[Mapbender-commits] r10291 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 18 06:05:05 PDT 2019
Author: armin11
Date: 2019-10-18 06:05:04 -0700 (Fri, 18 Oct 2019)
New Revision: 10291
   trunk/mapbender/http/plugins/mb_metadataApplication.php
Define textarea for metadata abstract
Modified: trunk/mapbender/http/plugins/mb_metadataApplication.php
--- trunk/mapbender/http/plugins/mb_metadataApplication.php	2019-10-18 12:23:11 UTC (rev 10290)
+++ trunk/mapbender/http/plugins/mb_metadataApplication.php	2019-10-18 13:05:04 UTC (rev 10291)
@@ -62,7 +62,7 @@
 	    </fieldset>
 	    <fieldset>
 		<legend><?php echo _mb("Resource abstract");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("This is a brief narrative summary of the content of the resource."); echo " "._mb("HTML encoding may be used!");?>'}" src="../img/questionmark.png" alt="" /></legend>
-		<input class="required" name="abstract" id="abstract"/>
+		<textarea rows="7" cols="50" class="required" name="abstract" id="abstract"/>
 	    </fieldset>
 	    <fieldset id="referencesystem">
@@ -84,7 +84,7 @@
 	</div>
         <div id="tabs-2">
 	    <?php $user = new User();?>
-	    <?php $guis = $user->getApplicationsByPermission($ignorePublic = false, 2);?>
+	    <?php $guis = $user->getApplicationsByPermission(false, 2);?>
 	    <fieldset id="gui_select_fieldset">
 	        <legend><?php echo _mb("GUI ID");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("ID of mapbenders internal GUI which should be used to build the application metadata.");?>'}" src="../img/questionmark.png" alt="" /></legend>
 	        <select class="gui_selectbox" id='fkey_gui_id' name='fkey_gui_id'>
@@ -98,7 +98,7 @@
 	        </select>
 	    </fieldset>
-	    <?php $wmcs = $user->getWmcInfoByOwner($ignorePublic = false);?>
+	    <?php $wmcs = $user->getWmcInfoByOwner(false);?>
 	    <fieldset id="wmc_select_fieldset">
 	        <legend><?php echo _mb("My public WebMapContext documents");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("ID of my WMC that should be loaded in the GUI above to define an special application.");?>'}" src="../img/questionmark.png" alt="" /></legend>
 	        <select class="wmc_selectbox" id='fkey_wmc_serial_id' name='fkey_wmc_serial_id'>
More information about the Mapbender_commits mailing list
