[Mapbender-dev] i18n: LC_CTYPE vs LC_ALL
Christoph Baudson christoph.baudson at wheregroup.com
Mon Aug 4 07:33:44 EDT 2008
I think we only need LC_MESSAGES. Taking a closer look I realized that
the folder in /resources/locale is named "LC_MESSAGES" as well, so it
corresponds to the setting in setlocale. Will commit later.
FYI: Another thing I found out, that Mapbender.mo is somehow cached.
After recompiling it, my new entries didn't show. Restarting Apache
resolved that issue.
Christoph
Michael Schulz schrieb:
> Hi Christoph,
> just trying to set locale with LC_CTYPE instead of LC_ALL (in
> class_locale.php:103). It works for the GUI tooltips and tabs, but not
> for the print module... This looks at if it works for things happening
> in the mainframe, but not for the content of seperate iframes.
> Just to let you know, maybe you can verify this behaviour.
> Cheers, Michael
> 2008/7/29 Michael Schulz <mschulz at webgis.de>:
>> Hi Chirstoph,
>> no objections. Another way would be to leave LC_ALL and additionally
>> set the LC_NUMERIC locale to "C".
>> This solves the decimal point problem, and leaves the rest untouched.
>> I have no favorite, but also can't really overlook implications of
>> either change. I have successfully tried the second method with
>> changeEPSG module, i.e. the translation and calculation - still having
>> some overall functionality problems :-)
>> Cheers, Michael
>> 2008/7/29 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>> Here's an important issue that needs to be resolved before the release of
>>> 2.5: replace LC_ALL by LC_CTYPE?
>>> http://trac.osgeo.org/mapbender/ticket/262
>>> I guess we stick to LC_CTYPE then? Any objections?
>>> _______________________________________
>>> W h e r e G r o u p GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Christoph Baudson
>>> Anwendungsentwickler
>>> Fon: +49 (0)228 / 90 90 38 - 15
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Arnulf Christl, Olaf Knopp, Peter Stamm
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Michael Schulz
>> in medias res
>> Gesellschaft für Informationstechnologie mbH
>> In den Weihermatten 66
>> 79108 Freiburg
>> Tel +49 (0)761 556959-5
>> Fax +49 (0)761 556959-6
>> http://www.webgis.de / http://www.zopecms.de
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev mailing list
