[Mapbender-dev] Re: [Mapbender] #129: mixed up wfs_conf_ids
Mapbender info at osgeo.org
Fri Oct 26 09:33:31 EDT 2007
  Reporter:  christoph  |       Owner:  mapbender_dev at lists.osgeo.org
      Type:  defect     |      Status:  closed
  Priority:  critical   |   Milestone:  2.5 release
 Component:  wfs        |     Version:  2.4.3
Resolution:  fixed      |    Keywords:
Comment (by christoph):
 1) To download the patch, follow the link "patch_129.txt", '''DO NOT
 RIGHT-CLICK AND DOWNLOAD'''! This will download the HTML site you see when
 you follow the link. Download at the bottom of that page, "Download in
 other formats: Original Format"
 2) To apply the patch, use Eclipse and follow these instructions
 http://www.mapbender.org/index.php/Release_guide#applying_a_patch
 If you know how to apply the patch via command line, let me know because I
 have never done that and I'm curious.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/129#comment:3>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
