[Mapbender-dev] [Mapbender] #117: Adding WMS (module AddWMS) does not automatically make added layer(s) visible
Mapbender info at osgeo.org
Fri Oct 12 06:05:46 EDT 2007
visible
 Reporter:  lieuwe          |       Owner:  mapbender_dev at lists.osgeo.org
     Type:  enhancement     |      Status:  new
 Priority:  major           |   Milestone:
Component:  administration  |     Version:  2.4.3
 Keywords:  WMS treeGDE     |
 It would so much be user-friendlier when adding a WMS on runtime that the
 layer(s) automatically be visible. Now you must explicitly (via treeGDE)
 set the visibilty status on to make the layer(s) visible.
 Are there any Mapbender javascript functions available to set layers
 visible when i dynamically add  a WMS?
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/117>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
