[Mapbender-commits] r10292 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Oct 20 21:50:38 PDT 2019
Author: armin11
Date: 2019-10-20 21:50:37 -0700 (Sun, 20 Oct 2019)
New Revision: 10292
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Fix for portaladmin_de gui problem - thanx to karlo ;-)
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2019-10-18 13:05:04 UTC (rev 10291)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2019-10-21 04:50:37 UTC (rev 10292)
@@ -2904,4 +2904,8 @@
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_application_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+--PortalAdmin_DE fix older update for newer versions of gui - thanx to karlo
+UPDATE gui_element SET e_target = 'editMaintenance_collection, reindexWMS_collection,reindexWFS_collection,reindexDATASET_collection,reindexWMC_collection,Start_Monitor_for_WMS_collection,CSW_collection' WHERE fkey_gui_id = 'PortalAdmin_DE' AND e_id = 'menu_maintenance';
More information about the Mapbender_commits mailing list
