[Mapbender-users] Antw: Re: Legend
Armin Retterath armin.retterath at lvermgeo.rlp.de
Tue Dec 22 02:50:26 PST 2015
hi gerhard,
choose the ows_proxy3_host and ows_proxy3_port for your proxy and set
ows_proxy3_noproxy to localhost. this may help for 3.0.5.2 ;-)
regards from germany
armin
On 22.12.2015 11:47, Gerhard Mocza wrote:
> Hi Astrid !
> Thank You for your response.
> I' ve installed 3.0.5.2 at my developing machine, but for my
> legend-issue, this was not the solution.
> Difference between 3.0.4.1 and 3.0.5.2 is entry
> "OWSProxyConfiguration" in parameters.yml, right ?
> Which entry is right for ows_proxy3_host and ows_proxy3_noproxy ?
> kind regards
> Gerhard
> Gerhard Mocza
> Institut f. Vermessung, Fernerkundung und Landinformation
> Peter Jordan Str. 82
> A-1190 Wien
> Tel.: 47654/5117
> email: gerhard.mocza at boku.ac.at
> >>> Astrid Emde <astrid.emde at wheregroup.com> 21.12.2015 08:43 >>>
> Hello Gerhard,
> I had a look at your log file. Look like in your GetLegendGraphic zu
> have encoded parts
> (request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA)
> http://../arcgis/services/AKK/acc_b_wr_neustaedter_pforte01_v02/MapServer/WmsServer?request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA
> Mapbender3 encodes the Request again which may cause th error.
> Try Mapbender 3.0.5.2 . The problem should be solved with this version.
> Astrid
> Am 2015-12-11 14:55, schrieb Gerhard Mocza:
> > Hi Astrid !
> > Thanks for quick response.
> > First: the connection from the inside-GIS-Server to the world is
> > unchecked by myself, but it was tested today positive with a friend
> > (in the outside world).
> > So it was surprising for me, to put a check to PROXY in the
> > WMS-Instanz of the service and the connection is working already
> > without configuration of proxy in parameters.yml.
> > I am using mapbender 3.0.4.1.
> > I am sending screenshots of the legend (with proxy: bottleneck1 and
> > without proxy: bottleneck2) and the log of the apache-access (first 15
> > lines for application bottleneck1 with proxy checked and spoiled
> > legend, last line for application bottleneck2 with proxy unchecked and
> > working legend).
> > kind regards
> > Gerhard
> > Gerhard Mocza
> > A-1190 Wien
> > Tel.: 47654/5117
> > email: gerhard.mocza at boku.ac.at>>> Astrid Emde
> > <astrid.emde at wheregroup.com> 11.12.2015 13:51 >>>
> > Hallo,
> > when you print the requests are send from the server. So your server
> > must reach the services and know himself.
> > Please configure the proxy in parameters.yml
> http://doc.mapbender3.org/en/book/installation/configuration.html#parameters-yml
> > [6]
> > And maybe define ows_proxy3_noproxy.
> > Have a look in your logfiles to find out which requests failed and
> > what is the error message.
> > Can you send a map and a getLegend request to compare the two?
> > Do you use Mapbender3 3.0.5.2? We had an issue with the legend in
> > earlier versions.
> > Astrid
> > Am 11.12.2015 12:38, schrieb Gerhard Mocza:
> > Hi All !
> > I have already successful installed a mapbender-application, which
> > request WMS-Services from an Server inside our local net, seperated
> > through a firewall.
> > Outside the local net in the DMZ-Zone mapbender is working with
> > legends, generated from the layers of the wms-service.
> > Recently i found out, this configuration is working well with the
> > proxy-function, but legends are not displayed anymore. When i turn off
> > the proxy-function, inside the local net i can use wms from our
> > GIS-Server with displayed layers in the legend (of course not outside
> > the local net) - turning on the proxy-functions will disturb
> > displaying layers in the legend.
> > Has anyone seen this too ?
> > Thanks und regards
> > Gerhard M
> > Gerhard Mocza
> > A-1190 Wien
> > Tel.: 47654/5117
> > Mapbender_users mailing list
> > Mapbender_users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
> > Mit freundlichen Grüßen
> > Astrid Emde
> > GIS-Consultant
> > FOSS Academy Winterschule 2016
> > Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> > http://www.foss-academy.eu/winterschule_2016 [2]
> >  Astrid Emde
> >  WhereGroup GmbH & Co.KG
> >  Eifelstraße 7
> >  53119 Bonn
> >  Germany
> >  Fon: +49(0)228 90 90 38 - 19
> >  Fax: +49(0)228 90 90 38 - 11
> >  www.wheregroup.com [3]
> >  Folgen Sie der WhereGroup auf twitter:
> > http://twitter.com/WhereGroup_com [4]
> > Amtsgericht Bonn, HRA 6788
> > Komplementärin:
> > WhereGroup Verwaltungs GmbH
> > vertreten durch:
> > Olaf Knopp, Peter Stamm
> >  pgp-public key:
> > http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [5]
> >  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> >  Signed and/or encrypted mail is highly appreciated
> > Links:
> > [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users
> > [2] http://www.foss-academy.eu/winterschule_2016
> > [3] http://www.wheregroup.com
> > [4] http://twitter.com/WhereGroup_com
> > [5] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> > [6]
> Astrid Emde
> GIS-Consultant
>   Astrid Emde
>   Eifelstraße 7
>   53119 Bonn
>   Germany
>   www.wheregroup.com
> Komplementärin:
> vertreten durch:
>   pgp-public key:
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466
http://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151222/bfdd3d9d/attachment-0001.html>
More information about the Mapbender_users mailing list
