[Mapbender-users] Mapbender 2.5 - Internationalization - "Locale could not be set. Language ID: 'de'"
Thomas Baschetti Thomas.Baschetti at gmx.de
Tue May 5 09:29:41 EDT 2009
Hi David,
take a look at
  http://trac.osgeo.org/mapbender/ticket/312
and
http://trac.osgeo.org/mapbender/changeset/3657
in short, the line
	if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
in globalSettings.php should do the trick, LC_MESSAGES is not defined
in Windows.
david.mueller at kaiserslautern.de schrieb:
> Hello List,
> i've got a problem with the default language parameter in my
> mapbender.conf.
> I edited the following section:
> # Internationalization
> define("USE_I18N", true);  // requires gettext for PHP.
>                                           // If "false", LANGUAGE is set to
> english
> define("LANGUAGE", "de");   // only available if USE_I18N is "true".
>                                           // "en", "de", "bg", "gr", "nl",
> "it", es"
> In my Mapbender 2.5 Installation the language translation /
> internationalization doesn't work.
> I get this error in the logfiles:
> 2009.05.04, 08:40:41,ERROR: Locale could not be set. Language ID: 'de'
> All the GUIS are shown in englisch, not in german, like i suggested.
> My System is a Windows 2003 Server Standard with the ms4w Apache Web Server
> and Mapbender 2.5 installed.
> How could the language problem be solved? Any suggestions?
> Thanks!
> Mit freundlichem Gruß
> i.A. David Müller
Ciao
Thomas
Thomas Baschetti - Systemanalyse Geographische Informationssysteme
Hakenstraße 8D
49074 Osnabrück
Tel: 0541 25 91 90 | mobil 01577 189 25 91
E-Mail: info at thomas-baschetti.de
www.thomas-baschetti.de
More information about the Mapbender_users mailing list
