[Mapbender-dev] i18n: LC_CTYPE vs LC_ALL
Michael Schulz mschulz at webgis.de
Fri Aug 1 07:27:47 EDT 2008
Hi Christoph,
just trying to set locale with LC_CTYPE instead of LC_ALL (in
class_locale.php:103). It works for the GUI tooltips and tabs, but not
for the print module... This looks at if it works for things happening
in the mainframe, but not for the content of seperate iframes.
Just to let you know, maybe you can verify this behaviour.
Cheers, Michael
2008/7/29 Michael Schulz <mschulz at webgis.de>:
> Hi Chirstoph,
> no objections. Another way would be to leave LC_ALL and additionally
> set the LC_NUMERIC locale to "C".
> This solves the decimal point problem, and leaves the rest untouched.
> I have no favorite, but also can't really overlook implications of
> either change. I have successfully tried the second method with
> changeEPSG module, i.e. the translation and calculation - still having
> some overall functionality problems :-)
> Cheers, Michael
> 2008/7/29 Christoph Baudson <christoph.baudson at wheregroup.com>:
>> Here's an important issue that needs to be resolved before the release of
>> 2.5: replace LC_ALL by LC_CTYPE?
>> http://trac.osgeo.org/mapbender/ticket/262
>> I guess we stick to LC_CTYPE then? Any objections?
>> _______________________________________
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev mailing list
