[Mapbender-users] Re:Re: Mapbender's wfs-t abilities
Albrecht.Weiser at hzd.hessen.de Albrecht.Weiser at hzd.hessen.de
Mon Jul 21 04:52:59 EDT 2008
> Albrecht.Weiser at hzd.hessen.de wrote:
> > Hi List,
> > i want to test a client which is able to perform as a wfs-t
> client. It
> > should be able to set a point (in case of a point feature)
> and  to open
> > a featureType attribute table mask in which i can edit the
> newly created
> > point's attributes (and then save it back).
> > I know that mapbender is able to act as a wfs-t client
> (means it saves
> > the point to the database), but does it do the latter issue
> too? Can i
> > edit the attributes of the created feature too? Does
> somebody have some
> > experiences with that?
> > Thanks
> > Albrecht
> Hi Albrecht,
> yes, Mapbender can insert, update and delete WFS-T features since
> roughly two years and is used in productive environments. You
> can check
> the digitizing WFS-T functionality on several demo portals.
> Find an older version here:
> http://wms.wheregroup.com/mapbender/
> Log in as test / test and select "gui_digitize" from the list.
> The default user interface has not been optimized - its ugly. :-)
> To select a feature use the buttons on the top right. The
> objects will
> be displayed in the lower left section. Then use the buttons
> under the
> digitize tab (opens at the start) to edit features.
> Best regards,
> Arnulf
Hi Arnulf,
for me the interface looks good. Maybe an artist would do it better ;o)
It worked fine for me. Does this table for editing the attributes appear
by default when saving the digitized feature or do i have to configure
mapbender (or even implement it myself)?
Best regards
Albrecht
More information about the Mapbender_users mailing list
