[Mapbender-dev] JS exceptions
Christoph Baudson christoph.baudson at wheregroup.com
Thu Jan 11 06:01:20 EST 2007
Hi there,
when thinking about a return value for Mapbender JS exceptions, I
encountered the following problem. Maybe I'm missing a central, please
enlighten me:
when I call the JS class Mb_exception, I'll fire the Ajax post function.
  The callback function is invoked, but it can't return the value to the
original caller, because that's in a different function.
see http://www.mapbender.org/index.php/Talk:For_developers#return_value
Another solution might be to set a member variable of the class (boolean
$exceptionThrown); but again, because of the asynchronous nature of
Ajax, this would not work because I would want a return value in the JS
code rightaway.
Any ideas?
Christoph
Christoph Baudson schrieb:
 > Hello again,
 >> Thats nice. Is the online browsable version of the SVN-repository
down at the moment?
 > The link at mapbender.orgeo.org has definitely been removed, but I
have no further information. In the meantime you can only view the plain
text at
 > https://mapbender.osgeo.org/svn/mapbender/
 >> For the discussed action (loggin of an exception), all of the above
mentioned things would work well... I'd choose the simplest thing by
echoing the status as 'true' or 'false'
 > Yes, that's what I had in mind as well. I guess that's what I'll do.
 >> The JSON-thing would be wonderful, too. Some additional properties
could be returned as string literal of an object, e.g. {loggingresult:
'true', loggingdate: '2007-01-09', ...}, eval'ed, and could be used
afterwards.
 > Interesting, I will keep this in mind. JSON is very powerful and it
might become handy in the future.
 > Thanks, Christoph
 > Mapbender_dev mailing list
 > Mapbender_dev at lists.osgeo.org
 > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
