[Mapbender-users] Re: call Mapbender-instance with WMS-URL
Michael Schulz mschulz at webgis.de
Wed Apr 14 11:14:00 EDT 2010
Milad,
if you can't find the element var "loadFromSession" you'll have to set
it using the edit gui form. Tto check/set the element var click on the
link of the element id "loadwmc" - not the checkbox.
I am not 100% sure, but i think you have to use login.php not
index.php. Try the link again, supplying a name, password, if that
user has more than one gui assigned you need to supply the gui_id as
well (as mb_user_myGui) and then the wms1 url, like this:
http://localhost/mapbender26/http/frames/login.php?name=test&password=test&mb_user_myGui=gui1&
&wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
HTH, Michael
2010/4/14 Milad84 <milad1984 at gmail.com>:
> Hi,
> well I updated mapbender to 2.6 but it still doesnt work. I try to load my
> gui1 with a wms. checked the gui and the loadWMC is enabled but I still
> didnt find something about loadFromSession
> my link looks as followed..
> http://localhost/mapbender26/http/frames/index.php?&gui_id=gui1&wms1=http%3A%2F%2Fintergeo.sdisuite.de%3A80%2Fwmsconnector%2Fgdi%2Fbrd%3Frequest%3Dgetcapabilities%26service%3Dwms
> greets
> milad
> View this message in context: http://n2.nabble.com/call-Mapbender-instance-with-WMS-URL-tp4896325p4901984.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_users mailing list
