[Mapbender-users] Query Parameter for a specific external WMS
gisbert.breitbach at gkss.de gisbert.breitbach at gkss.de
Thu Oct 30 12:01:55 EDT 2008
The problem must be elsewhere perhaps in my installation. Even the initial
add_vendorspecific.php is not working if switched on.
The URL to the mapbender installation is:
kofserver2.gkss.de/mapbender
Temporary a user test with password test is created.
There are 3 GUIs available
testmitaddvendor: A test GUI with 2 WMS (demis and the UK stuff), but
nothing is shown. The mod_add_vendorspecific.php is reset to the initial
code.
test: Same GUI with add_vendorspecific switched off
Interrisk_recent: A real GUI with data in which the UK measurements should
be included.
Best regards,
Gisbert
____________________________________________________
Gisbert Breitbach, GKSS Forschungszentrum
Tel.: +49 4152 87 1563
Fax: +49 4152 87 4 1563
E-Mail: Gisbert.Breitbach at gkss.de
mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 16:45:09:
> Hello,
> is it possible to take a look at your mapbender installation? If it's
> not possible please separate the maprequests in Firefox (page info ->
> media) and post them to this list.
> Maybe they are a little bit enlightening.
> regards
> Uli
> gisbert.breitbach at gkss.de schrieb:
> > Hi Michael,
> > I got no Mapbender error log.
> > I want to use the time parameter for an external WMS server from UK.
They
> > gave me an URL like that:
http://www.npm.ac.uk/rsg/projects/interrisk/ncof_mapserver_wms?map=/var/
> > www/cgi-bin/wms.map&FORMAT=image%
> 2Fpng&TRANSPARENT=true&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%
> 3A59%
> 3A00&EXCEPTIONS=XML&LAYERS=zg_MYO_chlor_a_time&SERVICE=MS&VERSION=1.
> 1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A4326&BBOX=-11.25,56.25,0,67.
> 5&WIDTH=256&HEIGHT=256
> > This URL works for a browser. I removed all other WMS from the GUI.
Just
> > this WMS and demis.nl stay as part of the GUI. I put this WMS on the
first
> > position and removed the setBackground stuff. But the result is no map
and
> > even no frame.
> > I'm a little bit helpless, Gisbert
> > mapbender_users-bounces at lists.osgeo.org wrote on 30.10.2008 15:31:45:
> >> Hi Gisbert,
> >> your function looks ok. Is your WMS setup to respond accordingly? Did
> >> you check the mapbender and / or mapserver log?
> >> If you are using umn: I don't know what mapserver does, when a getmap
> >> with time parameter request comes in but the requested layer has no
> >> time metadata setup. I think mapserver tries to create a
corresponding
> >> time expression, but as no time column was defined probably fails.
> >> Could that be the case?
> >> Have you looked at that document:
> >> http://mapserver.gis.umn.edu/docs/howto/wms_time_support ?
> >> Cheers, Michael
> >> 2008/10/30  <gisbert.breitbach at gkss.de>:
> >>> Hi,
> >>> but how do I add the time parameter as a vendor specific parameter.
> >>> I tried to use mod_add_vendorspecific.php
> >>> with that kind of code:
> >>> <?php
> >>> # $Id:
> >>> # add vendor-specific parameters to MapRequest and
FeatureInfoRequests
> >>> # http://www.mapbender.org/index.php/mod_add_vendorspecific.php
> >>> # Copyright (C) 2002 CCGIS
> >>> # This program is free software; you can redistribute it and/or
modify
> >>> # it under the terms of the GNU General Public License as published
by
> >>> # the Free Software Foundation; either version 2, or (at your
option)
> >>> # any later version.
> >>> # This program is distributed in the hope that it will be useful,
> >>> # but WITHOUT ANY WARRANTY; without even the implied warranty of
> >>> # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
> >>> # GNU General Public License for more details.
> >>> # You should have received a copy of the GNU General Public License
> >>> # along with this program; if not, write to the Free Software
> >>> # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
> > 02111-1307,
> >>> USA.
> >>> require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
> >>> mb_registerVendorSpecific("mod_vs_init()");
> >>> function mod_vs_init(){
> >>> var re = "time=<?php echo
> >>> "2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00" ?>";
> >>>   return re;
> >>> The only thing that happened is that all maps disappeared including
> >>> background, overview and mapframe.
> >>> Best regards,
> >>> Gisbert
14:33:57:
> >>>> Hi,
> >>>> I don't think this is possible at the moment. Mapbender is not
aware
> >>>> of the wms time component. What you could do, is to add the time
> >>>> parameter as a vendor specific parameter, that would be controlled
by
> >>>> a customized module.
> >>>> If you want to use the wms time parameter you would also have to
> > setup
> >>>> your wms accordingly, so that you only have one layer "chlorophyll
> >>>> measurements" and a time column for your data.
> >>>> Cheers, Michael
> >>>>> Hello everybody,
> >>>>> I'm using Mapbender to show different measured raster maps, for
> >>> example
> >>>>> Chlorophyll in the north sea measured by satellites. Every day a
> > new
> >>>>> measurement is done. In my own WMS every new measurement means a
> > new
> >>> layer
> >>>>> with a name reflecting the date.
> >>>>> Other people have solved the problem introducing a time filter
> >>> parameter
> >>>>> into the GetMap request like
> >>>>> ...&TIME=2008-10-15T00%3A00%3A00%2F2008-10-15T23%3A59%3A00&...
> >>>>> Is it possible to include such a filter parameter into the GetMap
> >>> request
> >>>>> of Mapbender and, if yes, how can it be done.
> >>>>> Many thanks,
> >>>>> Gisbert Breitbach
> >>>>> Mapbender_users mailing list
> >>>>> Mapbender_users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> >>>> Michael Schulz
> >>>> mschulz at webgis.de
> >>>> in medias res
> >>>> Gesellschaft für Informationstechnologie mbH
> >>>> In den Weihermatten 66
> >>>> 79108 Freiburg
> >>>> Tel  +49 (0)761 556959-5
> >>>> Fax +49 (0)761 556959-6
> >>>> http://www.webgis.de / http://www.zopecms.de
> >>>> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> >>>> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
> >> Michael Schulz
> >> in medias res
> >> 79108 Freiburg
> Where2B-Konferenz
> Die Geo-IT Konferenz der WhereGroup
> vom 9.-10. Dezember 2008 in Bonn
> Web: www.where2b-conference.com
> Ulrich Rothstein
> WhereGroup GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Fon: +49 (0)228 / 90 90 38 - 17
> Fax: +49 (0)228 / 90 90 38 - 11
> mailto:uli.rothstein at wheregroup.com
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
