[Mapbender-users] 2.7 rc1 problem
Hernan Olivera lholivera at gmail.com
Wed Jan 19 16:46:51 EST 2011
> Thanks. But I think these are not real errors. We should mark them as
> notices.
Ok, I've set ALL & NOTICE,
> Any chance you got sth in your PHP error log? You can enable it in
> php.ini, sth. like
> logErrors = On
> errorLog = <filename>
Here it is:
[19-Jan-2011 07:50:32] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 07:50:32] PHP Warning:  Module 'imagick' already loaded
in Unknown on line 0
[19-Jan-2011 07:50:32] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 09:06:40] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 09:06:40] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 09:06:40] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 09:09:08] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 09:09:08] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 09:09:08] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 10:08:06] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 10:08:06] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 10:08:06] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 10:08:17] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 10:08:17] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 10:08:17] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 16:20:34] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 16:20:34] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 16:20:34] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 16:45:07] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 16:45:07] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 16:45:07] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
[19-Jan-2011 17:54:17] PHP Warning:  Module 'gd' already loaded in
Unknown on line 0
[19-Jan-2011 17:54:17] PHP Warning:  Module 'imagick' already loaded
[19-Jan-2011 17:54:17] PHP Warning:  Module 'pgsql' already loaded in
Unknown on line 0
> Sounds like an untested PHP/Apache/Postgres configuration .. never heard
> of so much hassle with an installation.
I have no problems now with 2.6.2.
mapbender_setup.php says all ok in both versions
And.. yes, CentOS is a nightmare.
By the way, can I import the OpenLayers example of 2.7 in 2.6.2, or I
need another version of the app?
thanks
> Thanks,
> Christoph
>> 2011/1/19 Hernan Olivera <lholivera at gmail.com>:
>>> 2011/1/19 Christoph Baudson <christoph at baudson.de>:
>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>> Hash: SHA1
>>>> On 01/19/2011 07:16 PM, Hernan Olivera wrote:
>>>>> 2011/1/19 Thoralf Kauk <tkauk at t-online.de>:
>>>>>> Am 19.01.2011 14:13, schrieb Hernan Olivera:
>>>>>>> News:
>>>>>>> I've installed 2.6.2 in the same machine, withouth any problem.
>>>>>>> Now this is my scenario:
>>>>>>> 1) Solve 2.7 problems to work
>>>>>>> 2) Use 2.6.2, but need to know what to do to use Openlayers example.
>>>>>>> Someone can help?
>>>> Hi Hernan, pleae install Firebug and check for JavaScript error messages.
>>> I'm just doing that. There's no errors reported by firebug in 2.7 apps
>>> (that hangs 'loading applicattion gui, gui1, gui2...').
>>> But I can see that the head section ends after the title and then all
>>> css is in the body.
>>> But this is what firebug shows. If I look at the source code of the
>>> page as is shown by firefox, the head section closes after all css.
>>> Strange...
>>> Searching...
>>> Hernan Olivera
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.10 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk03Vo0ACgkQGtMIfbycMX7v8wCfTXSYX4qu3ChNvqgVWMPdT6Ol
> p3UAn16SEriExsLeEBSwFuEYCdPXQj/N
> =qeAb
> -----END PGP SIGNATURE-----
Hernan Olivera
More information about the Mapbender_users mailing list
