[Mapbender-users] Antw: Re: Legend
Gerhard Mocza gerhard.mocza at boku.ac.at
Tue Dec 22 04:56:25 PST 2015
Hi Armin !
Thank you for your config-help.
This made it quite clear, proxy-config is not the reasson for my
legend-issue.
Must be encoding of LegendGraphics ! Maybe in 3.0.5.2 is a checkbox
anywhere or a switch in a config-file, where encoding could be turned
off ?
kind regards
Gerhard
Gerhard Mocza
Institut f. Vermessung, Fernerkundung und Landinformation
Peter Jordan Str. 82
A-1190 Wien
Tel.: 47654/5117
email: gerhard.mocza at boku.ac.at>>> Armin Retterath
<armin.retterath at lvermgeo.rlp.de> 22.12.2015 11:50 >>>
hi gerhard,
choose the ows_proxy3_host and ows_proxy3_port for your proxy and set
ows_proxy3_noproxy to localhost. this may help for 3.0.5.2 ;-)
regards from germany
armin
On 22.12.2015 11:47, Gerhard Mocza wrote:
Hi Astrid !
Thank You for your response.
I' ve installed 3.0.5.2 at my developing machine, but for my
legend-issue, this was not the solution.
Difference between 3.0.4.1 and 3.0.5.2 is entry "OWSProxyConfiguration"
in parameters.yml, right ?
Which entry is right for ows_proxy3_host and ows_proxy3_noproxy ?
kind regards
Gerhard
Gerhard Mocza
A-1190 Wien
Tel.: 47654/5117
>>> Astrid Emde <astrid.emde at wheregroup.com>
( mailto:astrid.emde at wheregroup.com)  21.12.2015 08:43 >>>
Hello Gerhard,
I had a look at your log file. Look like in your GetLegendGraphic zu
have encoded parts
(request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA)
http://../arcgis/services/AKK/acc_b_wr_neustaedter_pforte01_v02/MapServer/WmsServer?request=GetLegendGraphic%26version=1.3.0%26format=image/png%26layer=0&_signature=106%3A6ViVPx-E8aW020AS215KMHnYRBA
Mapbender3 encodes the Request again which may cause th error.
Try Mapbender 3.0.5.2 . The problem should be solved with this
version.
Astrid
Am 2015-12-11 14:55, schrieb Gerhard Mocza:
> Hi Astrid !
> Thanks for quick response.
> First: the connection from the inside-GIS-Server to the world is
> unchecked by myself, but it was tested today positive with a friend
> (in the outside world).
> So it was surprising for me, to put a check to PROXY in the
> WMS-Instanz of the service and the connection is working already
> without configuration of proxy in parameters.yml.
> I am using mapbender 3.0.4.1.
> I am sending screenshots of the legend (with proxy: bottleneck1 and
> without proxy: bottleneck2) and the log of the apache-access (first
15
> lines for application bottleneck1 with proxy checked and spoiled
> legend, last line for application bottleneck2 with proxy unchecked
and
> working legend).
> kind regards
> Gerhard
> Gerhard Mocza
> A-1190 Wien
> Tel.: 47654/5117
> email: gerhard.mocza at boku.ac.at>>> Astrid Emde
( mailto:astrid.emde at wheregroup.com)  11.12.2015 13:51 >>>
> Hallo,
> when you print the requests are send from the server. So your server
> must reach the services and know himself.
> Please configure the proxy in parameters.yml
http://doc.mapbender3.org/en/book/installation/configuration.html#parameters-yml
> [6]
> And maybe define ows_proxy3_noproxy.
> Have a look in your logfiles to find out which requests failed and
> what is the error message.
> Can you send a map and a getLegend request to compare the two?
> Do you use Mapbender3 3.0.5.2? We had an issue with the legend in
> earlier versions.
> Astrid
> Am 11.12.2015 12:38, schrieb Gerhard Mocza:
> Hi All !
> I have already successful installed a mapbender-application, which
> request WMS-Services from an Server inside our local net, seperated
> through a firewall.
> Outside the local net in the DMZ-Zone mapbender is working with
> legends, generated from the layers of the wms-service.
> Recently i found out, this configuration is working well with the
> proxy-function, but legends are not displayed anymore. When i turn
off
> the proxy-function, inside the local net i can use wms from our
> GIS-Server with displayed layers in the legend (of course not
outside
> the local net) - turning on the proxy-functions will disturb
> displaying layers in the legend.
> Has anyone seen this too ?
> Thanks und regards
> Gerhard M
> Gerhard Mocza
> A-1190 Wien
> Tel.: 47654/5117
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users [1]
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Winterschule 2016
> Alles Wichtige zur Erstellung einer GDI in nur 5 Tagen!
> http://www.foss-academy.eu/winterschule_2016 [2]
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> www.wheregroup.com [3]
> Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com [4]
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284 [5]
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
> Links:
> [1] http://lists.osgeo.org/mailman/listinfo/mapbender_users
> [2] http://www.foss-academy.eu/winterschule_2016
> [3] http://www.wheregroup.com
> [4] http://twitter.com/WhereGroup_com
> [5] http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> [6]
Astrid Emde
GIS-Consultant
Astrid Emde
Eifelstraße 7
53119 Bonn
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
pgp-public key:
listMapbender_users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapbender_users
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Von-Kuhl-Straße 49
56070 Koblenz
0261/492-466armin.retterath at lvermgeo.rlp.dehttp://www.geoportal.rlp.de
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20151222/83993a8e/attachment.html>
More information about the Mapbender_users mailing list
