[Mapbender-users] 2.7
Christoph Baudson christoph at baudson.de
Tue Dec 21 17:05:43 EST 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Hernan,
On 12/21/2010 10:30 PM, Hernan Olivera wrote:
> News:
> I've installed 2.7 on osgeo4, using different path and different database name.
> And pointed another apache virtual directory.
> But now I can't login with any user/pass.
> 2.6 is still working
> What is the procedure to work with 2.7?
Please check if the database is installed correctly.
You can do this by copying the file
tools/mapbender_setup.php
to
http/php/mapbender_setup.php
and calling the script via
http://localhost/mapbender/php/mapbender_setup.php
(or whatever the path is)
Thanks
Christoph
> thanks
> 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
>> Hi all
>> I'm stucked trying to make it work on centos. Someone have installed
>> mb 2.7 on centos successfully?
>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>> installation. I hope it must work with all dependences.
>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>> Do you think it will work if I use the installation script with
>> different path and different database name?
>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>> I need to be working on 2.7
>> thanks
>> Hernan Olivera
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk0RJLEACgkQGtMIfbycMX4PjwCffJX6lArifel2xGFLZag12f4C
2HkAn2GyAr+IbYfXHgDWGYxdJ3bltrzt
=q4x/
-----END PGP SIGNATURE-----
More information about the Mapbender_users mailing list
