[Mapbender-users] 2.7
Hernan Olivera lholivera at gmail.com
Tue Dec 21 17:15:33 EST 2010
Hi Chris
You're right. I've done a first install mistaking pg password, and
reinstalling do not update that (erasing db previolusly). I have to
delete the folder and reinstall again. Now working.
Thanks
2010/12/21 Christoph Baudson <christoph at baudson.de>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Hernan,
> On 12/21/2010 10:30 PM, Hernan Olivera wrote:
>> News:
>> I've installed 2.7 on osgeo4, using different path and different database name.
>> And pointed another apache virtual directory.
>> But now I can't login with any user/pass.
>> 2.6 is still working
>> What is the procedure to work with 2.7?
> Please check if the database is installed correctly.
> You can do this by copying the file
> tools/mapbender_setup.php
> to
> http/php/mapbender_setup.php
> and calling the script via
> http://localhost/mapbender/php/mapbender_setup.php
> (or whatever the path is)
> Thanks
> Christoph
>> thanks
>> 2010/12/21 Hernan Olivera <lholivera at gmail.com>:
>>> Hi all
>>> I'm stucked trying to make it work on centos. Someone have installed
>>> mb 2.7 on centos successfully?
>>> Now I'm changing my strategy, I'll try to install 2.7 on my 0sgeo4
>>> installation. I hope it must work with all dependences.
>>> I've seen the demo server with two versions working (2.6.2 y 2.7)
>>> Do you think it will work if I use the installation script with
>>> different path and different database name?
>>> Or it is better to update 2.6.2, or delete it and install 2.7 from scratch?
>>> I need to be working on 2.7
>>> thanks
>>> Hernan Olivera
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk0RJLEACgkQGtMIfbycMX4PjwCffJX6lArifel2xGFLZag12f4C
> 2HkAn2GyAr+IbYfXHgDWGYxdJ3bltrzt
> =q4x/
> -----END PGP SIGNATURE-----
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Hernan Olivera
More information about the Mapbender_users mailing list
