[Mapbender-dev] treeGDE2: opacity
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu Oct 25 09:09:06 EDT 2007
Michael Schulz schrieb:
> Hi,
> with a fresh mapbender 2.4.3 installation we have the following problem:
> When opacity_up/down is enabled for the treegde2, and you click the
> first time on "opacity down" for a certain wms, the opacity is lowered
> to 0 aka the map is fully transparent. Subsequent clicks on opacity
> up/down behave normally, i.e. raising/lowering the opacity by steps of
> 20%.
> Is this the intended behaviour?
> I can't test this on mapbender.telascience since the test login
> doesn't work, but if anyone else could test this and report, I'll open
> a ticket for it.
> Cheers, Michael
I'm pretty sure this is a bug; please feel free to add a ticket (and a
patch? ;-))
Thanks
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
