[Mapbender-users] Dynamic Add a WMS
Arnulf Christl arnulf.christl at wheregroup.com
Fri Feb 23 04:27:30 EST 2007
joscha.ma at web.de wrote:
> Hermann Tugholz wrote:
>> Hi,
>> is it possible to add a WMS dynamically by submitting the capabilities URL
>> via HTTP Post or something similar? I would like to dynamical create a
>> "Client" for a given capabilities URL without having to add it via the add
>> button in the client or adding it as an administrator.
>> Thanks!
>> Hermann
> Hi,
> Genau das gleiche würde mich auch interessieren. Ich möchte noch hinzufügen, dass man die URL ja vielleicht irgendwie beim Login mit angeben können müsste oder irgendwie per JavaScript übergeben kann. Weiss da jemand etwas genaueres?
> I would be interested in the exact same thing. I would like to add, that it might/should be possible to pass a URL to mapbender with the login or somehow with JavaScript. Does anybody knows anything specific here?
> Viele Grüße,
> Joscha
Did you try to use Web Map Context documents? It is a little tedious but would be the cmost comprehensive solution to your problem. This is how new services and layers are added to the Mapbender instance of the Geoportal-RLP (http://www.geoportal.rlp.de). Most of the code of that solution has already merged into core and is currently available for testing as 2.4.1 rc1
Best regards,
More information about the Mapbender_users mailing list
