[Mapbender-dev] i18n revisited
Christoph Baudson christoph.baudson at wheregroup.com
Wed Aug 20 09:34:28 EDT 2008
Hi there
today I realized that the concept for db translations is still not good
I had the scenario where I had texts I wanted to translate in table "a".
I wanted to add these texts to the translations table. However, I can't
add a foreign key to table "a", as the msgid column is not unique in
We should therefore think about splitting the table translations
table: translation_key
columns: id, msgid
table translation_values
columns: fkey_translation_key_id, locale, msgstr
No doubt, this will also save a lot of db space, as you would not store
the msgid again for each translation.
I think we should prepare this for version 2.6. The gettext function
would change, nothing else. We would of course have to supply an update
SQL, but this will be easy with spsneos script.
Please correct me if I'm wrong.
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Christoph Baudson
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
Amtsgericht Bonn, HRA 6788
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
