AW: [Mapbender-dev] treeGDE2: opacity
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Wed Oct 24 08:59:03 EDT 2007
Hi Michael,
Have the same behaviour at my fresh installed 2.4.3 Version. Additional, I have problems with IE6 and IE7 and the opacity. Is this the "normal" png transparent problem behaviour? Thought that ms would have fixed it in IE7?
CU,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Michael Schulz
Gesendet: Mittwoch, 24. Oktober 2007 14:48
An: Mapbender Developer List
Betreff: [Mapbender-dev] treeGDE2: opacity
with a fresh mapbender 2.4.3 installation we have the following problem:
When opacity_up/down is enabled for the treegde2, and you click the first time on "opacity down" for a certain wms, the opacity is lowered to 0 aka the map is fully transparent. Subsequent clicks on opacity up/down behave normally, i.e. raising/lowering the opacity by steps of 20%.
Is this the intended behaviour?
I can't test this on mapbender.telascience since the test login doesn't work, but if anyone else could test this and report, I'll open a ticket for it.
Cheers, Michael
Michael Schulz
mschulz at webgis.de
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
Mapbender_dev mailing list
Mapbender_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
