[Mapbender-dev] JS exceptions
Marc Jansen jansen.marc at gmx.de
Thu Jan 11 06:28:36 EST 2007
Christoph Baudson schrieb:
> Hi there,
> when thinking about a return value for Mapbender JS exceptions, I
> encountered the following problem. Maybe I'm missing a central, please
> enlighten me:
> when I call the JS class Mb_exception, I'll fire the Ajax post
> function.  The callback function is invoked, but it can't return the
> value to the original caller, because that's in a different function.
> see http://www.mapbender.org/index.php/Talk:For_developers#return_value
Hey Christoph,
try this (untested as usual):
function Mb_exception(message) {
	return mb_ajax_post('../php/mb_js_exception.php', {text:message}, function(text, status){
		return (text == "true") ? true : false;
note the first return before the function.
> Another solution might be to set a member variable of the class
> (boolean $exceptionThrown); but again, because of the asynchronous
> nature of Ajax, this would not work because I would want a return
> value in the JS code rightaway.
> Any ideas?
> Christoph
More information about the Mapbender_dev mailing list
