[Mapbender-users] problem with wfs search
    Christoph Baudson
    christoph.baudson at wheregroup.com
    Fri Jul 18 03:13:01 EDT 2008
Karsten Vennemann schrieb:
> Nobody any idea what could be wrong?
> I can't get it to work.
> Karsten
This is the SQL that gets your configured WFS:
SELECT * FROM wfs_conf_element JOIN wfs_element ON wfs_conf_element.f_id
= wfs_element.element_id WHERE wfs_conf_element.fkey_wfs_conf_id = $1
AND wfs_conf_element.f_show = 1 ORDER BY wfs_conf_element.f_respos;
You may not have checked the "show" field. If it is checked, you have to
find out if the client sends the WFS conf IDs to the server, see
Firebug's entry under POST. If it's missing it has to be specified as an
PHP element var (wfsConfIdString).
Let us know if you find the solution or need additional help,
Christoph
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
