[Mapbender-dev] motion: change file system layout
Christoph Baudson christoph.baudson at wheregroup.com
Tue Jul 1 04:47:16 EDT 2008
As most of Mapbender's recent security issues stem from files being
unnecessarily in the http folder, I think we should move as many files
as possible out of that directory. Only files which are really loaded
via http should remain there.
<motion>
I motion to
- move the PHP classes from /http/classes to /lib (and remove the prefix
"class_"). We can keep wrappers for the sake of backwards compatibility
(an old class file would only include a new class file).
- move the external libraries from /http/extensions to /ext
- create a folder /mod which holds a folder for each module (example:
/mod/mapframe1). Move files from /http/php and /http/javascripts to
these folders
in Mapbender 2.6 (est. release date Sep 15, 2008)
</motion>
I already have a working experimental version in /branches/testbaudson_dev.
The rest will remain untouched now, but will be moved to the new folders
later on (there is no need for http/frames, http/html, http/include,
http/print). I'm not sure how to deal with http/javascripts and
http/php, maybe we should have a http/mod folder as well? I'm also not
sure about /http/sld.
This approach also helps to
- isolate modules from the core
- optimize the core
- remove deprecated modules
- exchange modules
For customizations, we recommended to add a folder /http/x_<project
name> in the past. This folder could be replaced by folders mod/<project
name>_<module name>. This would help us to integrate modules developed
for specific scenarios into the Mapbender generic development, and also
to update overwhelmingly customized Mapbenders. Sustainability is the
keyword.
Christoph
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
