[Mapbender-dev] motion: change file system layout
Thomas Baschetti Thomas.Baschetti at gmx.de
Mon Jul 7 11:50:16 EDT 2008
i think it's really important to clean up the file system structure.
Christoph Baudson schrieb:
> As most of Mapbender's recent security issues stem from files being
> unnecessarily in the http folder, I think we should move as many files
> as possible out of that directory. Only files which are really loaded
> via http should remain there.
> <motion>
> I motion to
> - move the PHP classes from /http/classes to /lib (and remove the prefix
> "class_"). We can keep wrappers for the sake of backwards compatibility
> (an old class file would only include a new class file).
> - move the external libraries from /http/extensions to /ext
> - create a folder /mod which holds a folder for each module (example:
> /mod/mapframe1). Move files from /http/php and /http/javascripts to
> these folders
> in Mapbender 2.6 (est. release date Sep 15, 2008)
> </motion>
> I already have a working experimental version in /branches/testbaudson_dev.
> The rest will remain untouched now, but will be moved to the new folders
> later on (there is no need for http/frames, http/html, http/include,
> http/print). I'm not sure how to deal with http/javascripts and
> http/php, maybe we should have a http/mod folder as well? I'm also not
> sure about /http/sld.
> This approach also helps to
> - isolate modules from the core
> - optimize the core
> - remove deprecated modules
> - exchange modules
> For customizations, we recommended to add a folder /http/x_<project
> name> in the past. This folder could be replaced by folders mod/<project
> name>_<module name>. This would help us to integrate modules developed
> for specific scenarios into the Mapbender generic development, and also
> to update overwhelmingly customized Mapbenders. Sustainability is the
> keyword.
> Christoph
More information about the Mapbender_dev mailing list
