[Mapbender-dev] VSP Module
Christoph Baudson christoph.baudson at wheregroup.com
Thu Aug 14 09:12:11 EDT 2008
Aqua Miracle schrieb:
> Dear all developers.
> I need to submit variable (ex.qdate='2008-01-01') to mapfile (%qdate%
> has setup in the mapfile) before Adding WMS to display in mapbender
> environment.
> Can anyone pls. give me an example how to modify the file (which
> file?? map.js??)
Hello,
can you please be more specific? I have no idea what you are trying to
do. I will help as best as I can as soon as I have understood your problem.
Thanks
Christoph
> I read the thread but I could not get idea how to do it. Pls. Pls. help.
> Thanks,
> AQ.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
