[Mapbender_dev] mental notes on installation shell script
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Jul 23 05:34:44 EDT 2010
Thanks for your comments. I have updated the install shell script for
2.6.2, please take a look at [1], maybe do a test run, and let me know if
you want to make any changes. Otherwise I'll be using the installer in
2.6.2. As I'm in a bit of a hurry with 2.6.2, please do so right now (or
trust me, which is second best).
Christoph
[1] http://trac.osgeo.org/mapbender/changeset/6618/branches
On Wed, July 21, 2010 7:24 pm, Thomas Baschetti wrote:
> Hi,
> On 21.07.2010 18:10, Astrid Emde wrote:
>> Hello Christoph,
>> your suggestions sound good.
>> On Wed, July 21, 2010 3:04 pm, Christoph Baudson (Wheregroup) wrote:
>>> Hello developers,
>>> here are some mental notes on the installation script
>>> (resources/db/install.sh). we could
>>> - copy mapbender.conf-dist to mapbender.conf
>> good idea
>> although we should ask the user, whether to create the file, as
>> sometimes
>> I just want to create a new database and already have a mapbender.conf
>> file.
> we already do this:
> # creating mapbender.conf
> if [ -f ../../conf/mapbender.conf ]
> then
> echo "mapbender.conf already exists, not changed"
> else
> cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
> fi
> echo ""
> echo "please check and edit the entries in your mapbender.conf
> manually!"
>>> - add database information to mapbender.conf (via sed). The values are
>>> already being read from command line - concatenate all relevant SQLs
>>> into
>>> one temporary file via cat (the password is only requested once if a
>>> single file is executed, and not n times)
>> good idea
> but...
>>> I'm not sure how this would work under Windows.
>> should work with windows aswell.
> ...sorry, no sed with windows.
>>> These additions might seem trivial, but would make an installation even
>>> less work.
>> yes, yes.
>> Does someone volunteers to integrate the enhancements?
> /me is ducking and hiding, no space left on device this week...
> (and i owe you a webinstaller anyway so i keep calm ond hope nobody
> notices)
> Ciao
> Thomas
> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D
> 49074 Osnabrück
> Tel: 0541 25 91 90 | mobil 01577 189 25 91
> E-Mail: info at thomas-baschetti.de
> www.thomas-baschetti.de
> Ust-IdNr.: DE264355072
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
