[Mapbender-dev] [Mapbender] #629: bad "openfolder" kills the gui
Mapbender mapbender_dev at lists.osgeo.org
Thu Mar 25 12:09:53 EDT 2010
 Reporter:  frankjaeger  |       Owner:  dev
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  2.7 release
Component:  treeGDE      |     Version:  2.5.1
 Keywords:  openfolder   |
 If the value of the element-var "openfolder" of treeGDE is bigger then the
 count of wms in the gui, than the gui can not load: no overview, no
 This can happen, after some wms are removed from a gui.
 It is very difficult for the admin to find the reason. You can spend ours
 to find this element-var as the root of eval.
 Please check on Load:
  if openfolder > max-wms
    then ignore openfolder
 Alternatively check it on setting the value of the element-var '''and'''
 check it when removing a wms and when treeGDE is copied from an other gui.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/629>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
