Re: [Mapbender-users] No default user "root"
Petr DOBEŠ ptrdobs at email.cz
Sat Feb 20 18:30:19 EST 2010
Hello Astrid,
thank you for your help, but it doesnt work still.
Before I dowloaded mapbender 2.6., I had execute install.bat from 2.5.2, and the result was the same like later with 2.6:
Sorry, psql not found, must be in PATH-Variable, exiting...
Finished...check the log files to see if an error occured.
Should I allow some other path in Apache httpd.conf? I have only this for PostgreSQL (I have version 8.4)
<Directory "/Programy/PostgreSQL/8.4/bin/">
    Options none
    AllowOverride None
    Order allow,deny
    Allow from all
</Directory>
Thank you wery much and if you can write german, it would be better for me. Iam working on my Master in Dresden.
Have a nice time
Petr
******************** Whole run of install.bat can you see here:
Nelze najít G:\ms4w\Apache\htdocs\mapbender\resources\db\log_*.txt.
Nelze najít G:\ms4w\Apache\htdocs\mapbender\resources\db\err_*.txt.
DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN
RISK!
This script will create a database for you and will import the Mapbender data to
 the new database
It will possibly also compile the Mapbender.mo files
You need:
- a running postgresql or mysql database
- database user with write access
If everything is prepared you can continue.
Continue?
(y)es or (n)o:y
Which Database?
(p)ostgresql or (m)ysql:p
Which Encoding?
(u)tf-8 or (i)so-8859-1/latin1:u
Database host (localhost if running on local maschine):localhost
Database port (e.g. 5432 for postgres, 3306 for mysql):5432
Database user:postgres
Database Password will be asked many times during install...
Database name:Mapbender
Your Choices:
Databasetype: p - PostgreSQL
Encoding: u - UTF-8
Database Host: localhost
Database Port: 5432
Database Name: Mapbender
Database User: postgres
Database Password:  (not shown)
Looks ok, start install?
(y)es or (n)o? y
Pokračujte stisknutím libovolné klávesy...
******************************************END OF INSTALL.BAT SESSION
------------ Původní zpráva ------------
Od: Astrid Emde <astrid.emde at wheregroup.com>
Předmět: Re: [Mapbender-users] No default user "root"
Datum: 19.2.2010 18:32:19
Hello Peter,
Petr DOBEŠ schrieb:
> Hello,
> can somebody help me, please? After instalation of mapbender I dont have a
> default user "root" in the database, so I cant login me.
> I have checked it also with pgAdmin-SQL (select * from mb_user) and there is
> really no user
It look like your database was not set up correctly.
Please use the Mapbender 2.6 from SVN (there are lot of bugs fixed from
original version 2.6):
http://trac.osgeo.org/mapbender/changeset/5530/branches/2.6?old_path=%2F&format=zip
Then use the install.sh (mapbender/resources/db/install.bat) to install
Mapbender. This script will create the database and fill it with tables
and table entries.
Make sure that the installation went right. Check the log-files.
> When I make a new user, I can login, but "There are no guis available for
this
> user" So please how can I create new user with available all guis?
> Mapbender Version 2.5.2 (28-07-2009)
> operating system: Win7
Please use PostgreSQL as administrative database. What database version
do you use?
> Thank you very much
> Petr Dobes
Best regards
Astrid
> Petr DOBEŠ
> ČVUT v Praze, Fakulta stavební
> obor Geodézie a kartografie
> HTW Dresden, Fakultät Geoinformation
> ISC Buddy, ISC Media-calendar
> www.rosenka.cz
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
FOSSGIS Konferenz 2010
2. - 5. März 2010 in Osnabrück
http://www.fossgis.de/konferenz
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Petr DOBEŠ
www.rosenka.cz
More information about the Mapbender_users mailing list
