[Mapbender-dev] motion: change file system layout
Michael Schulz mschulz at webgis.de
Thu Jul 10 07:31:03 EDT 2008
also +1 for file system restructuring
Maybe we can discuss customization structure a little bit more. At the
moment we have the path and the name to the module referenced in
corresponding gui_element fields. When customization of modules occur,
we have to change the path and or names of the modules. This can
become cumbersome if you have a lot of projects on one mapbender
installation. What about a hierachical include mechanism, where you
can specify additional path(s) (eg. ./mod/projectname/ or ./plugin/ in
addition to ./mod/) that are searched for the module and if not found
the default mod dir is used. This could be gui wide and would lead to
only have the modulenames in the gui_element fields.
Cheers, Michael
2008/7/8 Samson, Marko <Marko.Samson at wald-und-holz.nrw.de>:
> +1 to the new filesystem structure.
> And I like the additions of Melchior.
> Viele Grüße,
> Marko Samson
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Tel.:   0251/91797-166(Montags)
>        05771/913455(Freitags)
> Mail: marko.samson at wald-und-holz.nrw.de
>> -----Original Message-----
>> From: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
>> Melchior Moos
>> Sent: Monday, July 07, 2008 9:25 PM
>> To: Mapbender Developer List
>> Subject: Re: [Mapbender-dev] motion: change file system layout
>> +1 I like the idea of a more structured filesystem.
>> Why not add a plugin/  directory which has the same function
>> as the mod directory but contains all modules the are not
>> shipped with mapbenders standard installation? This would
>> lead (in theory) to a clear division between customations and
>> core code. This would be the place where the <project
>> name>_<module name> modules would be.
>> Christoph Baudson schrieb:
>> > As most of Mapbender's recent security issues stem from files being
>> > unnecessarily in the http folder, I think we should move as
>> many files
>> > as possible out of that directory. Only files which are
>> really loaded
>> > via http should remain there.
>> > <motion>
>> > I motion to
>> > - move the PHP classes from /http/classes to /lib (and remove the
>> > prefix "class_"). We can keep wrappers for the sake of backwards
>> > compatibility (an old class file would only include a new
>> class file).
>> > - move the external libraries from /http/extensions to /ext
>> > - create a folder /mod which holds a folder for each module
>> (example:
>> > /mod/mapframe1). Move files from /http/php and /http/javascripts to
>> > these folders
>> > in Mapbender 2.6 (est. release date Sep 15, 2008) </motion>
>> > I already have a working experimental version in
>> > /branches/testbaudson_dev.
>> > The rest will remain untouched now, but will be moved to the new
>> > folders later on (there is no need for http/frames, http/html,
>> > http/include, http/print). I'm not sure how to deal with
>> > http/javascripts and http/php, maybe we should have a
>> http/mod folder
>> > as well? I'm also not sure about /http/sld.
>> > This approach also helps to
>> > - isolate modules from the core
>> > - optimize the core
>> > - remove deprecated modules
>> > - exchange modules
>> > For customizations, we recommended to add a folder /http/x_<project
>> > name> in the past. This folder could be replaced by folders
>> > mod/<project name>_<module name>. This would help us to integrate
>> > modules developed for specific scenarios into the Mapbender generic
>> > development, and also to update overwhelmingly customized
>> Mapbenders.
>> > Sustainability is the keyword.
>> > Christoph
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
