[Mapbender_dev] development of debian package
Abhishek Singh singhabhishek.bit at gmail.com
Mon Jul 19 02:36:40 EDT 2010
Hi Lars,
I am listing down the most convincing directory structure for mapbender
package as per my opinion.
------+etc
         |__mapbender(apache.conf)
                     |__sites
                            |__default(settings.php/default)
-----+usr
        |__share
        |      |__doc
        |            |__mapbender
        |                       |__examples
        |__mapbender
                    |__includes(mapbender.conf)
------+var
       |__lib
             |__mapbender
                        |__backup
                        |__files
                        |__extensions
Cheers,
Abhishek Kumar Singh
BE/1349/2007
Information Technology
7th SEMESTER
BIT MESRA
On Mon, Jul 19, 2010 at 11:39 AM, Lars Lingner <ml at lingner.eu> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello Mapbender devs,
> I had an IRC session with abhishek_singh last week about help on the
> debian package he is working in.
> I had a look at the drupal and mediawiki packages already available and
> tried to package Mapbender the same way. For MapServer I used to use
> checkinstall [1] to create .deb and .rpm packages. But for Mapbender a
> lot of more configuration is involved like the whole database setup and
> checkinstall doesn't cover that AFAIK.
> Unfortunately it is really to much time to read through all the docu for
> dh_* tools and dpkg-*
> I also stumbled up on some troubles with my setup, so I highly recommend
> doing the build process on a clean (vm-)machine.
> The current problem, I have no solution for, is that its not clear how
> the directory structure should look like and how its populated to be
> used as source for the build scripts.
> So far no solution from me. If I have spare time I'll take a further
> look but no promises when this will be ;)
> Lars
> [1] http://www.asic-linux.com.mx/~izto/checkinstall/
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAkxD7CEACgkQ0GRF77ebR/kajgCffl9HGG2BTKbLjGtkySqejHh1
> sk0AoKmGM/D03i+PgCbaERp9HkbV5lna
> =fLOU
> -----END PGP SIGNATURE-----
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100719/f961e2d9/attachment.html
More information about the Mapbender_dev mailing list
