[Mapbender-users] Mapbender 2.5 - Internationalization - "Locale could not be set. Language ID: 'de'"
david.mueller at kaiserslautern.de david.mueller at kaiserslautern.de
Tue May 5 09:48:20 EDT 2009
hey,
thank you, this is the solution!
the translation is now working, without any errors in the logfile!
Mit freundlichem Gruß
i.A. David Müller
Stadtverwaltung Kaiserslautern
Referat Stadtentwicklung
Stabsstelle Graphische Datenverarbeitung
Willy-Brandt-Platz 1
67653 Kaiserslautern
E-Mail: david.mueller at kaiserslautern.de
Internet:  www.kaiserslautern.de
mapbender_users-bounces at lists.osgeo.org schrieb am 05.05.2009 15:29:41:
> Hi David,
> take a look at
>   http://trac.osgeo.org/mapbender/ticket/312
> and
> http://trac.osgeo.org/mapbender/changeset/3657
> in short, the line
>    if (!defined('LC_MESSAGES')) define('LC_MESSAGES', LC_CTYPE);
> in globalSettings.php should do the trick, LC_MESSAGES is not defined
> in Windows.
> david.mueller at kaiserslautern.de schrieb:
> > Hello List,
> > i've got a problem with the default language parameter in my
> > mapbender.conf.
> > I edited the following section:
> > # Internationalization
> > define("USE_I18N", true);  // requires gettext for PHP.
> >                                           // If "false", LANGUAGE is
set to
> > english
> > define("LANGUAGE", "de");   // only available if USE_I18N is "true".
> >                                           // "en", "de", "bg", "gr",
"nl",
> > "it", es"
> > In my Mapbender 2.5 Installation the language translation /
> > internationalization doesn't work.
> > I get this error in the logfiles:
> > 2009.05.04, 08:40:41,ERROR: Locale could not be set. Language ID: 'de'
> > All the GUIS are shown in englisch, not in german, like i suggested.
> > My System is a Windows 2003 Server Standard with the ms4w Apache Web
Server
> > and Mapbender 2.5 installed.
> > How could the language problem be solved? Any suggestions?
> > Thanks!
> > i.A. David Müller
> Ciao
> Thomas
> Thomas Baschetti - Systemanalyse Geographische Informationssysteme
> Hakenstraße 8D
> 49074 Osnabrück
> Tel: 0541 25 91 90 | mobil 01577 189 25 91
> E-Mail: info at thomas-baschetti.de
> www.thomas-baschetti.de
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aktuelle Informationen und Veranstaltungshinweise finden Sie unter:
http://www.kaiserslautern.de/aktuelles
More information about the Mapbender_users mailing list
