[Mapbender-users] WG: Digitizer
Patrick Meis Meis at stadt-muenster.de
Fri Nov 25 01:59:29 PST 2016
Oh, yes.
After the update to the latest mapbender-version, its working like a charm.
Before I used v3.0.5.0, and in this one the digitizer was always visible, even when
I switched to another tab in the sidepane.
Thanks for your input.
Patrick
-----Ursprüngliche Nachricht-----
Von: Mapbender_users [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Charlotte Toma
Gesendet: Donnerstag, 24. November 2016 15:40
An: Mapbender User List
Betreff: Re: [Mapbender-users] Digitizer
Hello Patrick,
If you put the digitizer in the sidepane then you can drag it down under
the layertree-element.
If you switch between the tabs (Layertree | Digitizer | Redlining | ...)
then you can't see the Digitizer outside the Digitizer-tab (look at the
screenshots).
The used digitizer confiuration is from the demo
(http://doc.mapbender3.org/de/bundles/Mapbender/CoreBundle/elements/digitizer.html).
Charly
Type: image/png
Desc: digitizer_active.png
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161125/c29d4102/attachment-0002.png>
Type: image/png
Desc: digitizer_inactive.png
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161125/c29d4102/attachment-0003.png>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20161125/c29d4102/attachment-0001.txt>
More information about the Mapbender_users mailing list
