[Mapbender-users] no mb_metadata - sql error after getCapabilites Request - PostGreSQL and PostGIS
Armin Retterath armin.retterath at lvermgeo.rlp.de
Fri Aug 24 05:21:24 PDT 2012
Hello Jugeen,
we had this problem before on the list I think, but I don't know it
really. You need the mb_metadata table! I would strongly recommend to
install the mapbender trunk version and to really control if all update
sql's are made in the install script. The mapbender mb_metadata table
would be part of the update script:
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
In line 1781 the mb_metadata table will be created.
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
is the last update sql. This is not part of the install script and must
be executed later or written into the install.bat script:
http://trac.osgeo.org/mapbender/browser/trunk/mapbender/resources/db/install.bat
after line 145.
Hope that helps ;-)
regards
Armin
On 24.08.2012 10:42, Jugeen Word wrote:
> Hello List,
> I've tried to install Mapbender on my Windows XP 32bit workstation.
> I took the MS4W Package and the MapBender extension für MS4W.
> After that, i installed the PostGreSQL-Database (9.1) and the PostGIS
> extension (for 9.1)
> When I try to create the database for Mapbender with the
> install-script in resource/db/ everything seems to be fine - no
> records in the error log.
> but when i try to load a GetCapatbilities Request from a MapFile, i'll
> get a sql error.
> After a few researches on the net, i found out, that i do not have a
> *mb_metadata* in my postgres database.
> i tried a few version of mapbender (2,5, 2.7, 2.7.2) an the newest
> "update_2.7rc1_to_2.7rc2_
> pgsql_UTF-8.sql", - but no change.
> the mapfile also seems to be valide, it works with quantum gis,
> mapserver itself and openlayers.
> so i think, the problem is the mb_metadata, can somebody help me?
> best regards;
> Jugeen
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
http://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20120824/65d30181/attachment.html>
More information about the Mapbender_users mailing list
