[Mapbender-users] Re: Error installation mapbender 2.6.2
sandramp sanmink at hotmail.com
Sun Aug 8 18:27:34 EDT 2010
Hi Karim,
Thanks for your help. Following your advice, I have installed Firefox (is
this one ok?? ;-)) and the message shown is (more or less, I translated it):
Connection to the server has been restarted while the page was being loaded.
Site is temporally not available or too busy. Try again in a few moments.
If you cannot load any page, check the network connection of your system
If your system or network are protected by a firewall or proxy, check that
Firefox has permission for accessing the web.
I thought I turned the firewall off to avoid problems, but I've checked it
again. Now I also turned off something like "Domain Profile" and I noticed
that the "Private Profile" is active, but Firewall is turned off.
Maybe the answer is very simple, but how do I verify that I can access the
database as the Mapbender user? The database including the table mb_user
with the user "root" is there.
Here I post you something more from the apache logs. These are the messages
from two different log in's
(hopefully it is more meaningful to you than it is for me ...):
[Sun Aug 08 22:49:53 2010] [notice] Child 2348: Starting thread to listen on
port 80.
[Sun Aug 08 23:01:16 2010] [error] [client 127.0.0.1] File does not exist:
C:/Program Files/Apache Software Foundation/Apache2.2/htdocs/favicon.ico
[Sun Aug 08 23:01:19 2010] [error] [client 127.0.0.1] File does not exist:
[Sun Aug 08 23:03:18 2010] [error] [client 127.0.0.1] File does not exist:
C:/mapbender/http/http
[Sun Aug 08 23:03:55 2010] [error] [client 127.0.0.1] File does not exist:
C:/mapbender/http/extensions/jquery-ui-1.7.2.custom/development-bundle/ui/.ui.tabs.js,
referer: http://localhost/mapbender/frames/login.php
[Sun Aug 08 23:04:12 2010] [error] [client 127.0.0.1] File does not exist:
[Sun Aug 08 23:04:23 2010] [notice] Parent: child process exited with status
255 -- Restarting.
[Sun Aug 08 23:04:24 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
configured -- resuming normal operations
[Sun Aug 08 23:04:24 2010] [notice] Server built: Jul 30 2010 16:15:37
[Sun Aug 08 23:04:24 2010] [notice] Parent: Created child process 848
[Sun Aug 08 23:04:26 2010] [notice] Child 848: Child process is running
[Sun Aug 08 23:04:26 2010] [notice] Child 848: Acquired the start mutex.
[Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting 64 worker threads.
[Sun Aug 08 23:04:26 2010] [notice] Child 848: Starting thread to listen on
port 80.
[Sun Aug 08 23:10:55 2010] [error] [client 127.0.0.1] File does not exist:
[Sun Aug 08 23:11:06 2010] [notice] Parent: child process exited with status
255 -- Restarting.
[Sun Aug 08 23:11:07 2010] [notice] Apache/2.2.16 (Win32) PHP/5.3.3
[Sun Aug 08 23:11:07 2010] [notice] Server built: Jul 30 2010 16:15:37
[Sun Aug 08 23:11:07 2010] [notice] Parent: Created child process 1672
[Sun Aug 08 23:11:08 2010] [notice] Child 1672: Child process is running
[Sun Aug 08 23:11:08 2010] [notice] Child 1672: Acquired the start mutex.
[Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting 64 worker threads.
[Sun Aug 08 23:11:08 2010] [notice] Child 1672: Starting thread to listen on
port 80.
Finally, the versions I downloaded are the following:
Windows 7 / Apache 2.2.16 / PHP 5.3.3 / Poedit / Postgresql 8.4.4 / Postgis
1.5 / Geoserver 2.0.2 / Mapbender 2.6.2
Thanks again!
Sandra
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-installation-mapbender-2-6-2-tp5385835p5387205.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users mailing list
