[Mapbender_dev] mental notes on installation shell script
Astrid Emde astrid.emde at wheregroup.com
Wed Jul 21 12:10:52 EDT 2010
Hello Christoph,
your suggestions sound good.
On Wed, July 21, 2010 3:04 pm, Christoph Baudson (Wheregroup) wrote:
> Hello developers,
> here are some mental notes on the installation script
> (resources/db/install.sh). we could
> - copy mapbender.conf-dist to mapbender.conf
good idea
although we should ask the user, whether to create the file, as sometimes
I just want to create a new database and already have a mapbender.conf
file.
> - add database information to mapbender.conf (via sed). The values are
> already being read from command line - concatenate all relevant SQLs into
> one temporary file via cat (the password is only requested once if a
> single file is executed, and not n times)
good idea
> I'm not sure how this would work under Windows.
should work with windows aswell.
> These additions might seem trivial, but would make an installation even
> less work.
yes, yes.
Does someone volunteers to integrate the enhancements?
Best regards Astrid
FOSS4G 2010
6.-9. September 2010 in Barcelona
http://2010.foss4g.org/
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
