[Mapbender-dev] treefolder2
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Tue Jan 30 06:14:35 EST 2007
Fast, faster, Melchior. ;-)
Works great! But where is the nice little function-button for each layer (the litte grey button with the blue arrow)? Or did I something wrong?
> -----Ursprüngliche Nachricht-----
> Von: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
> Melchior Moos
> Gesendet: Montag, 29. Januar 2007 21:23
> An: Mapbender Developer List
> Betreff: Re: [Mapbender-dev] Test of RC1 / some thoughts
> Hi Marko,
> thanks for reporting the problems, I have made a svn
> commitment that corrects the points you mentioned:
> > 3. The treefolder2 modul
> > Really a very nice improvement of the MB. But 2 questions or ideas:
> >     -what is the element_var "menu". In the
> mod_treefolder2.php script, menu is set to:
> menu="wms_up,wms_down,remove,layer_up,layer_down,metainfo,zoom
> ,hide";.  So it seems to be the menu for the wms-layers. But
> is it possible to configure it with an element_var entry? I
> tried to configure it by deleting the two last options
> "zoom,hide" directly at the script, but the effect was, that
> I just had the moveup and movedown option anymore. Is there a
> solution, how to configure it right?
> I removed the line, now the element var should work as
> described in the mapbender wiki:
> http://www.mapbender.org/index.php/Menu
> >     - isn't it possible to leave the wms-layer-tree open,
> after moving a layer of a wms up or down? That would improve
> this already very nice module!
> Now the layer you moved yould be selected and the original
> tree state should be restored.
> best regards,
> Melchior
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
