[Mapbender-users] 2.7 rc1 problem
Hernan Olivera lholivera at gmail.com
Wed Jan 19 17:19:54 EST 2011
Ok.
I have downloaded again 2.7 rc1, reinstalled from scratch and all is
working well.
I can't explain this. Maybe a newer 2.7?
Thanks. I've learned a lot :)
2011/1/19 Hernan Olivera <lholivera at gmail.com>:
>> Thanks. But I think these are not real errors. We should mark them as
>> notices.
> Ok, I've set ALL & NOTICE,
>> Any chance you got sth in your PHP error log? You can enable it in
>> php.ini, sth. like
>> logErrors = On
>> errorLog = <filename>
> Here it is:
> [19-Jan-2011 07:50:32] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 07:50:32] PHP Warning:  Module 'imagick' already loaded
> in Unknown on line 0
> [19-Jan-2011 07:50:32] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 09:06:40] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 09:06:40] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 09:06:40] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 09:09:08] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 09:09:08] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 09:09:08] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 10:08:06] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 10:08:06] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 10:08:06] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 10:08:17] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 10:08:17] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 10:08:17] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 16:20:34] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 16:20:34] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 16:20:34] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 16:45:07] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 16:45:07] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 16:45:07] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
> [19-Jan-2011 17:54:17] PHP Warning:  Module 'gd' already loaded in
> Unknown on line 0
> [19-Jan-2011 17:54:17] PHP Warning:  Module 'imagick' already loaded
> [19-Jan-2011 17:54:17] PHP Warning:  Module 'pgsql' already loaded in
> Unknown on line 0
>> Sounds like an untested PHP/Apache/Postgres configuration .. never heard
>> of so much hassle with an installation.
> I have no problems now with 2.6.2.
> mapbender_setup.php says all ok in both versions
> And.. yes, CentOS is a nightmare.
> By the way, can I import the OpenLayers example of 2.7 in 2.6.2, or I
> need another version of the app?
> thanks
>> Thanks,
>> Christoph
>>>> 2011/1/19 Christoph Baudson <christoph at baudson.de>:
>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>> Hash: SHA1
>>>>> On 01/19/2011 07:16 PM, Hernan Olivera wrote:
>>>>>> 2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
>>>>>>> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>>>>>>>> News:
>>>>>>>> I've installed 2.6.2 in the same machine, withouth any problem.
>>>>>>>> Now this is my scenario:
>>>>>>>> 1) Solve 2.7 problems to work
>>>>>>>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>>>>>>>> Someone can help?
>>>>> Hi Hernan, pleae install Firebug and check for JavaScript error messages.
>>>> I'm just doing that. There's no errors reported by firebug in 2.7 apps
>>>> (that hangs 'loading applicattion gui, gui1, gui2...').
>>>> But I can see that the head section ends after the title and then all
>>>> css is in the body.
>>>> But this is what firebug shows. If I look at the source code of the
>>>> page as is shown by firefox, the head section closes after all css.
>>>> Strange...
>>>> Searching...
>>>> Hernan Olivera
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.10 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAk03Vo0ACgkQGtMIfbycMX7v8wCfTXSYX4qu3ChNvqgVWMPdT6Ol
>> p3UAn16SEriExsLeEBSwFuEYCdPXQj/N
>> =qeAb
>> -----END PGP SIGNATURE-----
> Hernan Olivera
Hernan Olivera
More information about the Mapbender_users mailing list
