[Mapbender-users] Query Parameter for a specific external WMS
Michael Schulz mschulz at webgis.de
Thu Oct 30 10:31:45 EDT 2008
Hi Gisbert,
your function looks ok. Is your WMS setup to respond accordingly? Did
you check the mapbender and / or mapserver log?
If you are using umn: I don't know what mapserver does, when a getmap
with time parameter request comes in but the requested layer has no
time metadata setup. I think mapserver tries to create a corresponding
time expression, but as no time column was defined probably fails.
Could that be the case?
Have you looked at that document:
http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
Cheers, Michael
2008/10/30  <gisbert.breitbach at gkss.de>:
> Hi,
> but how do I add the time parameter as a vendor specific parameter.
> I tried to use mod_add_vendorspecific.php
> with that kind of code:
> <?php
> # $Id:
> # add vendor-specific parameters to MapRequest and FeatureInfoRequests
> # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
> # Copyright (C) 2002 CCGIS
> # This program is free software; you can redistribute it and/or modify
> # it under the terms of the GNU General Public License as published by
> # the Free Software Foundation; either version 2, or (at your option)
> # any later version.
> # This program is distributed in the hope that it will be useful,
> # but WITHOUT ANY WARRANTY; without even the implied warranty of
> # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
> # GNU General Public License for more details.
> # You should have received a copy of the GNU General Public License
> # along with this program; if not, write to the Free Software
> # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307,
> USA.
> require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
> mb_registerVendorSpecific("mod_vs_init()");
> function mod_vs_init(){
> var re = "time=<?php echo
> "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
>   return re;
> The only thing that happened is that all maps disappeared including
> background, overview and mapframe.
> Best regards,
> Gisbert
> ____________________________________________________
> Gisbert Breitbach, GKSS Forschungszentrum
> Tel.: +49 4152 87 1563
> Fax: +49 4152 87 4 1563
> E-Mail: Gisbert.Breitbach at gkss.de
> mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 14:33:57:
>> Hi,
>> I don't think this is possible at the moment. Mapbender is not aware
>> of the wms time component. What you could do, is to add the time
>> parameter as a vendor specific parameter, that would be controlled by
>> a customized module.
>> If you want to use the wms time parameter you would also have to setup
>> your wms accordingly, so that you only have one layer "chlorophyll
>> measurements" and a time column for your data.
>> Cheers, Michael
>> > Hello everybody,
>> > I'm using Mapbender to show different measured raster maps, for
> example
>> > Chlorophyll in the north sea measured by satellites. Every day a new
>> > measurement is done. In my own WMS every new measurement means a new
> layer
>> > with a name reflecting the date.
>> > Other people have solved the problem introducing a time filter
> parameter
>> > into the GetMap request like
>> > ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
>> > Is it possible to include such a filter parameter into the GetMap
> request
>> > of Mapbender and, if yes, how can it be done.
>> > Many thanks,
>> > Gisbert Breitbach
>> > Mapbender_users mailing list
>> > Mapbender_users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> Michael Schulz
>> in medias res
>> Gesellschaft für Informationstechnologie mbH
>> In den Weihermatten 66
>> 79108 Freiburg
>> Tel  +49 (0)761 556959-5
>> Fax +49 (0)761 556959-6
>> http://www.webgis.de / http://www.zopecms.de
>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_users mailing list
