[Mapbender-users] How to edit data/features. Is it possible?
Axel Schaefer axel.schaefer at wheregroup.com
Thu Jan 21 05:27:46 PST 2016
Hi Paula.
Do you have Linux 32-bit?
http://lists.osgeo.org/pipermail/mapbender_users/2015-December/004768.html
Axel
Am 20.01.2016 um 21:16 schrieb paulados:
> Hi Astrid,
> Thank you very much. I think this is what I was looking for
> However, I have now another problem. First of all, I am not sure if I should
> create a new post with a new subject. Thus, if I should, please let me and I
> will do.
> The subject is that I have decided to install mapbender for trying to my own
> mapbender application because live dvd is to slow in my computer. I have
> installed mapbender3-3.0.5.2 in ubuntu 14.04 with apache 2.4, postgres9.3
> and php5.5.9. I think that I have installed mapbender correctly, however
> when I open http://localhost/mapbender3 I found that the appearance is
> strange, like if css did not work or is not loaded, and when I launch any of
> the application demos there is no map, only the text info without format. I
> attach two screenshots at the end.
> Any idea about what have I do wrong or how to debug it? I tried the
> app_dev.php mode and the only think I found wrong (in red) is that there are
> some invalid entities.
> Any idea or tip about how to debug it would be grateful.
> Thank you in advance,
> Paula
> <http://osgeo-org.1560.x6.nabble.com/file/n5246385/mapbender_error_0.png>
> <http://osgeo-org.1560.x6.nabble.com/file/n5246385/mapbender_error_1.png>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-edit-data-features-Is-it-possible-tp5246339p5246385.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Axel Schaefer
Projektleitung
Fon: +49 (0)228 / 90 90 38 - 31
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
