@
 	URL_SEARCH_REQUEST:		"http://www.geoportal.rlp.de/mapbender/geoportal/gaz_geom_mobile.php",
 	URL_BACKGROUND_HYBRID:	"http://www.gdi-rp-dienste2.rlp.de/mapcache/tms/1.0.0/test@UTM32",
-	URL_BACKGROUND_AERIAL:	"http://geo4.service24.rlp.de/wms/dop_basis.fcgi"
+	URL_BACKGROUND_AERIAL:	"http://geo4.service24.rlp.de/wms/dop_basis.fcgi",
+	URL_FEATURE_INFO_PROXY:	"./scripts/proxy.php"
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2018-03-19 16:38:14 UTC (rev 9885)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/layers.js	2018-03-20 08:40:33 UTC (rev 9886)
@@ -72,7 +72,7 @@
 					netgis.config.URL_WMC_PROXY,
 						//q: encodeURI( "http://www.geoportal.rlp.de/mapbender/php/mod_exportWmc2Json.php?wmc_id=" + id + "&epsg=" + netgis.config.MAP_PROJECTION.split( ":" )[ 1 ] + "&withHierarchy=1" )
-						q: encodeURI( url )
+						q: encodeURIComponent( url )
 					onWmcResponse
@@ -101,7 +101,7 @@
 					netgis.config.URL_LAYERS_PROXY,
 						//q: encodeURI( "http://www.geoportal.rlp.de/mapbender/extensions/mobilemap/mod_mapbender/search_proxy.php?languageCode=de&resultTarget=web&maxResults=40&resourceIds=" + ids.join( "," ) )
 					onLayersResponse
Modified: trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js
--- trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-03-19 16:38:14 UTC (rev 9885)
+++ trunk/mapbender/http/extensions/mobilemap2/scripts/netgis/map.js	2018-03-20 08:40:33 UTC (rev 9886)
@@ -651,7 +651,8 @@
 					source:	source,
-					zIndex: index
+					zIndex: index,
+					opacity: netgis.config.MAP_DEFAULT_OPACITY
@@ -916,7 +917,7 @@
 							view.getResolution(),
 							netgis.config.MAP_PROJECTION,
-								"INFO_FORMAT": "text/html" //"text/plain" //"text/javascript" //"application/json" //"text/html"
+								"INFO_FORMAT": "text/html" //"text/plain" //"text/javascript" //"application/json" //"text/html",
@@ -931,12 +932,17 @@
 							content += "<div class='panel panel-primary'>";
 							content += "<div class='panel-heading clickable' data-toggle='collapse' data-target='#" + panelId + "'>";
-							content += "<h4 class='panel-title'>" + layer.components.title.value + "</h4>";
+							content += "<h4 class='panel-title'>" + layer.components.title.value + "<span class='pull-right glyphicon glyphicon-share' title='In neuem Tab öffnen'></span></h4>";
 							content += "</div>";
+							var frame_url = url;
+							if ( netgis.config.URL_FEATURE_INFO_PROXY && netgis.config.URL_FEATURE_INFO_PROXY.length > 0 )
+								frame_url = netgis.config.URL_FEATURE_INFO_PROXY + "?q=" + encodeURIComponent( url );
 							content += "<div id='" + panelId + "' class='panel-collapse collapse'>";
 							content += "<div class='panel-body'>";
-							content += "<iframe seamless width='280' height='100' src='" + url + "'></iframe>";
+							content += "<iframe seamless width='280' height='100' src='" + frame_url + "'></iframe>";
@@ -945,8 +951,19 @@
 							var element = $( content );
-							element.find( ".panel-heading" ).click( function() { element.find( "#" + panelId ).collapse( "toggle" ); } );
+							var heading = element.find( ".panel-heading" );
+							heading.click( function() { element.find( "#" + panelId ).collapse( "toggle" ); } );
+							heading.find( ".pull-right" ).click
+								function( evt )
+									evt.stopPropagation();
+									window.open( url, "_blank" );
 							popupContent.append( element );
@@ -1005,6 +1022,7 @@
 							zIndex: 999,
+							opacity: netgis.config.MAP_DEFAULT_OPACITY,
 							style: onKmlStyle
More information about the Mapbender_commits mailing list
