AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial images
Michael Schulz mschulz at webgis.de
Wed Jun 18 05:46:20 EDT 2008
Hi Kai,
before answering complete rubbish, I double checked whether the pngs
embedded in the pdf are actually 24bit. But they are.
>From looking at the code, mapbender creates img obj with
imagecreatetruecolor and copies all wms images into that image. the
wms images are requested again with a getmap request but with the
format set to "image/png". You have to make sure, that your mapserver
spits out 24bit images also when requested with image/png and not only
with "image/png; mode=24bit".
How do the images look in the mapbender application, when the wms
format is set to image/png and not image/png; 24bit? That's my
outputformat:
  IMAGETYPE PNG
  DEBUG on
  OUTPUTFORMAT
    NAME PNG
    DRIVER "GD/PNG"
    MIMETYPE "image/png"
    IMAGEMODE RGBA
    EXTENSION "png"
  END
The only difference is that i'm using alpha transparency, hmm... Do
you have both options image/png and image/png;mode=24bit in your
getcapabilities? What version of mapserver are we talking about?
Keep on trying ;-) The solution to switch the mapfiles is surely a
way, I'think you could achieve the same, by setting the processing
parameters to your png outputformat and use jpeg in the browser
(because for the print the map would be requested with png...).
Cheers, Michael
Am 17. Juni 2008 16:06 schrieb Kai Behncke <Kai-Behncke at gmx.de>:
> Hi Michael, thank you.
> You mean you made it somehow to integrate 24bit pngs in the Mapbender-Print?
> Great, but what exactly did you do?
> Well, at "WMS Gui Enstellungen" in Mapbender I choose "image/png; mode=24 bit".
> In the WebGIS it looks fine but in the print everything else than that.
> How did you define the OUTPUTFORMAT?
> I tried it with:
> MAP
> NAME           'luftbilder'
> STATUS ON
> IMAGETYPE     PNG
> EXTENT        3595000 5904140  3621500  5919000
> UNITS          METERS
> SIZE        500 500
>  IMAGECOLOR 255 255 255
> SHAPEPATH       '/home/deichbau/daten/luftbilder'
> OUTPUTFORMAT
>  NAME png
>  DRIVER "GD/PNG"
>  IMAGEMODE RGB
>  EXTENSION "png"
> END
> ....but the result is not what I want.
> Best regards, Kai
> -------- Original-Nachricht --------
>> Datum: Tue, 17 Jun 2008 15:33:15 +0200
>> Von: "Michael Schulz" <mschulz at webgis.de>
>> An: "Mapbender User List" <mapbender_users at lists.osgeo.org>
>> Betreff: Re: AW: [Mapbender-users] Ausdruck von Luftbildern / Printing aerial images
>> Hi Marc, Kai,
>> I think Marc is right: Kai, your pretty surely using jpeg for aerial
>> images, but the pdf print code sets the format to png
>> (classweldmaps2png.php, line 49). I never had problems using 24bit
>> png's, so perhaps Kai can set an outputformat png with rgb, in order
>> to avoid the usual mapserver "png; 24bit" format. Then you should get
>> good looking (huge) aerial images in the pdf.
>> Cheers, Michael
>> Am 17. Juni 2008 15:00 schrieb Marc Jansen <jansen.marc at gmx.de>:
>> > Hi Kai,
>> > could you post  the FORMAT-Parameter (png, gif, etc.)  which you
>> request?
>> > AFAIK the PDF-lib used in Mabender is incapable of 24bit-PNGs (enabled
>> e.g.
>> > with IMAGEMODE RGB in UMN Mapserver). Furthermore, your problem
>> description
>> > makes me think of a JPEG which is transformed to a PNG when adding to
>> the
>> > PDF. But that is pure guessing.
>> > -- Marc
>> > Hi Kai,
>> > könnntest Du den Parameter FORMAT (png, gif, etc.) mal an die Liste
>> senden?
>> > Sowei ich weiß kann die vomn Mapbender verwendete PDF-lib nicht mit 24
>> bot
>> > PNGs unmgehen (im UMN Mapserver z.B. via IMAGEMODE RGB
>> bereitgestelllt),.
>> > Die Problembeschreibung könnte allerdings auch (hier rate ich) auf ein
>> JPEG
>> > hindeuten, welches vom PDF-Module bei einbettung in das PDF in ein PNG
>> > umgewandelt wird. (weldMapsToPng).
>> > -- Marc
>> > Kai Behncke schrieb:
>> >> Hi Markus,
>> >>> ich habe mich selbst noch nicht ausgiebig damit beschäftigt. Es gibt
>> aber
>> >>> beim Mapbender das Druckmodul, bei dem man die Auflösung (dpi)
>> einstellen
>> >>> kann, mit der das Bild für den Druck angefordert wird (Für den Druck
>> >>> benötigt man in der Regel höhere Auflösungen als für den
>> Bildschirm).
>> >>> Man
>> >>> muss dabei nur gewährleisten, dass der Mapserver die hohe Auflösung
>> >>> bringt,
>> >>> ansonsten gibt es eine weiße Seite.
>> >> ja, das klappt einwandfrei, mit Mapfiles wo Werte mit 4 multipliziert
>> >> werden ist das hochaufgelöste Resultat  prima, bis auf die Luftbilder.
>> Die
>> >> Luftbilder sehen sowohl bei 72dpi als auch 288 dpi miserabel aus.
>> >> Hmmm....scheinbar wird bei der Einbettung ins PDF da irgendwas mit den
>> >> Bildern gemacht (nur was?).
>> >> Viele Grüße, Kai
>> > _______________________________________________
>> > Mapbender_users mailing list
>> > Mapbender_users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Michael Schulz
>> in medias res
>> Gesellschaft für Informationstechnologie mbH
>> In den Weihermatten 66
>> 79108 Freiburg
>> Tel +49 (0)761 556959-5
>> Fax +49 (0)761 556959-6
>> http://www.webgis.de / http://www.zopecms.de
> Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users mailing list
