[Mapbender-users] Mapbender_users Digest, Vol 108, Issue 6
Rahn Hanno (rahn) rahn at zhaw.ch
Fri Nov 20 23:48:46 PST 2015
Hello list,
Today I have a question about migrating .
I have umn mapserver 6.0 and i now change to 7.0.
But I have a little problem with my mapscript. Perhaps someone can have a look and help me, please?
I have the follwing php mapscript code:
	$class = ms_newClassObj($layer_title);
	$style = ms_newStyleObj($class);
	$class->label->set('type', 'TRUETYPE');
	$class->label->set('font', 'arialbd');
	$class->label->set('size', '12');
	$class->label->color->setRGB(0,0,0);
I think the ->label is no longer correct in version 7.0 but how do I have to change the lines? What is the correct syntax? Can you help me please? I think it is very easy for you.
Thank you very much.
Greetings
Hanno
-----Ursprüngliche Nachricht-----
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von mapbender_users-request at lists.osgeo.org
Gesendet: Freitag, 20. November 2015 21:00
An: mapbender_users at lists.osgeo.org
Betreff: Mapbender_users Digest, Vol 108, Issue 6
Send Mapbender_users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/mapbender_users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	mapbender_users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Mapbender_users digest..."
Today's Topics:
   1. Re: Probleme mit sassc (Version 3.0.5.2) (Axel Schaefer)
Message: 1
Date: Fri, 20 Nov 2015 16:23:47 +0100
From: Axel Schaefer <axel.schaefer at wheregroup.com>
To: Mapbender User List <mapbender_users at lists.osgeo.org>
Subject: Re: [Mapbender-users] Probleme mit sassc (Version 3.0.5.2)
Message-ID: <564F3B03.8000907 at wheregroup.com>
Content-Type: text/plain; charset=utf-8; format=flowed
Hallo.
der Fehler weist darauf hin, dass eine CSS-Anweisung falsch ist. ") unexpected" bedeutet, dass dort eine Klammer zu viel ist. Die falsche CSS Anweisung kommt wahrscheinlich aus einem manuell erstellten CSS Code.
Haben Sie in der Konfiguration Ihrer Anwendung (CSS-Tab der Elemente) CSS-Code integriert? Oder an einem SASS/CSS Datei Veränderungen vorgenommen? Bitte prüfen Sie Ihren CSS-Code. Sie können dazu Tools wie z.B. http://sassmeister.com/ nutzen.
Herzliche Grüße
Axel Schaefer
Am 20.11.2015 um 11:45 schrieb Wiche, Vanessa:
> Hallo Mailingliste!
> Nach der Installation der Mapbender Version 3.0.5.2 kommt eine
> Fehlermeldung bezüglich sassc.
> Mapbender  wird nicht richtig dargestellt.
> Die Fehlermeldung ist folgende:
> An error occurred while running:
> '/var/www/mapbender3/mapbender3-3.0.5.2/app/../vendor/eslider/sasscb/dist/sassc'
> '--load-path' '/' '--style' 'nested' '--load-path'
> '/var/www/mapbender3/mapbender3-3.0.5.2/app/../mapbender/src/Mapbender/CoreBundle/Resources/public/sass'
> '--load-path'
> '/var/www/mapbender3/mapbender3-3.0.5.2/app/../vendor/igosuki/compass-mixins/lib'
> '--load-path' '/var/www/mapbender3/mapbender3-3.0.5.2/app/../web'
> '/tmp/assetic_sassqKGbxm'
> Error Output:
> /var/www/mapbender3/mapbender3-3.0.5.2/app/../vendor/eslider/sasscb/dist/sassc:
> 1: Syntax error: ")" unexpected
> Input:
> @import "libs/variables";
> @import "libs/mixins";
> @import "libs/icons";
> Hat jemand dieses Problem auch gehabt und eine Lösung dafür parat?
> Mit freundlichen Grüßen
> i.A. Vanessa**Wiche
> ITEBO GmbH
> Vanessa**Wiche
> Servicebereich E-Services / DMS
> ITEBO GmbH | Dielingerstraße 39/40 | 49074 Osnabrück
> Tel.: 0541 9631 - 668 | Fax: 0541 9631 - 196
> E-Mail: wiche at itebo.de <mailto:wiche at itebo.de> | Internet:
> ITEBO GmbH, Dielingerstraße 39/40, 49074 Osnabrück; Stüvestraße 26,
> 49076 Osnabrück und Frankfurter Straße 4, 38122 Braunschweig
> Geschäftsführung: Bernd Landgraf
> Aufsichtsratsvorsitzender: Aloys Raming-Freesen
> Bankverbindung: Commerzbank Osnabrück, Kto.-Nr. 0549631000, BLZ 265
> 400 70, IBAN DE12265400700549631000, BIC COBADEFF265 HRB 18 957,
> Gerichtsstand Osnabrück
> *Verpassen Sie nicht die 6. Fachkonferenz der Hochschule Osnabrück am
> 01. Dezember 2015.*
> *Bei der Konferenz wird folgendes Thema zur Diskussion gestellt:
> „Kommunales Finanzmanagement: Aktuelle Herausforderungen und
> Entwicklungen"*
> Mapbender_users at lists.osgeo.org
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Axel Schaefer
Projektleitung
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Subject: Digest Footer
End of Mapbender_users Digest, Vol 108, Issue 6
More information about the Mapbender_users mailing list
