[Mapbender-users] Digitizer
Charlotte Toma charlotte.toma at wheregroup.com
Thu Nov 24 06:39:53 PST 2016
Hello Patrick,
If you put the digitizer in the sidepane then you can drag it down under
the layertree-element.
If you switch between the tabs (Layertree | Digitizer | Redlining | ...)
then you can't see the Digitizer outside the Digitizer-tab (look at the
screenshots).
The used digitizer confiuration is from the demo
(http://doc.mapbender3.org/de/bundles/Mapbender/CoreBundle/elements/digitizer.html).
Charly
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161124/4996acfe/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161124/4996acfe/attachment-0003.png>
More information about the Mapbender_users mailing list
