AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial images
Kai Behncke Kai-Behncke at gmx.de
Tue Jun 17 10:06:02 EDT 2008
Hi Michael, thank you.
You mean you made it somehow to integrate 24bit pngs in the Mapbender-Print?
Great, but what exactly did you do?
Well, at "WMS Gui Enstellungen" in Mapbender I choose "image/png; mode=24 bit".
In the WebGIS it looks fine but in the print everything else than that.
How did you define the OUTPUTFORMAT?
I tried it with:
MAP
NAME           'luftbilder'
STATUS ON
IMAGETYPE     PNG
EXTENT        3595000 5904140  3621500  5919000
UNITS          METERS
SIZE        500 500
 IMAGECOLOR 255 255 255
SHAPEPATH   	'/home/deichbau/daten/luftbilder'
OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGB
  EXTENSION "png"
END
....but the result is not what I want.
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Tue, 17 Jun 2008 15:33:15 +0200
> Von: "Michael Schulz" <mschulz at webgis.de>
> An: "Mapbender User List" <mapbender_users at lists.osgeo.org>
> Betreff: Re: AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial	images
> Hi Marc, Kai,
> I think Marc is right: Kai, your pretty surely using jpeg for aerial
> images, but the pdf print code sets the format to png
> (classweldmaps2png.php, line 49). I never had problems using 24bit
> png's, so perhaps Kai can set an outputformat png with rgb, in order
> to avoid the usual mapserver "png; 24bit" format. Then you should get
> good looking (huge) aerial images in the pdf.
> Cheers, Michael
> Am 17. Juni 2008 15:00 schrieb Marc Jansen <jansen.marc at gmx.de>:
> > Hi Kai,
> > could you post  the FORMAT-Parameter (png, gif, etc.)  which you
> request?
> > AFAIK the PDF-lib used in Mabender is incapable of 24bit-PNGs (enabled
> e.g.
> > with IMAGEMODE RGB in UMN Mapserver). Furthermore, your problem
> description
> > makes me think of a JPEG which is transformed to a PNG when adding to
> the
> > PDF. But that is pure guessing.
> > -- Marc
> > Hi Kai,
> > könnntest Du den Parameter FORMAT (png, gif, etc.) mal an die Liste
> senden?
> > Sowei ich weiß kann die vomn Mapbender verwendete PDF-lib nicht mit 24
> bot
> > PNGs unmgehen (im UMN Mapserver z.B. via IMAGEMODE RGB
> bereitgestelllt),.
> > Die Problembeschreibung könnte allerdings auch (hier rate ich) auf ein
> JPEG
> > hindeuten, welches vom PDF-Module bei einbettung in das PDF in ein PNG
> > umgewandelt wird. (weldMapsToPng).
> > -- Marc
> > Kai Behncke schrieb:
> >> Hi Markus,
> >>> ich habe mich selbst noch nicht ausgiebig damit beschäftigt. Es gibt
> aber
> >>> beim Mapbender das Druckmodul, bei dem man die Auflösung (dpi)
> einstellen
> >>> kann, mit der das Bild für den Druck angefordert wird (Für den Druck
> >>> benötigt man in der Regel höhere Auflösungen als für den
> Bildschirm).
> >>> Man
> >>> muss dabei nur gewährleisten, dass der Mapserver die hohe Auflösung
> >>> bringt,
> >>> ansonsten gibt es eine weiße Seite.
> >> ja, das klappt einwandfrei, mit Mapfiles wo Werte mit 4 multipliziert
> >> werden ist das hochaufgelöste Resultat  prima, bis auf die Luftbilder.
> Die
> >> Luftbilder sehen sowohl bei 72dpi als auch 288 dpi miserabel aus.
> >> Hmmm....scheinbar wird bei der Einbettung ins PDF da irgendwas mit den
> >> Bildern gemacht (nur was?).
> >> Viele Grüße, Kai
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
More information about the Mapbender_users mailing list
